the girlfriends gear box is leaking, from what i could tell it was leaking out of the input shaft area. i looked at it after i got back from the bar and it was dark so no guarantees that is where its leaking.
the question is, i pulled the diagram on mitchell and there is a bunch of "O" rings that go around the valve body and all, now is that even worth tearing into? or would it need a full rebuild or replacement. i know seals go bad but i dont want to replace them if parts are warn and made the seals leak.
