The Kernel - 46 2a build - Broke Ground 11/27/15 - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2018, 02:42 PM   #161
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Got the back end finished up. Moved it back to start working on the 3 link up front.
The Kernel (46 CJ2a)
Mary Jane
Old February 8th, 2018, 07:21 PM   #162
Lousypirate
Whoop Whoop
Pic dump
Mary Jane
Old February 27th, 2018, 09:44 PM   #163
Wramblerguy
Wramblerguy's Avatar
Why bolt on lower links?
3rd generation jeeper
Old February 27th, 2018, 09:56 PM   #164
Lousypirate
Whoop Whoop
wasn't sure about welding the the diff, so I decided to use some plates and U bolts and weld lower links to those. Not sure how well they'll work, but I figured it was worth a shot?
Mary Jane
Old March 19th, 2018, 07:49 AM   #165
greygoose
Gustafson
greygoose's Avatar
Nice progress so far!! I like the 3800 supercharged V6, something different.
greygoose is online now   Reply With Quote
Old March 19th, 2018, 08:32 AM   #166
I like it.
Old March 19th, 2018, 09:55 AM   #167
Lousypirate
Whoop Whoop
I like it.
I do too, I just need to keep working on it
Mary Jane
Old April 20th, 2018, 07:21 PM   #168
Lousypirate
Whoop Whoop
Found a screaming deal on some 37 MTZs. (Under $1100 for the set delivered from 4wheelparts after discounts and rebate)
Got them and had them mounted on the rims i picked up last year. Rear is on bump stops and front is about 1 above bump stops.
Have a few things to button up on the front end, then its on to cage work.
Also acquired an 8274 in a good trade with a friend
After doing some research and figuring, an 8274 would be the only winch that would mount below the top of the bumper and still give me enough room for the steering box (i hope)
Mary Jane
Old August 30th, 2018, 11:21 AM   #169
srlbotanical
Because I Said So...
srlbotanical's Avatar
Any new progress?
My 48 is officially on the road... I may need to do a drive by one of these days.
srlbotanical is offline   Reply With Quote
Old August 30th, 2018, 12:02 PM   #170
Lousypirate
Whoop Whoop
Originally Posted by srlbotanical View Post
Any new progress?
Still need to hang my steering box and see how the track bar and drag link work out in the front, mount bump stops in the front. Suspension is done other than that. Started working on the fuel cell mount and rear of the tub, progress has slowed due to funding and enjoying summer.
Red truck needs to go so I can get back on this with more exuberance... and funds.
Almost have everything I need for full mock up, just need to spend time on it.
Mary Jane
Old September 20th, 2018, 10:11 AM   #171
Lousypirate
Whoop Whoop
Note to self.
NP231 CV style yoke bolt
Alloy-Steel 12-Point Screw
5/16"-24 Thread Size, 1-1/4" Long
https://www.mcmaster.com/91271a609
Mary Jane
Old September 20th, 2018, 10:23 AM   #172
bbaXJ
Yooper In Training
bbaXJ's Avatar
FWIW, I've got standard hardware store fine thread 6 point hex bolts in mine and they work just fine.
Old September 20th, 2018, 10:23 AM   #173
Lousypirate
Whoop Whoop
Noted
Mary Jane
Old September 21st, 2018, 06:16 AM   #174
redhead_823
redhead_823's Avatar
Originally Posted by Lousypirate View Post
Note to self.
x2 this is what I run
redhead_823 is offline   Reply With Quote
Old March 29th, 2019, 01:49 PM   #175
Lousypirate
Whoop Whoop
After having to take some time off of working on it due to bulging discs in my back, finally getting some work done on it. Steering box mounted, added front bracing, mocked up 8274 location, front bumpstops installed.
rolled it out of the garage to clean up the floor for the first time in ages. Hoping to keep the ball rolling and keep plucking away at what I have in hand already save for some nickel and dime stuff.
Currently gathering parts for my Mary Jane CJ2a build. Thinking about doing all the prep work, then having friends over for a build bash and doing the whole build and assembly in one weekend. Should be an interesting build. This is to get me a running Jeep this spring. Financially, I can get Mary Jane done this spring, whereas the Kernel will take significantly longer (I refuse to hurry this build, build it once, build it right). Mary Jane will be a fun, low slung 2wd setup.
TLDR:
Pictures.
Mary Jane
Page generated in 0.39456 seconds with 71 queries
