Compression fittings on fuel lines - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > General Tech
Old April 28th, 2019, 12:39 PM   #1
welderman85
Member
Default Compression fittings on fuel lines
Hello all. I'm trying to get my old Ford ranger back on the road. It had a fuel line that was leaking. I have checked ever junkyard that I know of for the part and i can't find a new one anywhere. So I would like to use a compression x barb fitting with a little bit of fuel injection hose to fix it. Is it safe . Thank you
welderman85 is offline   Reply With Quote
Old April 28th, 2019, 12:46 PM   #2
welderman85
Member
I though about making new lines out of nylon line but I don't know how I would keep them from rubbing on the the frame rail.
Old April 28th, 2019, 02:49 PM   #3
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
P clamps?
Sent from my SM-G960U1 using Tapatalk
Mihlfeldl2005 is offline   Reply With Quote
Old April 28th, 2019, 03:19 PM   #4
welderman85
Member
Not sure what a p clamp is these have a nut and feral you tighten down
Old April 28th, 2019, 03:38 PM   #5
Mihlfeldl2005
My bad, thought you were talking about making all new line out of nylon not just wrapping the bad spot with it. The new line idea would be my go to. You don't want to screw around with fuel leaks. P clamps can be used to mount the new line to the frame rail or body once ran. The make them in all different sizes.
Old April 28th, 2019, 06:57 PM   #6
welderman85
Member
Thank you I didn't even think of those clamps to hold it down. I do have one more dumb question. I have the correct fittings and even had some of the nylon line. How dose it hold up to heat. This line comes off the frame heads toward the engine bay
Old April 28th, 2019, 07:06 PM   #7
welderman85
Member
Also what's the easiest way to post pics
Old April 28th, 2019, 07:07 PM   #8
Mihlfeldl2005
Tapatalk in my opinion. Worth paying for if you use forums frequently.
The nylon line handles heat pretty well, just don't lay it on the exhaust manifold and you'll be all set.
Old April 28th, 2019, 07:12 PM   #9
welderman85
Member
Ok great. One more dumb question what is the trick to using that nylon. I tried but couldn't get it on. Also do you put clamps to hold it on once I get it there and once again thank you for the help
Old April 28th, 2019, 07:43 PM   #10
Mihlfeldl2005
Check out YouTube. There's some videos on there. Are you using AN fittings?
Old April 28th, 2019, 08:09 PM   #11
welderman85
Member
No AN. The lines run from the filter to the spring disconnect things Ford us5
Aeromotive Y fuel block 15672 -6 fittings Bones Parts for sale 0 March 22nd, 2017 09:02 AM
High Compression on #6 - 2007 LS 5.3L Active Fuel Management Delete srlbotanical Chevy Tech 6 February 13th, 2017 10:03 AM
YJ Fuel lines Gunsworth Wanted 0 February 1st, 2016 08:53 AM
Tj fuel lines bigbchevy Parts for sale 2 April 12th, 2015 07:50 PM
Compression fitting on fuel pump? bbaXJ General Tech 20 April 10th, 2015 01:41 PM
Page generated in 0.33770 seconds with 59 queries
