1 - 1 of 1 Posts
1948 Willys Jeep
Clear title and original VIN plates
New body with Willys script
Completely rebuilt chassis including:
Brakes – everything new from the vacuum plate out including drums
New master cylinder
New brake lines and hoses
New exhaust system from the manifold back
New springs and mounts
New seals front and rear
Rebuilt steering box and drag-arm assembly
New clutch, pressure plate, and throwout bearing
Rebuilt parking brake
Resealed gearbox
Rebuilt motor by professional
New electronic ignition distributor
Two carburetors with rebuild kit – not installed
Original radiator
Large amount of new parts (see pictures)
The frame, wheels, and seat frames were sandblasted and hot-dipped galvanized. The frame has been painted with POR. Body is in factory original condition. It has been stored indoors, has green epoxy primer, and is new. Tires are rollers only – will not all hold air. Many numerous new and used parts are included. Over $11,000 invested - Will take $8000 firm. 989-324-00five6
1 - 1 of 1 Posts
