1 - 4 of 4 Posts
· FORD / GM
Ford F-250 2wd. It has a 4.9L I6 5 Speed stick. Odometer reads 67k miles, but I'm not sure if its original or not. Recently replaced parts include front rotors and wheel bearings, Clutch, Slave Cylinder, Pan Gasket, U-Joints, thermostat, thermostat housing, water pump, and a new serpintine belt. I have just recently put 33 inch tires all the way around. The truck does leak oil do to a bad valve cover gasket. Dual tanks both work. Rear shackles will need to be replaced soon! This truck is my everyday driver and it is very reliable.
Give me a call at 517-672-6161 or PM
$1,200 or trade for an 80's Chevy Suburban or K5 Blazer.
1 - 4 of 4 Posts
