The Taz - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2018, 07:29 PM   #61
JeepHeap
JeepHeap's Avatar
Default Project Heep CJ7
My dad has a friend that owns a salvage yard and found these 17” Ford wheels laying around collecting dust. Hoping to do the DIY beadlocks.
Sent from my iPhone using Tapatalk Pro
JeepHeap is offline   Reply With Quote
Old March 11th, 2018, 07:39 PM   #62
Kegger83cj7
Kegger83cj7's Avatar
Lookin good! Keep up the good work.
Kegger83cj7 is offline   Reply With Quote
Old March 12th, 2018, 11:27 AM   #63
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Those ford wheels will do a good job of narrowing up the full widths.
I may need to look and see if ford made a similar wheel with a 5 on 5.5 pattern like that...
RIP FULLSIZE4LIFE
Old April 18th, 2018, 09:06 PM   #64
Elusive
Elusive's Avatar
Nice job so far guys!
Elusive is offline   Reply With Quote
Old April 21st, 2018, 10:04 PM   #65
JeepHeap
JeepHeap's Avatar
Not much progress since the last update because we have been working on my dads Jeep.
We got the engine bolted in and then got to work making a transfer case cross member.
The steel wheels that we picked up earlier won’t work because they weren’t deep enough for the bolts on beadlocks. When we started looking around for new wheel options, we found a deal we couldn’t pass up thanks to @jeepinjz.
Old July 21st, 2018, 12:56 PM   #66
JeepHeap
JeepHeap's Avatar
Since the last update, we have made some great progress on the front axle. We were offered an unbelievable deal on the milling of my knuckle for high steer, so we took it right away and got it done. The arm is an inch thick. A couple days after the high steer was done, the same guy offered to help us put back together the axle in his shop since he has more experience and a jig made for it. After less than 2 hours of being there, the axle was in one piece and straighter than what it would have been if we tried it.
As soon as we got it home, we started mocking it up. Ending up with about a 109” wheelbase with a 10” stretch in the front and 7” in the rear.
Since it’s so wide, we will be able to get TONS of steering angle.
Old July 21st, 2018, 01:42 PM   #67
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks great!
Old July 22nd, 2018, 07:57 AM   #68
cannaert
No more Jeep
cannaert's Avatar
Looks awesome, can't wait to see more updates and see it done.
Old August 12th, 2018, 07:54 PM   #69
JeepHeap
JeepHeap's Avatar
Began on the front suspension. Got the 3-link mostly in. Mounts are tacked in and links are mounted.
As we suspected, full bump is 3 inches from ride height due to the diff being so big. Due to this, we decided to do tubing for the frame from where the diff starts. With this we should get 3-4” more up travel and hopefully end up with 7” up and 7” down with the 14” shock.
Old August 13th, 2018, 11:14 AM   #70
VAhasnoWAVES
Dirty South
pan hard and LCA mount are going to be tricky.
taking a couple inches out of the casting like artec does for their truss (on the other side) would get you some tube to weld on. consider a truss at that point to help support the tubes. might want to factor that into your full bump.
VAhasnoWAVES is offline   Reply With Quote
Old August 31st, 2018, 10:51 AM   #71
JeepHeap
JeepHeap's Avatar
Realized I never showed the engine in without the cherry picker or how we mounted it, so here’s that.
Old August 31st, 2018, 11:49 AM   #72
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Congrats! There's a special place in my heart for old CJs (I've owned a TON), and I admire your initiative with working hands-on with this build. I'm looking forward to the updates.
EDIT: Wait, you're John's son? Very cool...great Dad, too.
Craig
Old September 1st, 2018, 06:13 PM   #73
JeepHeap
JeepHeap's Avatar
Great progress today on the Heep. Began on finishing the front tube frame and then connecting them in a bumper. After that, we got to work, started by taking off the fenders, then made shock hoops. They turned out okay but not the best. We mounted the air shocks on and put the axle shafts in. We couldn’t get it on all fours yet due no trackbar, so that is next on my endless list of things to do to get this done.
Pictures:
Ride height (the axle isn’t centered):
Full droop:
When we found out that we need a trackbar to get it on all 4s, we noticed that ride height in the back is WAY lower than we thought it was since we have never had it with actual weight on the front. We might have to redo the shock hoops and make them taller to get more up travel now.
Also had a friend stop by and he took us on a ride in his dads CJ2A
Now I need a cruiser Willy’s.
Old September 3rd, 2018, 08:26 PM   #74
JeepHeap
JeepHeap's Avatar
Had some free time today and since we couldn’t get DOM for the trackbar, I decided to go through the wiring harness and label the wires that I could. Just trying to get stuff done while at a stand still until tomorrow.
Had a helpers too.
Old September 4th, 2018, 02:49 PM   #75
JeepHeap
JeepHeap's Avatar
Default The Taz
Well, as you can see, the body of the heep is pretty rusted out, and I’m not too fond of going through and patching every panel. Luckily, something followed us home.
Allegedly, some guy restored it and put a plow on it. On the first trip out, he got hit or it hit something and bent the frame way over in the front. There are a few dents and a little body filler, but no rust. We were going to start dismantling and taking trips out to the trailer Friday and continue working Saturday, but when we got there Friday, it was way better than we anticipated and so we bought the whole thing, and picked it up today.
It’s really nice. It’s got like new best top seats, the hard top is immaculate, and has a rear defrost. All the wires are together and sort of neat, unlike the Heep.
Because of the fact that it isn’t rusted out, we are going to have to make new body mounts on the custom frame, but other than that, we are not really set back at all.
Since it is so nice, we are going to do everything right, and not just do “enough”. Plan is to Rhinoline the interior and the bottom to prevent rust and make cleaning easier, and then paint it. It’s going to take more work, but in the long run it will be much better and I will be a lot happier.
And, because it is clearly no longer a heap, it will now be know as “the Taz” because of this:
Old September 4th, 2018, 03:56 PM   #76
capone
capone's Avatar
Nice score on the tub!
capone is offline   Reply With Quote
Old September 4th, 2018, 08:57 PM   #77
John D
John D's Avatar
Craig
Thanks Craig, we’ve been having lot of fun with the project.
Old September 5th, 2018, 05:08 AM   #78
1x1_Speed_Craig
Simplify...
Nice-bordering-on-weird find on that CJ tub, too. It looks pretty darned solid!
Old September 5th, 2018, 08:28 PM   #79
John D
John D's Avatar
@laxman1306 found it sitting in J&R’s U-Pull-It north of Cedar Springs. We had our fingers crossed for an entire week before we could get up there to snag it and we definitely lucked out this time :)
Rumor is someone did a resto, added a plow and got smashed in the front/side almost immediately!
Old September 6th, 2018, 04:44 AM   #80
1x1_Speed_Craig
Simplify...
Score! (for you, at least...not the plow guy)
Similar Threads
80 cj7 bare bones wheeler project.. Price drop!! **sold** boggin-machine Completed Sales 9 December 1st, 2015 08:58 PM
'79 cj7 project trade for trackick. Lynxer Vehicle Part Outs 11 October 21st, 2015 12:09 PM
Project Jeep 1981 CJ7 r85redjeep Vehicles for sale 4 August 30th, 2015 11:32 PM
1986 Jeep CJ7 Project buzzbrick Vehicles for sale 9 January 18th, 2015 05:06 PM
77 CJ7 project jeep Chevyman3 Vehicles for sale 13 November 17th, 2014 07:12 PM
Page generated in 1.17728 seconds with 87 queries
