Project CJ in a Tj (full width axles coilover 3link and more) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 27th, 2017, 09:44 AM   #1
cj7on44's
cj7on44's's Avatar
Default Project CJ in a Tj (full width axles coilover 3link and more)
I figured it's time I make a build thread on my jeep. Little back ground on me, my initials are cj and that's what my friends and family call me. this is the 6th wrangler I have owned I have had cj5 cj7 yj and 3 tj's along with a hand full of other jeeps. I have been wheeling since I was 14 I had a 2 door 5 speed strocker xj on full widths I wheeled for 6 or so years. I parted ways with it in 2014 to build a 74 bronco which was sold before I got to wheel it in 2015 I had a ranger I was building when I came across this tj... on to the pictures
I started with this I traded a ranger I was daily driving for it I had $1100 in to the ranger 4.0 auto
I got it home and started working on it found out frame and body were going to need a lot more work than I was expecting floors were shot all the way to the seat mount as well as all body mounts not to mention the skid plat was sheet metal screwed and welded on.
So I picked up a nice body and frame had a anti rock corner guards and a 4" lift
Got it home cleaned and painted frame and engine bay and started swapping all the parts over
Had it running and driving in about 6 days
Picked up some 36" swamper sand started building my front fenders and bumper
After About 3 weeks of work I took it to silver lake sand dunes the first week of July for 9 days of playing
That brings us current finished my fenders last night and added lights
cj7on44's is offline   Reply With Quote
Old July 27th, 2017, 09:49 AM   #2
cj7on44's
cj7on44's's Avatar
Future plans included a stretch and a trussed hp dana 44 from 3/4 f250 and a 9" rear 3 link with coil overs up front
Old July 28th, 2017, 06:49 AM   #3
cj7on44's
cj7on44's's Avatar
Got a couple things done last night I finished wiring my winch up all the controls are in the cab now. The solenoids are under the hood. I need to pick up a fair lead for it but it is there if I have to use it for now
Old August 17th, 2017, 08:53 AM   #4
cj7on44's
cj7on44's's Avatar
Well started my axle swap last Wednesday and it didn't go as planned... I took a upper control arm to the face 8 stitches and 3 days off work
I now have the new front axle under the jeep moved it forward 4" some time in the next week I will get the links tacked in place and cycle everything. I ordered a bracket kit for my rear dana 60 so I will be starting that soon also
Old August 19th, 2017, 09:30 AM   #5
cj7on44's
cj7on44's's Avatar
I was finally able to get out and do a little work on my tj last night got my axle set at full bump and lowers tacked in to place and started working on the upper at full bump the axle truss just touches the lower radiator hose. The links are all 2X.25 wall dom 38" long 1 1/4 hemis
Old August 19th, 2017, 12:14 PM   #6
capone
capone's Avatar
Man that's a nice gash above your eye. I will following you build I want to do the same axle swap in my TJ.
capone is offline   Reply With Quote
Old August 20th, 2017, 11:09 AM   #7
cj7on44's
cj7on44's's Avatar
Haha yeah it was a good one still getting headaches from it. Not sure if you have ever heard of TNT customs they have a nice truss for the dana 44
Old August 20th, 2017, 11:49 AM   #8
cj7on44's
cj7on44's's Avatar
Got my upper link mount tacked in need to get my shock mounts built
Old August 23rd, 2017, 08:01 AM   #9
cj7on44's
cj7on44's's Avatar
Well got my track bar tacked in last night at full bump it barely clears
Also got the brackets for my rear yesterday
Old August 24th, 2017, 12:28 PM   #10
cj7on44's
cj7on44's's Avatar
Well I flex everything out and didn't have any binding so I fully welded the brackets in place. Now I'm waiting on parts for my plasma cutter so I can cut my old mounts off and do my c/o mounts also threw the wheels on and I really need to find some h1's
This is with a stock h1 I just need 3 more
Old August 26th, 2017, 07:19 AM   #11
cj7on44's
cj7on44's's Avatar
Well started clean I g up my new rear axle last night then I ran out of grinding wheels and cutoff wheels but I got my link brackets tacked in place. Today I plan to pick up a couple wheels and get the old leaf perches cut off. Then fully weld all the link brackets
Old August 30th, 2017, 12:41 PM   #12
cj7on44's
cj7on44's's Avatar
I got all my brackets fully welded I still need to cut the leaf spring perches off but the parts for my plasma cutter will be here today so that should make thing easier. I also got my original rear axle pulled and the jeep is ready for the new axle.
Stock arms for now I plan to 4 link the rear and build my 609 this winter along with a v8 swap
Old September 3rd, 2017, 11:52 AM   #13
cj7on44's
cj7on44's's Avatar
Got the jeep sitting on its own weight now I just need to order the correct springs for the coilovers finish the steering brake lines rear shocks
Old September 11th, 2017, 01:08 PM   #14
cj7on44's
cj7on44's's Avatar
Well I got to drive the jeep around my yard a little still need to order springs and shocks and a few other things but at least I can move it now I also picked up a new power plant for it
Old October 6th, 2017, 11:04 PM   #15
cj7on44's
cj7on44's's Avatar
Well I finally had a little time to work on the jeep got the brakes plumbed and bled still needs a little more bleeding but stops better than it did before the axle swap. Also got the rear drive shaft in its closer to its maiden voyage with the stretch and swap.
Old October 17th, 2017, 02:10 PM   #16
cj7on44's
cj7on44's's Avatar
Well I got my rear shock mounts built opened up my rear fenders and moved my flares back slowly working on it
Old November 11th, 2017, 11:07 AM   #17
cj7on44's
cj7on44's's Avatar
Got my barn floor and approach pored I added 4 chains in the floor for pulling frames and other things. Got the jeep back to my barn and getting ready to start the v8 swap
At the urging of my little boy we went out back on our property to “run stuff over”
Old November 12th, 2017, 07:28 AM   #18
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks good
Sent from my SM-T710 using Tapatalk
JohnnyJ is online now   Reply With Quote
Old November 15th, 2017, 07:25 AM   #19
cj7on44's
cj7on44's's Avatar
Well I started my v8 swap Sunday I pulled the 4.0 sold it Monday and got the motor sitting where I want it last night on to some mounts shifters and wiring
Old November 20th, 2017, 10:27 AM   #20
cj7on44's
cj7on44's's Avatar
Been working on the wiring slowly
Similar Threads
2000 TJ 1 Ton Project *SOLD* Bleay Vehicles for sale 9 January 22nd, 2018 01:11 AM
LS V8 99 TJ wrangler PROJECT firehawk Vehicles for sale 19 August 2nd, 2017 02:23 AM
98 TJ project SOLD Nitrodave Completed Sales 17 February 8th, 2017 03:07 PM
LS V8 99 TJ wrangler PROJECT (reading heavy) bjlindell Vehicles for sale 12 July 1st, 2016 07:34 PM
TJ flares on a CJ with rock sliders alumitub78 Jeep Tech 7 June 11th, 2015 06:26 AM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 1.36832 seconds with 86 queries
