1 - 2 of 2 Posts
Direct Drive FTW
Looking for a 10.5 14 bolt yoke within 50 miles of grand rapids.
The splines need to be free of damage.
$40 cash.
Need to grab before noon weekend or weekdays. Pm me, thank you for looking.
Direct Drive FTW
Discussion Starter · #2 ·
I need a 10.5 full float yoke. 73 to 96 year range. I am unaware if there is a difference in full float yokes after 96
Here is the differences.
9.5" 14 Bolt:
Model Year Model
Year
C10, C15, C20 88-96 K30-K35
89-96
C30, C35 83-96 3/4 - 1 ton
81-92
K10, K15 88-96 3/4 - 1 ton Front IFS
88-96
K20, K25 81-96
12-1/8"
14 HOLES
Oval Irregular Gasket Pattern
RG Diameter 9.5"
12 12mm X 1.5" LH Threaded Bolts
PINION Diameter 1.876", 30 Spline
Semi Floating
CASE: no case breaks
8620 Material Heat-Treated
Assembly Specifications:
Cover Bolt Ft. Lbs. 20
Pinion Brg. Preload In. Lbs 20-25
Pinion Brg. Preload In. Lbs 10-15 Used
Ring Gear Backlash .005-.009
Ring Gear Bolt to case Ft. Lbs. 105
Side Brg. Caps Ft. Lbs. 60
10.5" 14 Bolt
Model Year Model
Year
3/4 Ton 1 Ton 73-92 K20, K25
73-96
G30, G35 73-96 K30, K35
73-96
C20, C25 73-96
C30, C35 73-96
The Larger and arguably the strongest production Axle.
14-7/8 x 13"
14 HOLES
RG Diameter 10.5"
12 9/16 X 18" RH Threaded Bolts
PINION Diameter 1.75", 30 Spline
CASE: 4.10 & Numerically Lower, 4.56 & Numerically Higher
Pinion Bearing Preload In. Lbs 20-25
Pinion Bearing Preload In. Lbs 10-15 Used
Side Bearing Caps Ft. Lbs. 100
1 - 2 of 2 Posts
