My project TJ Bigger, Badder jackstand wheeler - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2019, 09:03 PM   #181
Cool Hand Luke
I'll be watching this to see how you re work your frame as I'd like to do something similar some day
Sent from my SAMSUNG-SM-G930A using Tapatalk
Cool Hand Luke is offline   Reply With Quote
Old June 2nd, 2019, 08:52 PM   #182
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
Started working on this again after doing vacation stuff to Iceland. I need to finish for DOA now since we have a spot for that. Sold a few things and started ordering more stuff to finish this. Just bit the bullet and ordered some KMC Machetes for wheel selection.
Lopped off the rear portion of frame again. Just doing a typical 2x3 and a rear bumper-ish
Going for the Rock Krawler style frame mounts for the links and will do a flat 3/8" aluminum skid. Before my skid was split into a couple pieces along with the cross member. Now it will be the cross member above the skid and a large flat skid with and engine skid to tie into that.
TJontherox is offline   Reply With Quote
Old June 3rd, 2019, 06:07 AM   #183
greygoose
Gustafson
greygoose's Avatar
Very cool!
greygoose is online now   Reply With Quote
Old June 7th, 2019, 08:12 PM   #184
TJontherox
Mall Rated
TJontherox's Avatar
Nothing to add other than the bling that came in this week
Old June 9th, 2019, 06:13 PM   #185
TJontherox
Mall Rated
TJontherox's Avatar
Got some time with the plasma cutter and used my cardboard cad pieces to make templates for my outer frame side brackets. Now I need to make the inside frame mount and cut off some of the old stuff for the new stuff to work.
full stuff
Track bar will be a bit of a challenge
Old June 15th, 2019, 05:03 PM   #186
TJontherox
Mall Rated
TJontherox's Avatar
My frame rail is .25" wider than it should be due to the upper link bracket assembly I made years ago, s I butt welded the new inner lower bracket to the bottom of the frame and then made a weld washer to extend onto the frame. The weld washer stops a little past where the tube is on the back side of the other plate.
Front lower inner
Front lower
Front lower again
Trans cross member. This allows me to have a flat belly skid that can be removed without removing the cross member
Old June 17th, 2019, 06:19 AM   #187
greygoose
Gustafson
greygoose's Avatar
Lookin good!
Old June 19th, 2019, 08:21 PM   #188
TJontherox
Mall Rated
TJontherox's Avatar
Originally Posted by greygoose View Post
Lookin good!
Thanks!
Probably doing something like this with the cage/shock tie in. May ditch the piece from the frame up to the cage though, or flip it to be behind the shock and tie into the C pillar mount down to the frame. Or move the axle mount for the shock to front side of the housing, moving it forward in the wheel well and making it almost exactly like the one pictured.
Horizontal tube will have a bend to meet B pillar and the other 2 tube and shock will meet at the bend
Looking to do similar to this
Old July 13th, 2019, 09:42 PM   #189
TJontherox
Mall Rated
TJontherox's Avatar
Got to spend a little time cutting and bending for my rear bumper
Also got a couple tubes bent for rear shock mounts
Old July 15th, 2019, 08:37 PM   #190
TJontherox
Mall Rated
TJontherox's Avatar
More rear bumper pics
Old July 15th, 2019, 09:29 PM   #191
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Do you plan to trim the body corner by the bumper? Feel like it's inevitable that the corner gets bent there
Sent from my SM-G960U1 using Tapatalk
Mihlfeldl2005 is offline   Reply With Quote
Old July 16th, 2019, 06:52 PM   #192
TJontherox
Mall Rated
TJontherox's Avatar
Propbably will just for looks. With a stretch and 42's my tires are past the bumper anyway, so it would be a special something to hit that little corner.
Old July 16th, 2019, 08:30 PM   #193
Mihlfeldl2005
Fair enough
Old July 21st, 2019, 03:19 PM   #194
TJontherox
Mall Rated
TJontherox's Avatar
Old August 20th, 2019, 07:26 PM   #195
TJontherox
Mall Rated
TJontherox's Avatar
Old August 21st, 2019, 05:43 AM   #196
greygoose
Gustafson
greygoose's Avatar
Awesome to see you got her out on the trail!
Old August 21st, 2019, 07:29 PM   #197
TJontherox
Mall Rated
TJontherox's Avatar
Thanks! I had a lot of 2-3 hours per night of sleep to get it done for Drummond and it paid off and worked awesome
Similar Threads
Project Guinness (Finished pics, page 8) Monkeyevil Rig Builds and Pics 207 November 4th, 2011 01:59 PM
Newest project: Make Moffett fit on 48' Fruehauf *Finally finished!!* dune coon Pictures and Video 46 February 24th, 2009 12:50 AM
YJ project: solid body/frame, Chevy V8, 700R4. needs finished 2kids=nojeepmoney Vehicles for sale 0 July 2nd, 2008 05:33 PM
latest work project - finished - *new pics* dune coon Pictures and Video 23 November 30th, 2007 06:38 AM
Jeep CJ-10a conversion project (pretty much completed) 1x1_Speed_Craig Rig Builds and Pics 167 September 4th, 2007 08:47 AM
Page generated in 0.61344 seconds with 77 queries
