Dirt Road CJ7 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 26th, 2016, 11:18 AM   #21
GearDrive
A little slow
GearDrive's Avatar
I assume you guys mean a complete core coverage shroud. The spal fan has a “shroud” that fits tight against the core. The effective ness of the fan is debatable, and I understand your concern. The fan is rated at 2024cfm, and 16” diameter. Am I getting full velocity from the fan? Probably not, due to the restriction of the core. Now 100% of the air flow from the fan is within the 16” circle. Is this enough to cool a mild SBC at slow speeds? For my intent of use for this vehicle, so far, yes.
Now say I Build a full coverage shroud, and move the fan back 1”. I can now obtain full velocity of the rated flow. I’m going to guess that 80 % of the flow will be within the 16” circle. The other 20% distributed to the rest of the core, gradually decreasing from the 16” circle. By the time you get to the corners of the core, the air flow is minimal. That is, of course, if I get no air gaps fabricating a full shroud.
Gains at slow speeds from no “shroud” to full shroud: My opinion, 0
At higher speeds, having the core open in the corners, allows natural air flow to enter the core without restriction. With a full shroud, there is a restriction to not allow natural air flow.
Gains at higher speeds from “no shroud” to full shroud: My opinion, negative gains.
And now boys and girls, some real life experiences.
1) The same setup on my crawler, but with a 500 ci engine. Sees a lot of slower speeds. No problems
2) ’83 Chevy crew cab, tow rig, 500 ci engine, stock rad, dual electric fans, minimal shroud. No problems
3) ’88 MJ 4.7 stroker, Stock cooling system. Half of radiator core open. No problems
4) ’76 Corvette, Big block, aluminum heads, 3 row DeWitt’s aluminum rad. Dual electric fans, FULL shroud. Experiencing problems.
GearDrive is offline   Reply With Quote
Old September 26th, 2016, 12:05 PM   #22
GearDrive
A little slow
GearDrive's Avatar
Another “shroud” experience.
I have an outdoor wood furnace, and use it to heat my shop also. I built the heat exchanger out of an automotive radiator, old washing machine, and squirrel cage blower from a furnace.
The blower is about 10” away from the rad. Even with a shroud that completely contains the core, I only feel the majority of the air flow directly from the blower, not spread out across the whole core.
Old September 30th, 2016, 12:36 PM   #23
My real life experience was that shroud made big difference; but to each their own.
Old September 30th, 2016, 12:56 PM   #24
GearDrive
A little slow
GearDrive's Avatar
Did you go from absolutely no shroud to a full shroud?
Or from a minimal, circular shroud like mine, to a full shroud?
Old October 3rd, 2016, 06:22 AM   #25
GearDrive
A little slow
GearDrive's Avatar
I did a test on the fan.
Old April 4th, 2017, 10:14 AM   #26
GearDrive
A little slow
GearDrive's Avatar
Old February 25th, 2019, 05:58 AM   #27
GearDrive
A little slow
GearDrive's Avatar
Almost done
Old February 25th, 2019, 07:20 AM   #28
Looking good!
greygoose is online now   Reply With Quote
Old February 25th, 2019, 07:47 AM   #29
mtnbikinbryno
mtnbikinbryno's Avatar
Send a message via AIM to mtnbikinbryno
Originally Posted by greygoose View Post
Looking good!
Hell yeah!
mtnbikinbryno is offline   Reply With Quote
Old March 29th, 2019, 01:10 PM   #30
GearDrive
A little slow
GearDrive's Avatar
My door panels were shity. So I filled the openings with tread plate.
Old March 29th, 2019, 01:53 PM   #31
I would imagine a lot of it had to do with the distance from the radiator. the mounting flange of the electric fan creates a shroud.
Electric fan, not necessarily a big deal as long as you can get the cfm large enough to counter the temp difference coming from the engine.
Mechanical fan, big difference.
Yes, I know the post is from 2016.
Mary Jane
Lousypirate is offline   Reply With Quote
Old April 2nd, 2019, 09:41 AM   #32
Jrgunn5150
Jrgunn5150's Avatar
This is awesome, dirt simple and easy, I love it.
Jrgunn5150 is offline   Reply With Quote
Old August 27th, 2019, 07:38 AM   #33
GearDrive
A little slow
GearDrive's Avatar
Just need to mount my 8274.
Old August 27th, 2019, 07:57 AM   #34
Looks great!
Old August 27th, 2019, 07:21 PM   #35
Kegger83cj7
Kegger83cj7's Avatar
Nice clean ride.
Kegger83cj7 is offline   Reply With Quote
SOLD-Full Width CJ7 on 35's - $3750 Arnie897 Completed Sales 1 June 16th, 2016 02:46 PM
81 and 85 CJ7, some in between 82cj7ltd Vehicle Part Outs 19 May 16th, 2016 09:42 AM
Cj7 parts mprevo Parts for sale 4 September 22nd, 2015 08:31 AM
jr dirt bike input please Mudking The Pub 50 March 26th, 2015 08:56 AM
1982-ish CJ7, and other CJ parts **SCRAP WARNING** Haggar Vehicle Part Outs 32 October 8th, 2014 12:58 PM
Page generated in 0.42739 seconds with 73 queries
