The Kernel - 46 2a build - Broke Ground 11/27/15 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2014, 08:20 PM   #1
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Default The Kernel - 46 2a build - Broke Ground 11/27/15
In design and parts collecting phase.
EDIT: The build has started. see page 6
I acquired a 1946 CJ2a from Mr. Crawl this past summer for my next rig since parting out the eliminator. I wanted to come up with a name before I posted the start to the build thread.
Only keepin the front cowl, fenders, grille, and hood. rest will be sold or scrapped.
Starting from the ground up, the plan is for 35" tires on a pair of scout axles (or something else in the 60" wms range) with some sort of traction aid in at least the rear to start. Ended up with 44/44 Waggy axles.
Toss up on the suspension, but it will be linked. Low slung as sensically reasonable. 4 link front and rear with ORI struts
Frame will be new, along with a custom tub taking the styling queues of the original, which will allow for a slight wheelbase stretch in the rear. A roll cage will be installed, either tied into the body, or separate. PRP low back seats are the preference for now. Some sort of Desert Tan will be the main color for the rig. Largely unchanged, except mastercraft low back seats.
As for the powertrain, and part of the name I've given to this project.
e-85 powered 3800 pontiac supercharged engine attached to a powerglide(now planning for an AW4 with a d300 (might just stick with 231 with SS SYE). Overall length of this setup should be in the 52-55" range. Add in 350 hp while being under 1200# drivetrain, and you have some great power to weight ratio. 3800sc/700r4/231c
The goal of this ride: To be able to cruise at 60 mph down the highway comfortably, wheel it, and drive it home. 70mph
This will not be a fast build, but should start seeing some shape take place next summer after I finish fixing up the 77 ranger bass boat. started fall 2015
The Kernel (46 CJ2a)
Mary Jane
Old November 25th, 2014, 08:24 PM   #2
Jeep Thrills
Lumbermonkey/pedalpusher
Jeep Thrills's Avatar
fawesome.
Jeep Thrills is offline   Reply With Quote
Old November 25th, 2014, 08:42 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
You doing something eventually with the sides? They have re-pops if you go in that direction.
That seat looks hard on the backside. Nice to see it all.
Old November 25th, 2014, 09:29 PM   #4
Lousypirate
Whoop Whoop
The cowl back is being scrapped... starting with all new
Mary Jane
Old November 25th, 2014, 09:36 PM   #5
1TFROT
1TFROT's Avatar
should be a very cool project
1TFROT is offline   Reply With Quote
Old November 26th, 2014, 06:43 AM   #6
Lousypirate
Whoop Whoop
http://www.pirate4x4.com/forum/jeep-...lys-mb-97.html
Enjoying the read from the Rango thread. Some good info in there, that I might borrow to a lesser extent.
Mary Jane
Old November 26th, 2014, 08:05 AM   #7
AJ Hall
offensive 2 the sensitive
AJ Hall's Avatar
How do you like that Quadrasteer on your truck and is that 2wd?
If you dont like it, get out.
AJ Hall is offline   Reply With Quote
Old November 26th, 2014, 08:06 AM   #8
Lousypirate
Whoop Whoop
I love it and it is 4wd.
I'd probably hate it if it was the 6 lug version. The 8 lug is based off the Dana 60
Mary Jane
Old November 26th, 2014, 08:20 AM   #9
kickstand
circling the drain
kickstand's Avatar
1. Before I call you @cerial I wanted to say nice build, I love old flatties.
2. You sound like @cerial, but with less lists.
Old November 26th, 2014, 08:27 AM   #10
Lousypirate
Whoop Whoop
I hope I sound more realistic than @cerial
This will be built, but I'm unclear on the timeline for completion. Mostly budgeting to finish this. Do it once, not a bunch of times.
Mary Jane
Old November 26th, 2014, 09:38 AM   #11
kickstand
circling the drain
kickstand's Avatar
You do, but @cerial was all about the plans and collecting parts, and the ability to drive on any road at any speed, so I wanted to rib you a little about that.
Old November 26th, 2014, 09:39 AM   #12
Lousypirate
Whoop Whoop
Hey now hey now. I set a goal of 60 mph comfortably, not mach 1 getting 45 mpg out of a big block Cadillac.
Mary Jane
Old November 26th, 2014, 10:03 AM   #13
dreezy
Haggard Fab
dreezy's Avatar
At least the pirate has a starting point. I'm pretty sure the only thing @cerial had was a build thread.
Old November 26th, 2014, 10:07 AM   #14
kickstand
circling the drain
kickstand's Avatar
Yeah, but he's a Lousy Pirate.
Old November 26th, 2014, 10:08 AM   #15
Lousypirate
Whoop Whoop
Did i mention that this will also be a boat?
Just kidding.
Mary Jane
Old November 26th, 2014, 10:13 AM   #16
kickstand
circling the drain
kickstand's Avatar
winning
Old November 26th, 2014, 10:16 AM   #17
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
You should look at the various Jesse Haines flatty type builds on pirate. They are more buggy than flatty, but he keeps the aesthetic while making something very functional.
Old November 26th, 2014, 10:19 AM   #18
jthomp
jthomp's Avatar
1. Will you use this rig to tow the boat to the lake?
2. Will you use this rig to tow the boat launch to the boat?
I suggest 2. It can be tricky getting the correct number of strands of copper wire, to achieve optimum current flow to ensure maximum glow from your side marker lights.
jthomp is offline   Reply With Quote
Old November 26th, 2014, 11:01 AM   #19
Lousypirate
Whoop Whoop
You might want to quit while you're ahead
Mary Jane
Old November 26th, 2014, 12:47 PM   #20
AJ Hall
AJ Hall's Avatar
Cool always wondered about that. I drove one when I was like 16 and that's it and can't remember it. Any premature wearing of parts?
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.71681 seconds with 85 queries
