Project Bo0sted - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2019, 06:32 AM   #141
roll-bar Bob
roll-bar Bob's Avatar
Do you hear that ??? I think the track is calling you might want to reassemble soon
RBB
roll-bar Bob is online now   Reply With Quote
Old April 14th, 2019, 09:23 AM   #142
I've been slacking a bit, got laid up with some health stuff that left me sidelined for a bit. But managed to get the car back together enough to get it out of the garage.
2019-03-13_08-28-14 by Cheapthrillb2, on Flickr
swapped water pumps for a more desired inlet location. and relocated my catch can.
20190319_182907 by Cheapthrillb2, on Flickr
Got my new wheels and tires and in. I like how the rear looks but not so much on the fronts. 20x10 295/40-20
20190319_182856 by Cheapthrillb2, on Flickr
20190319_182843 by Cheapthrillb2, on Flickr
IMG_20190402_115547_952 by Cheapthrillb2, on Flickr
I also picked up a new engine management system. I used hptuners on it before and still use hp tuners with my jeep. But i liked what i seen with this new holley system so thought i'd give it a go.
20190406_192715 by Cheapthrillb2, on Flickr
scabbed together the exhaust.
20190405_100750 by Cheapthrillb2, on Flickr
Got the 4l80 back from "my guy" ready for a yr of beat downs.
20190413_174525 by Cheapthrillb2, on Flickr
20190413_163803 by Cheapthrillb2, on Flickr
And finally outside, now to get that holley figured out and get in the 10's.
Old April 14th, 2019, 07:32 PM   #143
green50gt
Got rocks?
green50gt's Avatar
I almost asked where you were! Hope you are feeling better!?
I heart Jeeps
green50gt is offline   Reply With Quote
Old April 15th, 2019, 08:33 AM   #144
Take some weight out of the tank and it'll run 10's easier haha
Old April 30th, 2019, 07:52 PM   #145
A$$ end shot a week or two ago.
20190420_065153 by Cheapthrillb2, on Flickr
This year I switched from the stock ecu and hptuners to the new Holley Terminator MAx setup. So learning new software. Well made a big mistake/overlook. We had adjusted the ign timing, then started working on the target afr tables. I had to rescale my map table for afr and when I did that it gave me a popup window I misunderstood. So loaded the tune and went for a spin. What that popup was saying without actually saying it, was that it had also re scaled my timing tables. So I didn't catch the change in the timing. I went out to watch the afr, hit 11psi and noticed my timing was way off. But it was to late. Hit 36 degrees where I would normally hit around 10-12 degrees. Unfortunately damage was done and two pistons gave it up.
Messed up part was it really didnt act up. No smoke, didnt feel rough etc. I actually put about 50 miles on it including some 5-6psi hits on it before i started hearing the engine make noise.
Cyl7 plug
USER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_155623 0331122.jpg_1556230332626 by Cheapthrillb2, on Flickr
cyls 5 and 7
20190425_193250 by Cheapthrillb2, on Flickr
#7
20190427_083333 by Cheapthrillb2, on Flickr
#5
20190427_083337 by Cheapthrillb2, on Flickr
So I picked up another motor friday at work, 90k for $900 complete drop out. Had the old one out friday night. I had to swap the cam and valve springs from the old to the new. Was really happy how clean the inside of the new/used motor was.
2019-04-30_07-48-45 by Cheapthrillb2, on Flickr
20190426_202533 by Cheapthrillb2, on Flickr
20190427_083329 by Cheapthrillb2, on Flickr
Old April 30th, 2019, 07:52 PM   #146
swapping valve springs
20190427_083320 by Cheapthrillb2, on Flickr
swapping cam
20190427_093747 by Cheapthrillb2, on Flickr
I always install a pick up tube support, common issue with that oring on LS.
20190427_112230 by Cheapthrillb2, on Flickr
decided to paint some of the bolt ons blue.
20190427_142127 by Cheapthrillb2, on Flickr
20190427_143439 by Cheapthrillb2, on Flickr
Now its in and running as of Sunday morning. But haven't had the opportunity to go out, been raining and cold everyday. but hoping friday and saturday look good
Old May 1st, 2019, 07:17 AM   #147
roll-bar Bob
you have been a busy Man
I hate it when I teach myself expensive lessons
RBB
Old May 12th, 2019, 09:28 AM   #148
Added e85, need to do some testing to see if my pump is enough to support it at peak. So far seems to be alright. But Warlboro has a new bigger pump, might just switch to it regardless. and tune as needed with that pump, if have to hold the tune back a little if its not 100% up to it. I dont want to run two pumps.
20190509_170744 by Cheapthrillb2, on Flickr
20190509_203742 by Cheapthrillb2, on Flickr
I need to buy a real camera and learn how to take real pics, not just phone pics.
20190501_202555 by Cheapthrillb2, on Flickr
https://youtu.be/41BXjIwVCZc
First clip was very early on this year. I hadnt got the trans setup yet and you can hear from the quick 1-2 shift.
Second clip, I believe is when I hurt the motor. I noticed at the tail end my timing was way to high. and right after I could smell oil. Blew the knock sensor seals and the frt crank seal. The crank seal didn't 100% blow out. The balancer kept it in just enough it couldn't completely blow out and dump oil everywhere.
Third was the other night, took a buddies FIL for a ride. New 295/40 toyos hook way better then the oem size coopers I had on last year. OEM size coopers never stood a chance when the boost came in.
Hoping to get to the track this week either Wednesday or Friday evening for test and tune.
Old May 13th, 2019, 08:48 AM   #149
green50gt
Got rocks?
green50gt's Avatar
Nasty. Love it John!
I heart Jeeps
Old May 19th, 2019, 08:50 PM   #150
Well visited the track last week. Wasn't as great of a performance as i had hoped for. Seems i cannot hold the car as well now to launch as i was last year. I upgraded to Mustang rotors and corvette calipers. I'm pushing through the brakes before i can build boost to launch. Last year i could build 2-3psi and launch. Braking feels good coming to a stop and i have good firm pedal. I wonder if going to larger front calipers but not increasing master cylinder size is the cause.
First run, i went to stage and ended up pushing through the beam when i wasnt expecting so my time was terrible.
We turned up the boost, maxed out my controller with the 5psi wastegate spring. Looks like with that spring the controller maxes out at 17psi. What i didnt realize, is that when the controller maxes out and i hit that psi, it defaults to spring pressure. So i hit 17psi and the wastegate opened and didnt close till 5psi. So the car fell on its face during the pull. Which was fine, cause reading the logs its obvious i need more fuel pump at peak load as it was falling short.
You can hear at 48 seconds.
https://youtu.be/wRrTd5BoDrM
Didn't get another opportunity to run anyway. A guy blew his motor and oil misted 3/4 of the track.
20190515_191730 by Cheapthrillb2, on Flickr
20190515_194441 by Cheapthrillb2, on Flickr
cool shot a buddy got.
20190517_181918 by Cheapthrillb2, on Flickr
Hoping to get the two step launch control figured out with the holley and go back after i improving my fuel delivery.
Added a logo light under light underneath that turns on with interior lights.
2019-05-19_08-16-08 by Cheapthrillb2, on Flickr
Old May 20th, 2019, 06:53 AM   #151
bad ass! Glad she's back on the road / track.
Old June 2nd, 2019, 06:04 PM   #152
Well, I ordered a new clamp for the intercooler boot at the turbo itself, wasn't a great clamp setup I had at that spot. Well 19 psi was all that clamp was good for lol. I ment to change it this morning. But forgot. Changed now.
Installed new fuel pumps. Dual walbro 450s in the tank. Didn't fit real well lol. Kinda a pain to install. But in and working. Between those and the 1500 cc injectors I have allz the fuel now. Turned it up to 19 psi on about 79% e. New turbo is working really well. Still working on launch control via the tune. Hopefully I'll get to the track Wednesday or Fridays test and tune and get a better run in then last time. I have no doubts I will lol,we figured out all the boost cut issues I was having last time. Not only was my boost gauge/controller cutting me off but I didn't realize in the tune we had setup ignition cut at 18psi from when I was running pump 93.
I also added an external battery switch per the track tech guys. I installed a hitch on the car, and mounted the switch to a receiver. Pulled a trunk plug in the floor and ran wires via a quick disconnect through floor to switch for while I'm at the track, not at the track pull reciever and wires and reinstall trunk plug.
Old June 3rd, 2019, 06:24 AM   #153
Good thinking! My FIL has a Trans Am that ran a 10.60 in the 1/4 and they told him he needed a cage and a battery disconnect. He didn't want to cut a hole in the bumper so he doesn't run at the track anymore. I like this idea!!
Old June 3rd, 2019, 08:46 AM   #154
Needs moar 2 step...............
Old June 5th, 2019, 12:52 PM   #155
Needs more TC lol. Or a trans brake.
https://youtu.be/yiAqnT-QfHE
Old June 5th, 2019, 03:16 PM   #156
green50gt
Got rocks?
green50gt's Avatar
Gosh I wish I had that problem.
I heart Jeeps
Old June 6th, 2019, 12:37 PM   #157
It's 4800 lbs, it needs to lose weight!
Old June 6th, 2019, 01:08 PM   #158
That is a heavy car.
Old June 6th, 2019, 02:41 PM   #159
Blaspheme, big girls can party to.
Samurai based buggy project - PRICE DROP ! Geezer Vehicles for sale 7 September 26th, 2016 09:04 PM
LS V8 99 TJ wrangler PROJECT (reading heavy) bjlindell Vehicles for sale 12 July 1st, 2016 06:34 PM
1988 Toyota 4x4 Project Siegzook Vehicles for sale 4 July 20th, 2015 12:53 PM
79 F150 Project, Rockwells, Needs GONE Lilmuddy Vehicle Part Outs 7 June 10th, 2015 08:20 PM
1988 Suzuki samurai Project - DELETE PLEASE!!! ericeclark Vehicles for sale 7 August 24th, 2014 07:53 PM
Page generated in 0.60039 seconds with 85 queries
