97 Wrangler TJ 5.3L - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2015, 06:25 AM   #161
Ryanw10
Ryanw10's Avatar
Yep. Stock 4 cylinder tj radiator. Like Collin said when I had the mechanical fan I had zero issues. I could beat the crap out of it on a 90 degree day at silver lake and never get above 210. I now have a random electric fan and I do see some over heating now. Part of it is because I'm not running shroud and I'm pretty sure my fan doesn't push enough cfm. At some point soon I will be buying an aluminum radiator with a built in e fan
Ryanw10 is offline   Reply With Quote
Old August 3rd, 2015, 07:19 AM   #162
If it worked well before the elec fan, why stray away from it?
Old August 3rd, 2015, 08:13 AM   #163
bbaXJ
Yooper In Training
bbaXJ's Avatar
I totally agree. The performance and reliability of a mechanical fan is well worth the 2hp loss you'll never feel.
FWIW, I've been happy with my cheap Summit aluminum radiator. I believe it's built by Northern Radiator. Looks to be identical to the ones Speedway Motors sells.
Old August 3rd, 2015, 08:47 AM   #164
Ryanw10
Ryanw10's Avatar
The mechanical fan limited me to the shitty truck air intake system and the fan rubbed the lower radiator hose. There was no possible effective way for me to reliably and cleanly get the mechanical fan to work. Did it work for the time being? Yes, but I was sick of worrying about rubbing through the radiator hose and I know for a fact I was majorly limiting airflow to the motor
Old August 3rd, 2015, 09:12 AM   #165
Just curious, you didn't list anything negative about it in your previous post. So was curious.
Old August 3rd, 2015, 09:26 AM   #166
Ryanw10
Ryanw10's Avatar
That's my bad then. For now I am just going to fab a shroud up and call it a day. Come winter time I am seriously considering a budget motor build with a mild cam, 4.8 pistons and so on, when I do that I will order up an aluminum radiator with inlet and outlets on the passenger side
Old August 3rd, 2015, 11:44 AM   #167
Ryanw10
Ryanw10's Avatar
I was able to make it up to the dunes this weekend to see how the new tires worked in the sand. My conclusion was I need more power haha. With the bald 35s I could hammer down anywhere and always be able to bounce off the rev limiter. With the new tires I would hammer down and sometimes even lose power. I played around most of the time in 4 low and 3rd gear and still could go anywhere. Couple times I could start from a dead stop halfway up test dump the clutch and just pull myself all the way up slowly but surely. Any farther down the hill then that I would very quickly gain speed moving up the hill. All in all the tires did great
Old August 17th, 2015, 11:07 PM   #168
Ryanw10
Ryanw10's Avatar
Pics from the badlands trip this weekend:
Old August 18th, 2015, 04:08 PM   #169
Ryanw10
Ryanw10's Avatar
Here is what sent me home Sunday. Still have no idea how it happened but whatever haha. I did keep wheeling for a little while like this but every time I would go under water my 8.8 would fill up with water and every time I got off camber I would lose fluid. A little bit of a bummer but I still had a great time and this put me home at a more reasonable time
Old August 18th, 2015, 04:09 PM   #170
mtnbiker995
American
Why didn't you RTV it?
Sent from my XT1060 using Tapatalk
mtnbiker995 is offline   Reply With Quote
Old August 18th, 2015, 04:13 PM   #171
Ryanw10
Ryanw10's Avatar
We had a welder at camp I could have used if I wanted but by the time I got it fixed I would have wanted to leave anyway
Old August 19th, 2015, 07:41 AM   #172
Ryanw10
Ryanw10's Avatar
Had a productive night last night and got the first 3 bars of the cage welded in and the axle tube re welded. I also finished up a toolbox to hold fluids and tools. If you look closely at some of my pictures from the badlands you will see tools and quarts of oil in mid air flying out of the bin I was previously using.
Old August 23rd, 2015, 05:59 PM   #173
Ryanw10
Ryanw10's Avatar
Pit trash shootout was awesome today, but I had the worst luck haha. Before leaving I did a once over of everything and everything was good to go. I get to the Bundy parking lot come to find out I lost a u joint cap and the ear was ovaled out. Threw another cap in and got it tack welded in place with a jump pack and some flux core wire haha. I got through the first half of the course pretty quick and everything was feeling solid and then on the hill climb I twisted an outer stub shaft and was unable to finish. I still got to watch all the buggies go so I wasn't too mad. We left fairly early and on my way home I blew a drive shaft so I had to 1 wheel drive it about a half mile back to my house. (Somewhere in here I snapped my Novak cable shifter too) I can't call today a complete loss though the jeep made it to the comp and back home under its own power still, and I had a blast watching the rest of the competition.
Old August 23rd, 2015, 06:14 PM   #174
Toyfish
Toyfish's Avatar
Wow sounds like I missed a good day of carnage! lol
Sent from my DROID RAZR HD using Tapatalk
Old August 23rd, 2015, 06:20 PM   #175
bradw76
Lots of carnage...
Sent from my SPH-L720T using Tapatalk
bradw76 is offline   Reply With Quote
Old August 23rd, 2015, 06:35 PM   #176
firehawk
Live Action!
firehawk's Avatar
I love the way you beat that Jeep like it owes you $2.
Haha, great show at the Badlands.
Why did a twisted stub put you out? It its not broke you shoudn't know the difference.
Old August 23rd, 2015, 07:08 PM   #177
mtnbiker995
American
By twisted he means twisted it in half lol we thought it was a blown lockout at first but that wasn't the case
Old August 23rd, 2015, 07:10 PM   #178
Toyfish
Toyfish's Avatar
run that bitch in three wheel drive!
Old August 23rd, 2015, 07:11 PM   #179
mtnbiker995
American
We tried, he was caught on the front diff pretty bad
Old August 23rd, 2015, 07:14 PM   #180
Toyfish
Toyfish's Avatar
i have stock stub shafts
Similar Threads
sold - 5 Wrangler 30x9.5 15 Wrangler GSA hase Completed Sales 5 June 25th, 2011 06:51 PM
SOLD:Jeep Wrangler spare tire Goodyear Wrangler RT/S - $25 Big_daddy_75 Completed Sales 0 June 6th, 2010 01:27 PM
1990 wrangler 6 cyl. into 95 wrangler 4 cyl Darkskye19 Jeep Tech 2 March 14th, 2008 09:36 PM
SOLD 4 Stock wrangler rims with Goodyear wrangler GS-A's 30x9.50 15 ryancornell Completed Sales 1 January 28th, 2007 01:59 PM
'80 Wrangler reddeviltj Vehicles for sale 16 November 22nd, 2006 09:27 AM
Page generated in 3.89757 seconds with 87 queries
