Roxor Crawler Build - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2019, 04:56 PM   #121
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Originally Posted by Wramblerguy View Post
Why not just use 05+ bearing pockets in the rear?
I wanted to have the same wheel bearing, rotor, caliper and pads on every corner.
Old January 29th, 2019, 07:09 AM   #122
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Things to do before Friday in no particular order:
1. Lengthen driveshafts
2. Button up steering hoses and cooler / Fill with fluid
3. Trim Rear fenders
4. Plumb brake lines (fittings should be here today)
5. Assemble rear axle (waiting on breather and drive flanges, should be here tmr)
6. Make engine skid plate
7. Mount rock sliders
8. Mount and wire fog lights
9. Mount and wire rock lights
10. Fill all fluids (Steering, brakes and axles)
Tires are back on to figure out trimming.
Rear calipers mounted. K10 Caliper and pads, rear superduty rotor and superduty wheel bearing are used on all 4 corners.
Old January 29th, 2019, 07:53 AM   #123
cannaert
No more Jeep
cannaert's Avatar
This thing looks killer. Can not wait to see it in action.
Old January 29th, 2019, 08:13 AM   #124
Booster
Lookin real good! Can't wait to see action pics.
Booster is offline   Reply With Quote
Old January 29th, 2019, 08:36 AM   #125
Fog lights are not important. Rock lights are.
Old January 29th, 2019, 08:43 AM   #126
Zjman
You planning on adding a tuner? Or any engine mods. Heard the top speed isnít great
Sent from my iPhone using Tapatalk Pro
Zjman is offline   Reply With Quote
Old January 29th, 2019, 08:57 AM   #127
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Thanks guys!
They are acutally already wired, just need to drill a hole and mount them. But I agree.
Originally Posted by Zjman View Post
You planning on adding a tuner? Or any engine mods. Heard the top speed isn’t great
Yes. Working with a company on getting a tune. Won't happen for this trip though.
Old January 31st, 2019, 10:09 AM   #128
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Done yet? How about now?
* 2018 ZR2
Old January 31st, 2019, 10:49 AM   #129
siettas81
siettas81's Avatar
i never really looked into rear ends since i just run a 14b ff, thats cool having the bearing wheel assembly hub in rear like front neat
i dig the build i need something small like this instead of fool size
siettas81 is offline   Reply With Quote
Old January 31st, 2019, 12:05 PM   #130
green50gt
Got rocks?
green50gt's Avatar
Can this whole bearing thing be explained please? A front unit bearing goes in that pocket do-ma-hickey that was welded on the ends of the rear housing?
I heart Jeeps
green50gt is offline   Reply With Quote
Old January 31st, 2019, 12:13 PM   #131
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Yep, trail gear makes the housing with unit bearing pockets that fit 99-04 super duty unit bearings. Others make cups for 05+ unit bearings.
https://www.trail-gear.com/index.php...g-pockets.html
Their version of a 99-04 Super Duty unit bearing made to 6x5.5:
https://www.trail-gear.com/index.php...ub/category/3/
Old February 1st, 2019, 03:59 AM   #132
siettas81
siettas81's Avatar
hmmm interesting
Old February 1st, 2019, 04:38 AM   #133
I wonder if they would make a 5x5.5. If they did, would I be able to convert my 9” to a full float?
Old February 1st, 2019, 05:36 AM   #134
Ryanw10
Ryanw10's Avatar
I wonder if they would make a 5x5.5. If they did, would I be able to convert my 9Ē to a full float?
Currie does. https://www.currieenterprises.com/CE-8000JK
Or you can have the factory 99-04 hubs turned down and re drilled like I did.
Ryanw10 is offline   Reply With Quote
Old February 1st, 2019, 08:11 AM   #135
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Jim - Branik sells them drilled 5x5.5
http://branikmotorsports.com/unit-bearings/
Old February 1st, 2019, 08:25 AM   #136
Hmmmm. Something to think about for sure. I hate having to pull apart my complete rear axle to get my center section out.
Old February 1st, 2019, 09:31 AM   #137
ROXROES
cool story
ROXROES's Avatar
I am pulling 5 x 5.5 rotors, calipers and unit bearings off a jk with a currie rockjock d60 SD outer front and 14 bolt full float rear if any of that would work and save you some coin?
ROXROES is offline   Reply With Quote
Old February 10th, 2019, 04:58 PM   #138
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
We had an awesome time at KOH. Got the Roxor "finished" enough to drag it across the country with zero testing.
Other than a few issues, it did great and moved our butts around the desert all week.
Issues:
- Front axle is leaking diff fluid from the passenger. Must have damaged the cheap summit seal when installing the shafts.
- All four tires rub really bad. It was expected though, since I ran out of time for bump stops. Ended up trimming the rear fenders a little more on the lake bed.
- Steering is super slow at low rpm. Going to look into swapping the pulley or the whole pump.
- Mile marker hub on the pass. side kept unlocking for some reason. Will upgrade to chromo outters and flanges.
- Brakes are super soft. Have to look into a booster upgrade.
Still need to finish up the rock sliders and rear corner armor.
Looking into a 1" body lift to allow me to raise the trans and tcase to help with building a flatish belly skid. Also need to get beadlocks as we burped all the air out of one tire on the trail.
Old February 11th, 2019, 07:43 AM   #139
cannaert
No more Jeep
cannaert's Avatar
Not bad for a untested build. Glad it all went well and you guys had fun.
Old February 11th, 2019, 07:51 AM   #140
Thomas,
Were you wheeling by yourself?
Similar Threads
Totaled 4runner build Cdyoung1985 Rig Builds and Pics 13 November 28th, 2017 08:46 PM
Project Rural Legend - a Second Gen Dodge Four Door Ramcharger Build kkodet Rig Builds and Pics 39 October 10th, 2017 10:02 PM
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 09:40 PM
blazer/jimmy sas build 2.2 OL RED Rig Builds and Pics 4 November 28th, 2014 05:00 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 09:00 PM
Page generated in 0.85951 seconds with 87 queries
