21 - 34 of 34 Posts
F-U-CANCER!!!
You photo bombed your own photo... lol
Project is looking good.
That backwards header has me wondering if this is getting the snail treatment?
Discussion Starter · #22 ·
Lol i saw that too... look kinda like a grumpy caveman!
Thanks it's been in the shop taking up room for far too long. Time to get it moving.
Yes sir!!! Probably not at first, but the exhaust will be built with it just so it's bolt in later. I don't want to deal with trying to rebuild the engine before i can even test the suspension, so I'll run with the 260k+ for now. Hopefully by winter 23/24 I'll have a fresh engine ready to install, then take to the dyno tuner to see how many whoopows i can make!
I also might just say fuck it and install/ tune for it right away so i have motivation to build an engine a lot quicker once this one grenades lol
Discussion Starter · #26 ·
The good thing so far is that through 14" of travel there is absolutely no bind and it stays perfectly center throughout, even fully articulated either direction it is free and clear and only off center by 1/2". Just need more damn time lol
Automotive tire Motor vehicle Automotive design Automotive exterior Rim
Motor vehicle Automotive tire Automotive lighting Vehicle Automotive design
Discussion Starter · #31 ·
Lol well.....
Tire Wheel Car Vehicle Automotive tire
Full Articulated bump here... not so good. Outer fender looks to be able to stay in tact(though I'm not Full lock steering here) but the inner fender and more core support need to go. Also need to put my hoops on the top of the frame leaned toward the fender so the shock can be leaned in toward the frame to clear the tire. It's not rubbing the coil much, but at the same time, the rear shock hoop mounts also interfere with the tire lol..... also my p side upper link mount is contacting the oil pan. So have to move that over as well lol which means the d side one has to move for symmetry. Yay!
Discussion Starter · #32 ·
Finally got some time to work on this pos.
Relocated the shock hoops to the top of the frame via some angle iron mounts I'll turn into straps over top of the frame. The passenger side is a little tight to the turbo header. I'll have to remove it to get the engine out, but that's not a big deal. I hope...
Motor vehicle Automotive tire Tread Hood Automotive exterior
Vehicle Automotive tire Hood Motor vehicle Tire
Automotive tire Motor vehicle Automotive fuel system Automotive exterior Rim
Also of note, i relocated the upper link mounts on the axle, and the passenger side clears the oil pan.
Discussion Starter · #33 ·
Also clearanced the inner fenders for Articulated suspension travel. They're pretty close, but not perfect yet. I can't quite freely roll the tire, but it will go from full bump to full droop going from lock to lock, well the tire rubs the frame both front and rear a bit, so that will be where i set my lock to lock...i do still have my hydraulic bumps to install, and the travel will be limited by about 1/2" before the shock bottoms anyway, so i probably won't have any rub issues on the fender.
Tire Wheel Vehicle Car Automotive tire
Tire Wheel Motor vehicle Automotive tire Light
Automotive tire Tire Motor vehicle Automotive lighting Automotive design
Discussion Starter · #34 ·
Did some stuff a while back... haven't had much of a chance to get in the shop lately.
Got the t- case/ underdrive mocked up for the drive shaft in the front. Going double cardon 1410 at the case and 1410 at the axle.
Need to cut a notch in the cross member for more clearance, then get the case mount installed to be finished with that...
Wheel Tire Automotive tire Motor vehicle Hood
Bump stops also in place on both sides. I'm using a pipe landing pad and only losing 1/4" of travel when fully articulated.
Automotive tire Leg Motor vehicle Automotive lighting Automotive exterior
Installed the over engine tube to connect the shock hoops as well.
Wheel Tire Hood Automotive tire Motor vehicle
21 - 34 of 34 Posts
