1 - 20 of 51 Posts
This is a garage kept black 1990 yj with:
98 4.0 approx 60,000 miles
auto trans 904 or whatever came in a 1998 tj
front Dana 30 hp limited slip 4:10 gears
rear axle dana 35 limited slip but spiders stripped at dunes last year so its currently welded. I could fix it properly though.
Warn swing out tire carrier with 33 bfg all terrain new never used
Black diamond 4.5" exterme duty lift kit Daystar 1" body lift.
33-12.50-15 on mickey thompson wheels 80% tread
Best top tan seats
Best top tan top with black steel half doors
The tub has minimal rust, front fender on pass side was once crunched flat fenders would really set it off.
The frame is spotless.
bestop extended yj flares.
cd player, hornet alarm with autostart.
This jeep was built for my wife as a dd. It has been to silver lake 1 time and St. Helen two track twice.
new brakes with inline tube stainless lines, brake booster, pads shoes, wheel cylinders, rotors, drums, and calipers.
New optima red top battery
tilt steering wheel
Family rollcage
This jeep was rebuilt three years ago and doesn't get used! It is reliable transportation! I am asking 3500.00 obo I will take pics sometime this week. Thanks for looking.
Discussion Starter · #13 ·
would you take 3800 ? trying not to be a low baller but I dont have a ton of cash
I will take 3800.00 cash. The optima battery will not take a charge so its getting a new red top tomarrow! I will do 38 becauce the body is starting to show some rust everything is repairable but being straight up about everything. I do not want to be labeled as a junk seller. The jeep has a tj 20 gallon tank with a new fuel pump sender. The reason I bring this up is because the bus systems for the gauges are different. So it could use a gas gauge. Its been like this for two years now. We just put gas in it every 250 miles. Give me a call 586 419-3526 Jim
Discussion Starter · #19 ·
I'm trying to thin my insurace bill, I already have 7 vehicles and I drive a company truck so I just want to thin out my driveway. No trades on this just cash! I can't believe this isn't gone yet. Its dirt cheap for as solid as it is and reliable also!
1 - 20 of 51 Posts
