1978 Ford f 250 dana 44 HD high pinion front 4x4 axle.
-8 lug
-dana 44 high pinion
-4:10 gears -flat top knuckles (pass side not machined or drilled)
-3" tubes and 1/2" thick wall -driver side drop
-68" wheel mount surface to wheel mount surface.
-31-1/2" spring centers
-30 spline inner shafts.
-all stock hardware Axle has been sitting in my shop for over 10 years. housing is sandblasted, epoxy primed. Everything included, only thing missing is 1 lock out and one brake caliper. Includes u bolt mounting brackets and tie rod. All shock mounts and brackets have been removed. Was going to put in a jeep and went a different route. Axle is apart and ready for rebuild. Will not ship, can help load. located in Vermilion Ohio 44089. price is firm. Call or text 614-935-8008
