Paver Patio advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2019, 01:35 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default Paver Patio advice
For me and the patios I've helped with and the people I've talked with that have done their own paver patio the base has been primarily constructed of
4-8" of 21AA, compacted
1" of slag sand
Then set pavers, sweep in sand, and compact them.
I'm between buying Fendt or Unilock pavers. Fendt still recommends the method using the 21AA. But Unilock is now changed and recommends an approach used more for permeable pavers, recommending this base construction for permeable and non permeable pavers, claiming their 40 years of experience has them recommending this method.......
cover area with geotextile mat
6-8" 3/4" CLEAR CHIP STONE (NO FINES) compacted
1" THICK LAYER OF 1/4" STONE CHIP (NO FINES)
Anybody have any input or advice on this method?
Old April 13th, 2019, 08:13 PM   #2
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
I haven't heard of this new method but I have been out of the install game for awhile, But i Know the old way is tried and true.
mideerslayer is offline   Reply With Quote
Old April 13th, 2019, 09:43 PM   #3
Gunsworth
Gunsworth's Avatar
Slag should not be used under pavers. It has a shitload of calcium and will eat the pavers from the bottom up. It is the easiest to work with and arguably more stable initially, so many still use it. But you shouldnt
Sent from my Pixel 2 using Tapatalk
Old April 14th, 2019, 05:32 AM   #4
My son in law is a certified Unilock installer. I know he likes the new method. I know my pavers done 15 years ago with the first method are definitely settling.
Old April 14th, 2019, 07:21 AM   #5
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
From bottom to top:
Geotextile riprap
9-13" of 3/4" no fines crushed limestone (basically I removed all topsoil and stopped at sand, couldn't find anyone to give me crushed stone with no fines which is what I normally use)
Compacted with a pickup truck
Geotextile riprap
1-3" of crushed granite (expensive around here)
compacted with a pickup truck
Set pavers
Sweep in mason's sand
Wash it
Sweep in more mason's sand
Wash it
For the edges I used typical plastic paver edge stuff but I used either 14" long nails or I made 2' long 3/8" rods with a washer welded on top for nails.
Hasn't moved yet through 5 winters but I used cheap Menards 11x14 "flagstone" pavers.
I was going to use Unilock pavers from their spring "seconds" sale but they were still expensive enough that combined with all the prep work it would have been cheaper just to pay someone else to pour stamped concrete.
At some point the crushed limestone will probably settle but so far nothing has moved. When I as in the UP I used crushed basalt (yooper rock) for all of it.
If it sees a lot of water (like water flowing across it) then I'd use polymeric sand. Helps with washout.
wrath is offline   Reply With Quote
Similar Threads
Need some trail advice sippycup88 Trail Rides & 4x4 Events 23 August 2nd, 2016 11:27 AM
Stamped concrete patio tweak177 The Pub 24 April 8th, 2016 06:25 AM
2000 + patio pavers copper Miscellaneous items 0 July 28th, 2015 05:35 AM
machine shop advice 73scout345 Meets, Greets, and Wrenching 24 December 1st, 2014 09:25 PM
Page generated in 0.27929 seconds with 40 queries
