The Kernel - 46 2a build - Broke Ground 11/27/15 - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2017, 02:11 AM   #141
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I think this will be pretty close to the rear setup.
Plan to be working on either tearing Mary Jane down and/or working on the Kernel tomorrow afternoon/evening.
The Kernel (46 CJ2a)
Mary Jane
Old March 11th, 2017, 05:39 PM   #142
Lousypirate
Whoop Whoop
Mary Jane
Old March 11th, 2017, 06:32 PM   #143
brown212
brown212's Avatar
Info on the seats?
brown212 is offline   Reply With Quote
Old March 11th, 2017, 07:16 PM   #144
Lousypirate
Whoop Whoop
Originally Posted by brown212 View Post
Info on the seats?
Mastercraft low backs
Bajas? I dont remember, got them used from @sbcrichie
Took a page from @FyrFyr and only put an adjuster on the drivers side
Mary Jane
Old March 12th, 2017, 10:05 AM   #145
FyrFyr
FyrFyr's Avatar
Looking good. Running this summer?
FyrFyr is offline   Reply With Quote
Old April 15th, 2017, 09:50 PM   #146
Lousypirate
Whoop Whoop
Made a truss
Got the rear four link all mocked in, pictures show approximately full droop to about 2" past bump, plan to put bump stops in tomorrow and check full flex then weld everything in.
Pretty happy with today, got some range time on the 22/45 lite and the p320, got some serious time in on my new grinder, and spent some much needed time in the workshop.
Mary Jane
Old April 16th, 2017, 07:16 AM   #147
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Can you get more separation on frame side? I think you will look like a monkey humping a football on climbs with that high of anti squat.
Sent from my SM-T710 using Tapatalk
Old April 16th, 2017, 07:45 AM   #148
Lousypirate
Whoop Whoop
Are you referring to the lowers? I can't move that crossmember any further forward without making it impossible to remove the tcase
Currently sitting at about 18" separation, I'll check my models when i get back to work monday
Mary Jane
Old April 16th, 2017, 07:55 AM   #149
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Frame side uppers higher.
Old April 16th, 2017, 08:05 AM   #150
Lousypirate
Whoop Whoop
I'd have to make a bracket, but those would be the easiest to move, I'll look into it. I had some rough guesses made up, so i just went tacking stuff in
Mary Jane
Old August 9th, 2017, 07:26 PM   #151
Lousypirate
Whoop Whoop
Found a good deal on some rims. Shop truck has been taking precedence, hoping to get back to this soon
Mary Jane
Old August 10th, 2017, 11:40 AM   #152
srlbotanical
Because I Said So...
srlbotanical's Avatar
What do you have as far as the original D41 rear axle? Anything left in your original parts pile that you want to sell?
I've got a 48 CJ2A I'm working on....
srlbotanical is offline   Reply With Quote
Old August 10th, 2017, 12:02 PM   #153
Ryanw10
Ryanw10's Avatar
Would that be the same axle that is under my 49 jeep willys pickup? It's 2 halves that come together in the middle of the pig. I have never seen anything like it but I would be willing to sell the whole axle
Edit: nevermind my axle is a timken axle
Ryanw10 is offline   Reply With Quote
Old August 10th, 2017, 12:24 PM   #154
Lousypirate
Whoop Whoop
sent you a PM.
Mary Jane
Old September 20th, 2017, 09:54 PM   #155
Lousypirate
Whoop Whoop
been spending most of my time with the shop truck or boat this summer, finally decided to move my eBay stuff out of the way for now and do a little fab work.
Need to move the frame side links around yet, have the math figured out from initial mockup. Hoping to tackle most if not all of that tomorrow.
Mary Jane
Old September 20th, 2017, 10:00 PM   #156
Lousypirate
Whoop Whoop
Mocked up a rim in the front due to some concerns, fits tight but beautifully.
Should suck the tires in about 2" around the whole vehicle, will look much better with plenty of turning clearance yet.
Mary Jane
Old September 21st, 2017, 07:12 AM   #157
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
You need more chainsaw carcasses.
Old September 21st, 2017, 08:16 AM   #158
Lousypirate
Whoop Whoop
You have any? Been messing with Homelite chainsaws this summer. I have 4 more not in picture in the workshop, 3 chainsaws that are running in my shed, and 5 more already torn down and parting out currently.
Mary Jane
Old January 7th, 2018, 10:19 PM   #159
Lousypirate
Whoop Whoop
Got the rear 4 link finished up, just need to add the cross bracing for the shock mounts. found a steal on dealer liquidation on 4-12" fox air shocks.
I have been slowly picking up some other odds and ends, and should have most everything to finish the cage and front suspension. I need to figure out what I'm doing on my steering box before i figure my track bar on the 3 link and get all of those bugs worked out. Looking like the shock tower and supercharger will protrude from the hood under an inch if I don't want to space it up. should look pretty cool and keep the overall look of the rig functional.
i also picked up an 88 rx7 to fix up for spring. Motor and trans might go to the other willys project and sell this rust free Cali car as a roller for a v8 swap... unless i really like the car or don't really care for the rotary.
Mary Jane
Old January 7th, 2018, 10:21 PM   #160
Lousypirate
Whoop Whoop
Got my forced air coal heat working excellently now.
Mary Jane
Page generated in 0.64657 seconds with 86 queries
