The Kernel - 46 2a build - Broke Ground 11/27/15 - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2014, 01:46 AM   #41
Wramblerguy
Wramblerguy's Avatar
Originally Posted by Lousypirate View Post
Good to know. Load range c seems like the only one that makes sense. And you're pretty much down to a 35x12.5x15 too get that
Ya load range d are too hard to full size jeeps lol
3rd generation jeeper
Old December 2nd, 2014, 05:41 AM   #42
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Herman has e's on it lol
The Kernel (46 CJ2a)
Mary Jane
Old December 2nd, 2014, 06:51 AM   #43
FORD FLARESIDE
6'-5" 209LB 16YR LEFTWING
FORD FLARESIDE's Avatar
The HumDinger has "E" rated as well.
Old December 2nd, 2014, 08:18 AM   #44
jbsjunk
Little Member
jbsjunk's Avatar
The Jeep had E's on it for a while. It rode like a lumber wagon. Got C's on it and all is well.
Old December 2nd, 2014, 05:40 PM   #45
Wramblerguy
How's that work in the dunes? Lol
Old December 2nd, 2014, 07:19 PM   #46
Lousypirate
Whoop Whoop
Never took it to the dunes on those tires, did fine at R&V this summer.
I kept up with @SRC
Mary Jane
Old December 2nd, 2014, 07:40 PM   #47
SRC
Web wheelin' on a budget.
SRC's Avatar
Indeed. They did very well keeping up with the Yota on BFG Mud Terrians.
SRC is offline   Reply With Quote
Old December 5th, 2014, 12:28 PM   #48
Lousypirate
Whoop Whoop
Planning to pick up a set of waggy axles this weekend
Mary Jane
Old December 6th, 2014, 10:00 PM   #49
Lousypirate
Whoop Whoop
Picked up a pair of waggy axles and a Isuzu rear end with supposed 4.88's for $300 with a set of rims and some rollers.
I'm told they are 4" lift springs for the waggy, but the eye is but off one of the rear leaves if someone is interested before I scrap.
Mary Jane
Old December 6th, 2014, 10:29 PM   #50
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Disc rears only came with 4:10 or 4:30, drum (2 wheel drive) had 4:56? Available
Old December 6th, 2014, 10:34 PM   #51
Lousypirate
Whoop Whoop
That is a little unsettling? I'm going to pull the covers in the am to check all to see where I'm at
Mary Jane
Old December 7th, 2014, 11:41 AM   #52
Lousypirate
Whoop Whoop
Turns out the matched set is 3.31
And the Isuzu is 4.30.
I'll throw my calcs up, but it shouldn't be too bad because my research last night pushed me to an aw4.
Mary Jane
Old December 8th, 2014, 02:15 AM   #53
Wramblerguy
I can't remember if the gm 3.8 is the 60* bell housing or the small block pattern
I assume the 60* and your going to try and find a 2.5 aw4?
Old December 8th, 2014, 04:58 AM   #54
Lousypirate
Whoop Whoop
Yup andyup, just trying to find the bellhousing though. It needs to go behind a more modern aw4 with the 23 spline output.
Mary Jane
Old December 9th, 2014, 02:44 AM   #55
Wramblerguy
Default The Kernel - 46 2a build
Should be prety cool
I assume you will just make the wheelbase as long as necessary?
Are you still planning a d300 just flipped or 231 or 208j or....?
Old December 9th, 2014, 05:31 AM   #56
Lousypirate
Whoop Whoop
Plans are to flip the d300, I like the gear to gear and save about 4" of length. I also want to maintain a twin stick to increase maneuverability.
I will probably move the rear axle back some for a larger cockpit, but that is all tbd.
Mary Jane
Old December 15th, 2014, 11:42 AM   #57
Lousypirate
Whoop Whoop
Playing around with the 4 link.
I'd really like to keep myself to a maximum of 2 different length links so I can carry a spare of each and some spare rod ends (all will be RH thread).
I will be able to dial in once I get the frame built and the front clip set to give me a rear axle location (going to move to give me enough room in the cockpit that way)
The way it's drawn up right now allows for ease of AS% movement up and down and small changes to the roll axis. I need to brush up on my suspension geometry... good thing I kept that book from college. COG will likely be higher, but I'm hoping for a pretty low belly height.
Name:	Theoretical 4 link.jpg
Mary Jane
Old December 15th, 2014, 06:38 PM   #58
bbaXJ
Yooper In Training
bbaXJ's Avatar
The numbers all look good, but I'd try and get a little more vertical separation out of the links at both ends
Old December 15th, 2014, 07:27 PM   #59
Lousypirate
Whoop Whoop
that's what I like to hear. Any rule of thumb to maintain articulation?
Mary Jane
Old December 26th, 2014, 09:21 PM   #60
Lousypirate
Whoop Whoop
http://www.amazon.com/Mbquart-GMR-1-...e+mount+stereo
http://www.amazon.com/Jbl-Prv175-Gau...e+mount+stereo
I thought these were neat and probably would be easy to fit in a small bodied vehicle with a pair of marine speakers
Mary Jane
Page generated in 0.64167 seconds with 86 queries
