Dirt Road CJ7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2016, 10:15 AM   #1
GearDrive
A little slow
GearDrive's Avatar
Default Dirt Road CJ7
As purchased.
Clean frame
YJ tub
4 inch lift
D30 front
D44 rear
No engine/trans/t-case
GearDrive is offline   Reply With Quote
Old July 28th, 2016, 10:17 AM   #2
GearDrive
A little slow
GearDrive's Avatar
Old July 28th, 2016, 10:23 AM   #3
GearDrive
A little slow
GearDrive's Avatar
Stripped down, new floor pans, a few body patches, and ready for paint.
Old July 28th, 2016, 10:27 AM   #4
GearDrive
A little slow
GearDrive's Avatar
Tub painted, 350 Chebby, SM465, NP205 installed.
Old July 28th, 2016, 10:28 AM   #5
GearDrive
A little slow
GearDrive's Avatar
CJ dash installed.
Old July 28th, 2016, 10:32 AM   #6
GearDrive
A little slow
GearDrive's Avatar
Picked up a Warn 8274 for $80.
Old July 28th, 2016, 11:49 AM   #7
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
If the solenoid pack is shot on your steal of an 8274, one thing to look into is moving to a contactor instead of the solenoids. We bought an Albright contactor through Custom Splice and it made it easy to mount under hood and cleaned up the wiring; and seemed to fix our occasional winch outages.
http://www.customsplice.com/electrical-s/136.htm
Old July 28th, 2016, 12:16 PM   #8
GearDrive
A little slow
GearDrive's Avatar
Yes.
I bought one from Warn to put on a M8000.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It wouldn't work when I bought it, that why it was so cheap, I pulled the cover off and it was full of mouse nest and chewed wires. Replaced the wires and it works like normal.
Old July 29th, 2016, 06:27 AM   #9
GearDrive
A little slow
GearDrive's Avatar
It came with a cover too.
Old July 29th, 2016, 06:33 AM   #10
Lousypirate
Whoop Whoop
Lousypirate's Avatar
please find a second one and sell it to me for my willys please.
The Kernel (46 CJ2a)
Mary Jane
Old July 29th, 2016, 06:40 AM   #11
GearDrive
A little slow
GearDrive's Avatar
I'll keep an eye out.
Old July 29th, 2016, 01:02 PM   #12
BearSquatch
Half Bear - Half Squatch
BearSquatch's Avatar
I like it so far! Do you have a plan for whats next or what the end goal is?
BearSquatch is offline   Reply With Quote
Old July 29th, 2016, 02:13 PM   #13
GearDrive
A little slow
GearDrive's Avatar
The end goal is pretty simple, just a back roads cruiser.
No mud or rocks. I have 40 acres with trails thru the woods and hills, near a few seasonal roads. The dunes a few times. And even take the woman out to eat.
I wanted a toy that is between the off road only crawler and the Harley.
Old August 1st, 2016, 12:02 PM   #14
GearDrive
A little slow
GearDrive's Avatar
Had an issue hooking up the power steering pump to the gear box. The gear box has o-ring style fittings, and the pump has inverted flare fittings. They have the same thread, but seal differently. I had some pumps in my spare parts pile, and was able to extract the brass inserts out of the high pressure port fitting. I turned the small diameters down, and pressed them into the box ports. The pump lines now seal properly.
Old August 15th, 2016, 08:07 AM   #15
GearDrive
A little slow
GearDrive's Avatar
Installed new Griffin Radiator and Spal fan.
Old August 15th, 2016, 08:29 AM   #16
bbaXJ
Yooper In Training
bbaXJ's Avatar
I had the same issue when I went to replace the high pressure line on my sister's Nova since it has an 80s Monte Carlo steering box upgrade. After farting around with a bunch of options and adapter ideas, I found these inserts and ordered up a pack. It came with 2 or 3 different sizes and one worked perfectly. http://www.speedwaymotors.com/O-Ring...ter,24682.html
FYI, the O-ring and inverted flare lines do have different threads (SAE vs metric), but they're close enough in diameter and pitch to work.
Old September 19th, 2016, 09:08 AM   #17
GearDrive
A little slow
GearDrive's Avatar
Old September 19th, 2016, 09:12 AM   #18
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Damn looks good...i would make a shroud for the fan, your missing a ton of cooling and it looks like you have plenty of room to push the fan out a little.
Old September 26th, 2016, 05:46 AM   #19
GearDrive
A little slow
GearDrive's Avatar
Trans cover and shifter boots installed.
Old September 26th, 2016, 07:42 AM   #20
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks very clean. Another vote for adding a fan shroud. Doesn't need to be exotic, but it will improve the effectiveness of the fan.
Similar Threads
SOLD-Full Width CJ7 on 35's - $3750 Arnie897 Completed Sales 1 June 16th, 2016 02:46 PM
81 and 85 CJ7, some in between 82cj7ltd Vehicle Part Outs 19 May 16th, 2016 09:42 AM
Cj7 parts mprevo Parts for sale 4 September 22nd, 2015 08:31 AM
jr dirt bike input please Mudking The Pub 50 March 26th, 2015 08:56 AM
1982-ish CJ7, and other CJ parts **SCRAP WARNING** Haggar Vehicle Part Outs 32 October 8th, 2014 12:58 PM
Page generated in 0.54811 seconds with 87 queries
