1 - 8 of 8 Posts
Merkin salesman
I have 2 ax-15 transmissions sitting in the garage that I will never use. One is from my DD, had around 150k when pulled when I did a drivetrain swap. That trans needs synchro's, did not like going into 1st gear, the 1-2 shift or 1 to rev. Also, iirc all but 1 of the mounting bolt holes had either broken off or has a bolt broken off in there. This is from a 96 dakota
The 2nd one, I never drove. Bought it to replace mine w/ the bad synchro's (get it rebuilt then swap it in) till I decided on the drivetrain swap. I had a shop take it apart to check the synchro's and gears which I was told were in good shape but the shifter rails were frozen. After some PB blaster and gentle use of force, they were free. I just never had it put back together. The housing on that one it fine so you could use it on the other trans if you want. I really do not know what this one is from.
Pick em up in St Clair Shores, Mi. $150 for the pair.
1 - 8 of 8 Posts
