Here ya go Jim, I'll post up something I slapped together this year.
I wanted a gator, but didn't want to pay for one. I had a 46 willys drivetrain and frame lying around that I picked up for $250. so queue the home depot theme song.
Picked up a set of 35s on 15" rims for $50, one needed a tube (eventually a 2nd needed a tube also).
Picked up an 18hp Duromax engine, electric start for $429 to my door from eBay. Comet CVT clutch, and welded up a sprocket to get the chain drive into the stock t90 case. Added a cutting brake for the rear because I had it lying around, and installed 4 corner disc brakes from Brennan Metcalf using Geo Tracker parts. Welded up a new bench seat, added a front and rear rack, and some headlights.
Added some front and rear reciever tubes to help navigate larger trailers around my new property in the UP.
Here's the cabin, still a lot of work to do. Couple buddies and I ripped the junk front half of the building off and got to work on the rear half. 12x14 lofted building, built with 4x4 timbers in all the wrong ways, but it has been standing the test of time uninhabited for a guessed 25 years. It was 7" out of level, which was fun in it's own right using a transit and a bunch of bottle jacks to get it all sorted out. Added some bunks and put a steel roof on it after replacing a bunch of rotten roof pieces. Eventually going to rebuild the front half to have a separation between sleeping and cooking/liesure quarters.
Dropped it off at the hunting cabin near Lakeview for the fall hunting season, and put it to work. We figured out that it can do 23mph in current configuration, 3rd gear high range, on hardpack dirt roads with ~500lbs in people and gear.
Need to make some tweaks for next year, and some further tweaks for hunting season. Been a super fun thing to have in the sub $1500 range.
