F700 build - Page 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2016, 11:31 AM   #381
back woods
It is a BIGGG truck.
Got the new turbo installed and turned the pump up some more.
Words that describe the sound of the turbo...menacing, doomsday siren, ambulance, and get out of my way, run for your life. hahah
Here are a couple videos.
https://www.youtube.com/watch?v=rByNcRsUJ7M
https://www.youtube.com/watch?v=0iyBFYWvRTw
back woods is offline   Reply With Quote
Old June 22nd, 2016, 08:00 PM   #382
Cool Hand Luke
This is awesome.
Cool Hand Luke is offline   Reply With Quote
Old August 24th, 2016, 08:34 PM   #383
back woods
So havent updated in a while. The H2D went out on me a short time after I installed it. So naturally I went bigger and upgraded to the ole 66mm S366. What a fuckin beast, ended up dropping 3 seconds off my 0-60mph from the Hx40. A whole 12mm larger than the stock turbo and it spools instantly. The exhaust housing is a .91AR. The 7.8 could probably even spin a 70mm unit but this is good for now. EGTs climb to around 1200 degrees on a WOT fully loaded pull up a big grade but dont go any higher.
Here is a video running WOT from a stock, gotta love the ole automatic transmission. Sumbitch really moves out.
Also built some ramps so I can get our Gator in the back, works pretty damn good and everything clears good.
Old August 24th, 2016, 08:41 PM   #384
booblinker
Sore and Tired 24/7
booblinker's Avatar
Originally Posted by back woods View Post
So terribly awesome.
Old August 24th, 2016, 08:45 PM   #385
back woods
Also picked up an Excursion for my wife, it is a 2000 7.3 (forged rods) has 220k on it. Pretty clean for a Michigan truck, has some rocker panel rust but nothing that cant be fixed. Installed a 4" turbo back, pulled the SCT transmission killer off it, and installed a set of 285 Cooper ST Maxx tires on it. (highly recommend them)
Our 2008 F450 blew up again in a year and a half (split pistons) and we needed a replacement. Picked up a 2016 4x4 pickup trim F450, pickup trim was the only was to get the 440hp/860tq 4.30 gear model, C&C are all 320hp and we didnt want the de-rated model. Fucker hauls major ass.
Old August 26th, 2016, 12:43 PM   #386
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Nice work!
Old August 26th, 2016, 08:40 PM   #387
alexdummy
gas, grass, and ass
alexdummy's Avatar
You got one hell of a fleet lol.
alexdummy is offline   Reply With Quote
Old November 11th, 2016, 06:18 AM   #388
back woods
Trying to keep this thread updated the best as possible. Got back from out west with the truck. When we got back I went through the brakes, new cans, slack adjusters, and governor. The truck is stopping very good now. Next was a new exhaust system, decided to run dual mufflers. One is a SS 4" and the other is 4" glasspack that I made this past spring. Wrapped the downpipe with heat wrap to keep some heat out of the floor.
Then I towed a logging Forwarder. It was heavy, real heavy. The truck pulled it good but got hot. Ran it up to 230 pulling a grade on 633 in Grawn but never overheated and temps came down on their own. After than I ordered some fans. Two 14" units that flow 2300cfm each. Made some mounts and custom shroud out of rubber. Was also having issues with the air pump running up high PSI. This was adding unneeded heat to the system running all the time. Got that fixed with a new governor.
Been pretty happy with how the S366 has been performing, but there is always room for improvement. Decided to get a billet compressor wheel for. It is a 6+6 wheel where as stock is 7+7. It has a slimmer hub with more blade area, taller blades, weighs less, and larger extended tip exducer. VERY happy with how it performs, it made a noticeable difference. Spools faster, pulls harder, cooler EGTs and it sounds really good.
A couple of videos driving. First one is showing it spool and the 2nd is a pull up to 70mph. Think my lift pump is weak in these videos because it just went out on me yesterday.
Hit 26psi on this run.
Old December 5th, 2016, 06:32 PM   #389
booblinker
Sore and Tired 24/7
booblinker's Avatar
Your truck popped up on my Facebook wall today, something about Alabama mud over snow, weird I don't know you, and live no were near you.
Old December 10th, 2016, 07:29 AM   #390
back woods
That's funny, yeah I spent a couple days in Alabama with the truck. Stuck it in some nasty clay out there but was able to get out with the locker. Bought an air-cooled cooler for the motor oil to help knock down my overall temps when hitting it hard. Truck has been running great though. Need to replace one of the king pins and get an alignment, then on to paint. Very pleased with the truck and I don't baby it at all.
Old April 1st, 2018, 11:57 AM   #391
back woods
Update this thread a little bit.
Started heading north yesterday. Everything was going great until just north or Lexington KY. The fuel rack in the pump stuck wide open. In the rain on I75 it was spinning 4500rpm smoking out the freeway. Got it choked out and stalled. Had to get it towed to the nearest shop for the night. Thought it was the turbo at first but it wasn't. Rack is stuck so far open I can't get the rack plug off. Heading up to Michigan to get a lowboy (I owe some people big) and come back down to get the truck tomorrow. Out off all the shit that could break I never guessed it would be the ppump. Don't think I hurt the motor any, only ran away for about a minute or two.
We made it home. Good Friday and it sure was good. Good friends are hard to come and they saved my ass big time. Was a 1200 mile round trip in a truck that just had a big chunk of money put into it for a rebuild. Was soooo lucky that my friend who was driving our Excursion back was also the driver of the lowboy. I have know him and his boss since high school. He got right on the phone when my truck ran away and got permission to use the tractor and trailer. A few permits later and we were ready to roll. Got back to Michigan from Georgia and left the next morning at 5am. Ran hard back to the 700 and got the tow company to back it on to the low boy.
At the end of the day it is time to retire the F700 from out of state travel. I will get it going again soon but it won't be a camper truck. Love this truck, got it when I was 22 on a work trade. Have ran it for almost 6 years. Two trips from Michigan to Montana, 5 trips to Georgia-Florida, Alabama, and numerous other short trips. No break downs, never over heated, never pulled over by 5-0 and driven WOT all the time. Had a flat tire one time in Alabama that slowed us down for a night. Besides that nothing has ever slowed us down for more than an hour while on the road. This was quite the experience and the most epic break down to date.
Old April 1st, 2018, 12:01 PM   #392
Lousypirate
Whoop Whoop
Lousypirate's Avatar
The 94-96 ppumps had a plunger warp issue if i remember correctly. Same thing happened to my 94. Scary shit. Glad you made it out alright
The Kernel (46 CJ2a)
Mary Jane
Old April 2nd, 2018, 09:41 AM   #393
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Was literally jsut thinking about this thread over the weekend. Say another F700 that made me think of this.
Sad to hear it's retired from full duty, but glad nothign major is broke. Looking forward to some paint in it (if ever) lol
-2011 Ford Fusion SEL 3.0L
-2006 Jeep Grand Cherokee Laredo 4.7L 65th Annv.
-1996 Chevrolet K1500 5.7L Vortec- Dirty mall queen
Old April 2nd, 2018, 10:19 AM   #394
roll-bar Bob
roll-bar Bob's Avatar
I have watched you build this thing over the past few years every one has a bad day from time to time don't jump to conclusions when the wallet is still burning let it cool down and look at all your options
RBB
Old November 14th, 2018, 10:20 AM   #395
roll-bar Bob
And thennn ???
Old November 14th, 2018, 11:44 AM   #396
greygoose
Gustafson
greygoose's Avatar
Originally Posted by roll-bar Bob View Post
And thennn ???
And thennn you house done and you move in!
greygoose is online now   Reply With Quote
Old November 14th, 2018, 11:59 AM   #397
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Two weeks.....
RIP FULLSIZE4LIFE
Old November 14th, 2018, 12:47 PM   #398
greygoose
Gustafson
greygoose's Avatar
Originally Posted by SHARPMACHINE View Post
Two weeks.....
Old December 9th, 2018, 10:12 AM   #399
I love that you checked back in and updated us, keep the updates coming. I love this build. One of my favorites on here.
Old May 5th, 2019, 08:41 AM   #400
Dwysywd
Dwysywd's Avatar
Any news on the f700? Did you retire it?
Sent from my iPhone using a facsimile machine.
Dwysywd is offline   Reply With Quote
Similar Threads
*SOLD*1997 Ford F700 Ridin Dirty Completed Sales 5 November 11th, 2011 11:53 AM
1962 Ford F700 Dump Truck 4x4 DD04WJ Ebay / Craigslist / Auction Links 0 January 6th, 2010 11:47 AM
John's YJ ground up build..Stroked, Stretched, Petted, groomed Koz Off Road build JKOZ Rig Builds and Pics 56 September 19th, 2007 10:18 AM
YJ Build, 5.7L hemi, Dana 60's, coil overs, Koz Off Road current build-Yes another YJ JKOZ Rig Builds and Pics 22 April 17th, 2007 08:13 PM
78 Ford F700 RUSTYSPIKE9 Vehicles for sale 10 February 17th, 2007 04:46 PM
Page generated in 0.52022 seconds with 87 queries
