1 - 2 of 2 Posts
· Thin Line Offroad
1994 Bombardier Sea-Doo Jet Ski I took in on trade late last season, so I don't know a bunch about it. I took it out once and it seemed to drive nicely, and I had a good time with it. I don't have time to use it, so I figure it should go.
The wrist strap mechanism for shutting down the PWC is missing. The previous owner taped the shutoff switch so he could run it without the strap. I bought a new strap, but the key part does not fit right, so if this is important to you, you will need to replace it, otherwise ride it as is.
The engine is a two stroke two cylinder and runs nicely. It does need a new battery, as it will not keep a charge overnight. I winterized and fogged the motor last fall, so it will need to be fired, and probably some new spark plugs. I have no idea what size the motor is, and I see no indication of what it is.
I have a clear title to the Jet ski in my name, and the shorelander trailer is registered in my name. The trailer has a long tounge and takes a 1 7/8 ball. The wiring and lights on the trailer need work, as the lights do not currently work.
The hull of the PWC is in nice shape, with only some minor blemishes. I see no breakage or fiberglass separation. The seat has some small cuts and is faded. Remember, this is a 16 year old PWC. I have kept it indoors or covered since owning it, as did the previous owner.
Call Keith at 810-614-8038. No texts and probably no trades. Calling is fastest because I only end up online every few days.
1 - 2 of 2 Posts
