1 - 7 of 7 Posts
Uggh
This is a stoopid question but will I be able to pull my transmission if I cannot turn the flywheel to remove the converter bolts?
Or do I need to pull the engine and trans in one shot?
any thought would be appreciated
thanks in advance
Premium Member
You "Might" be able to pull the trans without removing the converter. It just depends on if you can get a straight pull back on it.
What are you trying to do?
Uggh
Discussion Starter · #3 ·
well I don't really know what I am trying to do the damned thing is locked up I can't turn the engine over at all tried pulling the plugs and using a breaker bar etc. It was running fine before it happened drove to westbranch and It stalled and wont turn over. I have been told the trans pump is probably locked up. :confused: :confused: :confused:
unless the converter is locked up too the motor should atleast turn over
Yankabilly
Even if the converter was locked up it would still turn. Unless the pump is fawked and welded itself to the converter.
You should be able to pull the trans straight back to disengage it from the converter. Just don't try to install it that way...
AAA GOLD ROCKS!!!!!
Might sounds stupid quag but pull the belt off to make sure the alt. or some other acc. lock up. Then try to turn the engine over by hand. I once had a pos chevy have the alt. lock up and the motor seemed froze.
Uggh
Discussion Starter · #7 ·
yeah I can't believe I didn't think of that I had a pos chevy that did the same but to no avail it still dosent turn over.
buh bye auto hello stick?
1 - 7 of 7 Posts
