86 B2 Swapeverydamthing! - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 4th, 2018, 12:50 PM   #81
deathbypsi
Brian R.
deathbypsi's Avatar
What did you do about the front driveshaft binding?
Nothing yet. Im going to take to my buddies shop monday and put it on the alignment rack to set the toe,center the steering wheel and see where the caster is at now. If I can get away with just changing the C-bushings to raise the pinion angle Ill do that and possibly another Tom Woods shaft with two double cardons. If this dont work Ill be forced to convert my high pinion d44 to fit.
Old May 4th, 2018, 01:36 PM   #82
Bones
Bones's Avatar
who did the exhaust? Nice, clean work.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 4th, 2018, 02:49 PM   #83
deathbypsi
Brian R.
deathbypsi's Avatar
Name is Shawn Gamble just outside Toledo
Old May 13th, 2018, 09:04 PM   #84
deathbypsi
Brian R.
deathbypsi's Avatar
Made it to our first monthly meeting with the Glass City Crawlers
Old May 14th, 2018, 06:00 AM   #85
greygoose
Gustafson
greygoose's Avatar
Very cool! I saw this one on YouTube the other day.
Old May 19th, 2018, 10:04 AM   #86
deathbypsi
Brian R.
deathbypsi's Avatar
Couple new updates.
I built a swing out tire carrier on the James Duff rear bumper and it turned out awesome. I bought the parts from EMS OffRoad and have less than $200 in all the parts and materials.
Drilled a hole thru both tubes of the bumper then welded the spindle in good.
Here is a vid of the build.
And finished.
I also finally got around to gutting the doors and swapped in the full size glass and manual regulators. Put all new dew wipes and felts in too. Turned out great!
Old May 20th, 2018, 10:50 AM   #87
deathbypsi
Brian R.
deathbypsi's Avatar
So I took the factory window switch plate thingy and changed it up to hold just one mustang door lock switch. Turned out great! Cant believe the difference the new door panels made for the interior.
Coming from the original cat hair and piss covered panels to the new stuff is amazing.
Old May 21st, 2018, 06:22 AM   #88
greygoose
Gustafson
greygoose's Avatar
Looks real good! I bet this thing is a blast to drive.
Old May 21st, 2018, 07:43 AM   #89
Turning out real sweet.
Old July 8th, 2018, 10:35 AM   #90
deathbypsi
Brian R.
deathbypsi's Avatar
Short update....
I been driving the truck all over and loving it. Been working out all the bugs. Still havent taken it off roading yet but Im close!
I was getting some surging and stalling in gear when it was up to temp and I found the motor was running a little lean since I added the better flowing Explorer intakes and 65mm throttle body. The speed density ecm just cant compensate for the added air flow so I put on a Aeromotive adjustable fuel regulator and bumped pressure up 4psi and that made all the difference. Truck runs like a brand new truck now,zero issues. And to my delight even on these 90-100 degree days I havent seen the motor temps go higher than 190.
I was getting a lot of noise from the rear axle and it was chattering real bad in turns. Wasnt expecting that out of a Detroit Locker. Well turns out something was broken inside the diff so I just swapped it out for a full DTS spool I had and now the truck drives smooth and quiet! Can hardly even tell it has a spool except in my driveway when making super tight turns.
I did some cutting on the fenders and took it back to our clubs RTI ramp to check clearance and she all good now. I am super happy with the flex this thing has!
I also finished the front bumper and Im real happy with it.
So I got a bunch of other details knocked out too. The stereo system is all done and sounds great! Love cruising around with the tunes kicking! Got my speedo back from Speedhut and works perfectly. All my lights are hooked up now. I put a rubber mat in rear and mounted a fire extinguisher to tire carrier so anyone can get to it fast.
I have about two weeks left to get all the other bugs worked out and then its off to Silver Lake Dunes for Bronco Takeover!
Old August 13th, 2018, 08:45 PM   #91
deathbypsi
Brian R.
deathbypsi's Avatar
So I finally got around to getting the front axle upgraded.
I pulled the knuckles,brakes and RCV shafts from my full width d44 in my truggy.
Then I gutted the Bronco axle and started swapping parts.
And I threw the Aussie locker in.
I bought a new shorter EB d44 passenger inner shaft from RCV and the driver side I cut .600 off the end.
I bought a new set of Warn Premium hubs and the RCV 30 spline adapter gears. I had the diff cover powder coated and threw it all back together.
So truck was all set at this point and I loaded it up for Silver Lake Bronco Takeover.
Old September 24th, 2018, 03:18 PM   #92
deathbypsi
Brian R.
deathbypsi's Avatar
so check these out......
Old December 9th, 2018, 10:29 AM   #93
Glad to see you out and enjoying it, this has become my favorite b2 thread
Old December 12th, 2018, 02:22 PM   #94
deathbypsi
Brian R.
deathbypsi's Avatar
Other than breaking these Warn hubs everytime I go out we been having a blast with it! Truck does everything I want and does sit well so far.
We spent a weekend at Rocks N Valleys with a nice group including a few other Bronco2's. My GF Lisa did most of the driving and did great for just learning to drive it.
And just this past weekend we ran out to Rouch OffRoad to check it out for the first time. Had a fun day and we got to try out our newest toy.
Old December 13th, 2018, 02:57 AM   #95
siettas81
siettas81's Avatar
bad ass man love b2's i will have another someday soon
siettas81 is offline   Reply With Quote
Old April 15th, 2019, 06:04 PM   #96
deathbypsi
Brian R.
deathbypsi's Avatar
Soooo an awful lot has happened since my last post here .......lets just say alot has happened recently!
I ended up ordering a new F250
Spent a weekend in Grayling with the Glass City Crawlers for Snow Way Dude event..vid on my channel.
Then about a month ago I decided to make some serious changes before a planned trip to Wellsville Ohio.
I concerted the motor over to Microsquirt efi so I can tune it myself now. Full vid on my channel.
And upgraded the exterior just a tad.....Full vid on my channel.
Then we headed down to Wellsville
Old April 16th, 2019, 06:24 AM   #97
greygoose
Gustafson
greygoose's Avatar
very cool!
Nice new truck btw.
Old June 14th, 2019, 11:32 AM   #98
deathbypsi
Brian R.
deathbypsi's Avatar
Here a cool vid from our club with a lot of footage of Gilligan wheelin with a bunch of Jeeps. Had a great day at BundyHill and just love pushing the truck a little farther each time.
He are some of my favorite stills from the day just because it looks so dam good lol
Similar Threads
XJ: 86 Cherokee 4.0 swap Carbon Jeep Tech 14 September 23rd, 2016 11:07 AM
86 custom deluxe chevy Jnossal47 Rig Builds and Pics 8 September 15th, 2016 08:35 PM
86 Toyota 4x4 22r ,Trans ect. stereoguy Parts for sale 0 September 12th, 2016 11:46 PM
86 toyota ifs steering box hollndr Parts for sale 4 February 23rd, 2016 07:54 PM
86 4runner questions Carbon Toyota Tech 13 September 7th, 2014 09:49 PM
Page generated in 0.58991 seconds with 81 queries
