You sold your toys for what ????? - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2018, 09:08 AM   #121
greygoose
Gustafson
greygoose's Avatar
Looks good!! Too bad you can't show us a floor plan.
Old April 24th, 2018, 06:10 AM   #122
jancoe
Looks good. We're just getting started on our addition here. Adding 1000 sqft and a attached garage. That's a lot of drywall mud to be putting on in order to paint in a couple days. Good luck. I don't see any adhesive behind the drywall? Is there a reason your not using any. Also my drywall guy would cringe at all those screws you used to hold them on. Lots of mud work. That's one job I leave to the guys that do it for a living.
Sent from my SM-G900V using Tapatalk
jancoe is offline   Reply With Quote
Old April 24th, 2018, 06:13 AM   #123
greygoose
Gustafson
greygoose's Avatar
Am I missing something? I have hung a lot of drywall in my life and I never put any adhesive "behind" it??
Old April 24th, 2018, 06:38 AM   #124
jancoe
My drywall guy that I have used for years uses a small amount of construction adhesive with half the amount of screws I see in your pics. The reason for it is the more screws you put in the more the drywall is trying to follow the path of every stud. Especially when you use a lot of screws. Fewer screws with adhesive behind will make and keep a straighter looking wall with less mud work. He also places stringers on top of all walls to attach drywall to. He only attaches drywall to the stringers on the outside edges of the walls and will only attach drywall to the trusses in the center of the drywall. It keeps the corners from cracking.
Old April 24th, 2018, 11:28 AM   #125
roll-bar Bob
roll-bar Bob's Avatar
Yes we are Screwed and glued I use the same number of screws as I would without the glue as I love overkill I run a bead of glue down each stud right before final placement it is a huge pain in the ass but i have been told that is how they do things these days
Just for fun I took a quarter size glob of the glue on two scrap chunks of drywall stuck them back to back after drying the paper literally tour off the back of the small chunk when separating
I am no pro but I get it on the wall and my mud guy makes it look good
RBB
Old April 24th, 2018, 11:31 AM   #126
greygoose
Gustafson
greygoose's Avatar
RBB
Well, I guess I do it the old skool way.
Old April 24th, 2018, 11:35 AM   #127
roll-bar Bob
you are learning ( full disclosure here I have been doing drywall for a long time and this is the first board I have ever glued )
RBB
Old April 24th, 2018, 04:44 PM   #128
46flattie2
RBB
Doesn't sound like overkill to me! We hired "real dry-wallers" (not the cheapest bid either) to do the drywall when we built our house and it did not take long before it looked like shit...they were of the glue glob and fewer nails mentality...guess who gets to fix all their work.
The drywall i hung myself (screwed and glued) and had a buddy finish, still looks good.
46flattie2 is offline   Reply With Quote
Old April 24th, 2018, 05:37 PM   #129
aber61
aber61's Avatar
RBB
It is code to glue the ceiling with 5/8 drywall but not necessary for the walls. I have been on jobs where guys had only glued the walls so as not to screw the walls which means no screws in the wall/field but there is a chance at some point the glue will let go and you can end up with problems down the road after settling.
So I am all for putting screws on the wall board and glue as an option.
aber61 is offline   Reply With Quote
Old April 24th, 2018, 09:02 PM   #130
14muddn
The glue is to eliminate screw pops.
Old April 25th, 2018, 06:07 AM   #131
greygoose
Gustafson
greygoose's Avatar
I was under the impression that nails pop, that's why people use screws?
Old April 25th, 2018, 06:28 AM   #132
aber61
aber61's Avatar
They were called nail pops because the guy hitting the nail at times would tear the first layer of paper and that is where the mud would usually pop first. The idea is to not tear the paper.
Screws hold better but it is the mud that lets go and shows signs of popping out. I see it all the time. By tightening up the screw and apply a little mud fixes that.
Old April 25th, 2018, 06:43 AM   #133
greygoose
Gustafson
greygoose's Avatar
I'm learning all kinds of shit in this thread.
Old April 26th, 2018, 09:28 AM   #134
roll-bar Bob
It is starting to look like a house
RBB
Old April 30th, 2018, 07:25 AM   #135
roll-bar Bob
Not a lot of fun this past weekend, and it doesn't seem like much was done when you look at the photos but not all this kind of work is always the most gratifying
It is like this beautiful wood has been in a time capsule for all these years
We are getting there
Old April 30th, 2018, 07:49 AM   #136
greygoose
Gustafson
greygoose's Avatar
Looks awesome! You guys have done a ton of work! Good job RBB!
Old May 7th, 2018, 09:19 AM   #137
roll-bar Bob
So the Cantilevered window extension in the dining room was never properly framed instead of ordering longer floor stringers they added 2 feet to each one buy just nailing more stringer on but with only a 1 foot over lap Over the past 100 years the outside wall dropped 1.25 inches and it was time for a wall lift
I doubled up 2x6s six feet long and stuffed them in the floor and jacked it back up with a 4 ton floor jack This caused considerable amounts of noise but it is not going anywhere now
Meanwhile the wife was playing Cinderella with her little bucket Scrubby Scrubby Scrubby
Ordered some more toys this weekend
and started some minor patching and wall prep
all in all another fun weekend at the farm along with 4 hours of mowing both places
RBB
Old May 7th, 2018, 09:44 AM   #138
greygoose
Gustafson
greygoose's Avatar
Looks excellent!!! You should charge admission and have a tour when it's done.....
Old May 7th, 2018, 12:25 PM   #139
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Wood trim looks amazing. That's awesome you can bring it back.
Old May 11th, 2018, 08:44 AM   #140
roll-bar Bob
Well it was time for a field trip last night so I took some photos for you guys
His new shop
My New floor
The new door and window trim
Similar Threads
Sold sold sold 1988 dodge raider 2500 OBO lansing Michigan 7tcutty Vehicles for sale 5 February 7th, 2017 10:54 PM
98 ZJ Grand Cherokee Laredo SOLD!!!!!!!! SOLD SOLD SOLD!!!!!!!!!!! fullthrottle Completed Sales 0 May 19th, 2016 07:08 PM
SOLD :96 Dodge RAM Body/Bed InTeRnEt_RyAn Completed Sales 6 March 6th, 2016 06:27 PM
2003 wrangler / Sold jeepers48 Completed Sales 19 March 9th, 2015 09:31 AM
Page generated in 0.58806 seconds with 85 queries
