86 B2 Swapeverydamthing! - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 6th, 2018, 10:23 PM   #21
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Nice watching someone make progress. Looks good.
Sent from my SM-T710 using Tapatalk
Old January 7th, 2018, 05:46 PM   #22
Ready for snofari? Little strap together fun? Lol. Nice progress.
Old January 7th, 2018, 05:48 PM   #23
Speed hut is nice stuff.
Old January 7th, 2018, 06:33 PM   #24
deathbypsi
Brian R.
deathbypsi's Avatar
I cant wait to do another Snofari!
Old January 9th, 2018, 07:31 PM   #25
deathbypsi
Brian R.
deathbypsi's Avatar
Been busy last couple days and I scuffed and cleaned the floors from rear up to where I gotta cut floor pan out and sprayed down bedliner.
I mocked up my bumper ,which needs to be lowered and trimmed off bottom edge of front fenders
and some poser shots with the fresh paint and wheel.....lovin how its lookin.
Old January 9th, 2018, 07:38 PM   #26
koochman450r
koochman450r's Avatar
Looking good
you won this battle.
Old January 10th, 2018, 07:12 AM   #27
Jrgunn5150
Jrgunn5150's Avatar
When I see builds like this I wonder what it's like to have all your poop in a group and work in an organized fashion lol.
Jrgunn5150 is offline   Reply With Quote
Old January 10th, 2018, 08:43 PM   #28
deathbypsi
Brian R.
deathbypsi's Avatar
I have made a few vids of the truck since I picked it up. I decided to take vids of the swap for the hell of it. Might help somebody else down the road lookin to do the same swap.
Old January 11th, 2018, 07:05 PM   #29
deathbypsi
Brian R.
deathbypsi's Avatar
Well today the motor is officially in!
Here is the clearance to the heater box.
And the Canton oil filter adapter is dam close to the steering box but it fits.
So to get to this point I had to throw the James Duff instructions away and figure it out on my own. They want you to measure off existing holes in the crossmember to drill new holes for the v8 mounts. The driver side kinda made sense since there is only one hole for the original motor mount stud. The passenger side however has like 5 different holes and they dont say which one to measure from.
Well after hanging the motor in place I decided to not drill the holes where they wanted them because it looked like the motor would be to far back. On the driver side I removed the track bar mount bolt that went through the original 2.9 motor mount hole and bolted the v8 mount through that hole. Done.
So on the passenger side this is the original mount hole that I assumed they wanted the measurements taken from.
This where their measurements got me and the hole I was suppose to cut.
And instead this is the hole I drilled. Its 2" down and 1" rear of the original hole.
I then slotted it upwards another 1/2" so I could have some wiggle room.
This is where they ended up.
So not where Duff intended I dont think but motor sits in there perfect. The oil pan sumps are centered over the cross member also so we will call it good.
So now this is where I am as of tonite.....
Old January 11th, 2018, 08:03 PM   #30
Old January 12th, 2018, 06:48 AM   #31
koochman450r
Saweet man
Old January 12th, 2018, 11:35 AM   #32
siettas81
siettas81's Avatar
keep it up looks great
siettas81 is offline   Reply With Quote
Old January 14th, 2018, 09:08 PM   #33
deathbypsi
Brian R.
deathbypsi's Avatar
Good day today.
After rolling the axle under truck I could clearly see the engine cross member would need some trimming. Handled that today by chopping off most of the two lower lips then cut a plate out of the old tcase skid plate to box it.
Then I bolted up the arms and started measuring for the frame brackets
Got it on the wheels! Holy shit its tall....but, no interior inside, no trans,no tcase,no bumper,etc. Im sure it will drop as I keep adding more weight to it so no worries. Coils are pretty soft and I can lean on it and drop it 2-3"
Old January 18th, 2018, 02:05 PM   #34
deathbypsi
Brian R.
deathbypsi's Avatar
After a couple days of cutting and torching I got all the rear suspension out of the truck and the Skyjacker Softride leafs with Belltech shackles are in. I cut off the shock mounts and perches off the 9" and right now its hanging up letting the fresh chassis black paint dry.
I also made a discovery. I mentioned above that when I installed the drivers side coil bucket and track bar mount I needed to add a spacer and longer bolts because it looked like Duff hadnt thought about these parts being used together. Well when I was digging through my pile of parts from Ballistic I found one small random bag and when I opened it I found some parts obviously from my Duff pile.
So I want to stand corrected
I also dug out the mustang seats and a center console I have been sitting on for a while that was made for a different project that didnt work out. Looks like it should work nicely in this truck.
Old January 23rd, 2018, 09:19 PM   #35
deathbypsi
Brian R.
deathbypsi's Avatar
I now have all the original fuel system out. Tank sprung like 4 leaks as I was pulling the skid plate and straps. What a mess. 20 gallons of 12 year old fuel and now my shop smells like a meth lab.
Ripped all the lines off too since Ill be replacing them and it makes it easier when I start welding in the new floor pan and rock sliders.
I bought a 90 gas tank and single in tank pump sending unit set up for it. The skid, tank and straps all got cleaned and painted today so they will be ready to go in as soon as I finish the floor pan.
Hope to have floors done this weekend and start installing new fuel system and plump the brakes
Old January 23rd, 2018, 09:28 PM   #36
Knocking it out
Old January 23rd, 2018, 11:05 PM   #37
cannaert
No more Jeep
cannaert's Avatar
Very nice. Love seeing B2 get built up.
Old January 24th, 2018, 06:45 AM   #38
greygoose
Gustafson
greygoose's Avatar
Very cool build!
greygoose is online now   Reply With Quote
Old January 24th, 2018, 07:43 AM   #39
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks good.
Old January 29th, 2018, 10:19 PM   #40
deathbypsi
Brian R.
deathbypsi's Avatar
Slow progress but I have the driver side floor patched up now. Drilled out the spot welds in the braces on the bottom side of the floor pan and removed all of the pinch weld from the tunnel to the A pillar. The new pan didn't cover all my bad spots so I had to hand make a few pieces to get it all.
Just waiting on my order from Eastwood with the seam sealer now
Similar Threads
XJ: 86 Cherokee 4.0 swap Carbon Jeep Tech 14 September 23rd, 2016 11:07 AM
86 custom deluxe chevy Jnossal47 Rig Builds and Pics 8 September 15th, 2016 08:35 PM
86 Toyota 4x4 22r ,Trans ect. stereoguy Parts for sale 0 September 12th, 2016 11:46 PM
86 toyota ifs steering box hollndr Parts for sale 4 February 23rd, 2016 07:54 PM
86 4runner questions Carbon Toyota Tech 13 September 7th, 2014 09:49 PM
Page generated in 0.48415 seconds with 87 queries
