LS Powered Jeep Willys Pickup - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2018, 09:18 AM   #121
Ryanw10
Ryanw10's Avatar
I had an idea over the weeked...a full float high pinion dana 44 rear axle.
The Ford 9" that I thought I might use in this build is now getting repurposed for use in my wrangler, and it just hit me that I potentially have almost everything to make a rear hp44 minus axle shafts.
My concern is strength. I will use 4.10 gears and the way I understand it this ratio is one of the strongest. Next concern would be locking hubs/drive flanges, the axle would start off with a welded diff, probably a Yukon grizzly or equivalent down the road. This truck will not see bigger than 35" tires and the motor will make an estimated 400 hp and be pushed through a built 4l60e.
Thoughts/conerns?
Ryanw10 is offline   Reply With Quote
Old April 2nd, 2018, 09:29 AM   #122
roll-bar Bob
roll-bar Bob's Avatar
build it if you break it build it stronger
Words to live buy
RBB
Old April 2nd, 2018, 12:40 PM   #123
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I don't think a HP44 would last long in the rear end. I think the R&P would be the weak link.
Old April 2nd, 2018, 01:00 PM   #124
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Ryanw10 View Post
I'm going to disagree with you but I will hear you out and I will be open to others opinions as well.
I was for sure planning on a bushing to isolate the tank from the mount, but unless convinced otherwise I do not agree with opening the hole up. I get that the frame flexes but if I have the radiator mounted only by the tanks, won't the radiator core absorb frame flex?
I could be way off but that is my train of thought. I made these pucks but wide open design sells basically the same thing and it looks to me like they mount them to there frames the same way I did, it actually looks like they don't even use a bushing at all.
Their mount is a completely different application though. Theirs is mounted to a single bar in a tube chassis. There is less flex and deflection in a heavily braced tube chassis to begin with, and attaching both sides to the same cross-car beam reduces that even more. Short of severe damage, their mount will see very little torsion or movement. Yours is mounted to the opposing frame rails, which get drastically more twist than their setup. Plus theirs basically just has locating straps hanging the radiator, and probably a cradle at the bottom. They're locating it more than actually mounting it. Yours has structurally braced brackets locking it to flexible frame rails.
The way you have yours mounted, anytime the frame flexes/twists it will be torqueing those bolts up and down, putting a bending moment on the bolts and into the pucks. Over time it will fatigue crack the brittle HAZ areas on the radiator around the welded on pucks.
Using bushings with shanks to pass through oversized holes in the brackets(think OEM Jeep body mounts) will allow the bushings to take up most of the bending moment and keep the stress off your radiator tanks. If you can't find bushings like that you could even use standard rubber pucks to sandwich the brackets and some thick wall hose to sleeve between the bolt and oversized hole.
Something like this but with a better temperature rating:
https://www.mcmaster.com/#bushings/=1c8nwpc
Old April 2nd, 2018, 01:23 PM   #125
Ryanw10
Ryanw10's Avatar
I could probably buy into the thick wall rubber tube into an oversized hole idea.
I still believe though that any flex the radiator sees will be absorbed by the core. I beat the snot out of the pucks I welded on to my practice radiator with a hammer and all I saw was the puck deforming and no cracks.
Also keep in mind that the frame on this thing is far from done. It will have a grille hoop welded directly to the frame that will tie all the way back to the cab where there will be an A and B pillar tied into the frame. Shock mounts will probably be tied together as well yet too.
Old April 2nd, 2018, 02:12 PM   #126
PUNISHER TA
PUNISHER TA's Avatar
Aluminum hard works over time and gets brittle and cracks, its not an issue you would see with a short test session. Rubber mounts are a great idea.
PUNISHER TA is offline   Reply With Quote
Old April 2nd, 2018, 02:33 PM   #127
bbaXJ
Yooper In Training
bbaXJ's Avatar
Exactly. That's why I said it'll fatigue crack. It'll flex back and forth over and over and eventually split, it won't just snap from a single event.
Old April 8th, 2018, 04:14 PM   #128
Ryanw10
Ryanw10's Avatar
Steering is figured out
Old April 8th, 2018, 05:26 PM   #129
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks good, but I would upgrade to a 2" ratchet.
Old April 8th, 2018, 06:37 PM   #130
Ryanw10
Ryanw10's Avatar
Funny you say that, I attempted to ream the pitman arm out with the steering box strapped to the frame and almost lost it to the ground haha.
Old April 13th, 2018, 11:14 AM   #131
Wramblerguy
Wramblerguy's Avatar
Hp 44 in the rear with you driving sounds like a bad idea
At least use the d50 center section
3rd generation jeeper
Old April 13th, 2018, 11:23 AM   #132
Ryanw10
Ryanw10's Avatar
Yea it was just an idea because I pretty much have all the parts to make it happen right now including gears to match the front.
I will probably end up with a Ford 9" instead
Old April 15th, 2018, 06:51 PM   #133
Ryanw10
Ryanw10's Avatar
Got the steering finished up and couldn't help but throw my wrangler tires on it and see how it looked
Old April 15th, 2018, 07:15 PM   #134
Old April 16th, 2018, 06:07 AM   #135
Cool parts peddler
Ironman Offroad's Avatar
Nice stance.
Old April 16th, 2018, 06:19 AM   #136
greygoose
Gustafson
greygoose's Avatar
I like it, looks real nice!
Old April 16th, 2018, 08:04 AM   #137
Ryanw10
Ryanw10's Avatar
Nice stance.
Yea I like it too. Yesterday was the first time I realized this was a full width dana 44. For some reason I thought it was only 65" wms to wms being only 5 lug but it is actually 67"
Old April 16th, 2018, 08:04 AM   #138
Ryanw10
Ryanw10's Avatar
Thanks!
Old April 16th, 2018, 08:08 AM   #139
Ryanw10
Ryanw10's Avatar
I'll wait and see how it looks with the fenders on but I'm seriously contemplating 33s now instead of 35s. I think 33s will look a lot more proportionate
Old April 16th, 2018, 08:11 AM   #140
greygoose
Gustafson
greygoose's Avatar
I agree. I think 33s would "fit".
Similar Threads
1940-49 Willy's Jeep Questions Cool Hand Luke Jeep Tech 0 June 17th, 2016 07:34 PM
Jeep Willys CJ 5 1957 - $1350 (Grand Haven Mi) cerial Ebay / Craigslist / Auction Links 1 December 7th, 2015 10:56 AM
1960 Willys Jeep CJ-5 37k Miles $1000 tcxtreme1000 Vehicles for sale 8 September 21st, 2015 12:12 PM
*SOLD* "Saddle Brown" Jeep Commander leather seats (great for Willys Jeeps) 1x1_Speed_Craig Completed Sales 3 May 9th, 2015 08:30 PM
1999 Jeep Wrangler W/ LS 5.3L, Long arms, ETC sonic Vehicles for sale 15 October 6th, 2014 05:17 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.52701 seconds with 87 queries
