1 - 18 of 18 Posts
broken
i finished my swap today but i'm leaking antifreeze out of the hard pipe that comes out under the water pump and goes into the fire wall. what is this called? how shitty is it to fix exc.... thanks
aron
2.5
2.5 5 speed 98 tj
broken
Discussion Starter · #3 ·
it starts as a hard pipe and goes to rubber as it goes to the firewall.
broken
Discussion Starter · #5 ·
broken
Discussion Starter · #6 ·
it's leakin as it comes out of the block tho:( forgot to say that
Its tough out there.
are you talking about the elbow tube that comes off the water pump and goes up to beside the valve couver and ac compressor?
this one on the left of pict?
if its leaking from the block maybe water pump, or thurmistat housing? its not leaking from the side is it?
picts would help.
broken
Discussion Starter · #8 ·
picts would help.
yup thats the one. it was cracked right above the fitting that goes in to the block so i just blocked it and the hose for now . will this be a problem? just intill i order the part.
thanks aron
Fucking Zen as Shit
thanks aron
UNTIL
I would get it replaced as soon as you can.
While your not using the heat right now the cooling system still relies
on the coolant circulating through there and back into the block.
broken
Discussion Starter · #10 ·
UNTIL
thanks. auto zone and murries said it was a jeep dealer part and they were closed allready. is that why the temp gauge didn't go over 110?
did you get my pm about the part?
broken
Discussion Starter · #15 ·
broken
Discussion Starter · #16 ·
got it fixed today thanks for the help.
Premium Member
Good to hear, but please don't edit the title of your thread to delete what it is about- people (well, at least me, anyway) actually seach the threads for info, and maybe this one can help someone else looking for similar info.
Thanks. :thumb:
broken
Discussion Starter · #18 ·
Thanks. :thumb:
i do the same :sonicjay: i should have thought of that.:beer:
1 - 18 of 18 Posts
