LS Powered Jeep Willys Pickup - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2018, 09:49 AM   #101
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
Looking good!
Sent from my XT1254 using Tapatalk
Woodyjiw is offline   Reply With Quote
Old February 25th, 2018, 10:48 AM   #102
Ryanw10
Ryanw10's Avatar
Originally Posted by Woodyjiw View Post
Looking good!
Thanks!
Ryanw10 is offline   Reply With Quote
Old February 26th, 2018, 08:12 AM   #103
Ryanw10
Ryanw10's Avatar
Both towers are tacked in place. Going to get the lower mounts cut out this week and start getting the high steer set up. Any one local to the west Michigan area able to machine the knuckle for me?
Old February 26th, 2018, 12:54 PM   #104
mtnbiker995
American
Just read back in the thread but I have the steering box from my JK if you're still looking at that option
mtnbiker995 is offline   Reply With Quote
Old February 26th, 2018, 01:16 PM   #105
Ryanw10
Ryanw10's Avatar
I'm pretty sure the WJ box is going to work, I'll keep that in mind though
Old February 26th, 2018, 01:57 PM   #106
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Last I knew Branik still machines them if you need to send it off.
Old February 26th, 2018, 03:16 PM   #107
fabricator
throttle jockey
fabricator's Avatar
Dana 44 knuckle?
fabricator is offline   Reply With Quote
Old February 26th, 2018, 04:03 PM   #108
Ryanw10
Ryanw10's Avatar
Originally Posted by fabricator View Post
Dana 44 knuckle?
Yes
Old February 26th, 2018, 05:17 PM   #109
fabricator
throttle jockey
fabricator's Avatar
I can do it if you don't have anyone closer. Give me a shout if you still have my #
Old February 28th, 2018, 12:29 AM   #110
Wramblerguy
Wramblerguy's Avatar
I did mine
But it was 4 years ago haha
3rd generation jeeper
Old March 7th, 2018, 10:41 PM   #111
Ryanw10
Ryanw10's Avatar
Almost ready to be sitting on it's own weight again
Old March 25th, 2018, 04:58 PM   #112
fabricator
throttle jockey
fabricator's Avatar
Machined your knuckle today
Old March 25th, 2018, 06:16 PM   #113
Ryanw10
Ryanw10's Avatar
Looks good!
Old March 29th, 2018, 09:02 PM   #114
Ryanw10
Ryanw10's Avatar
Lower radiator mounts are set in place, I welded up a 2" diameter by .5" thick puck tapped for a 7/16" bolt to the tank and formed a bracket to weld to the frame. I have my doubts though that in the current set up i will be able to route the lower hose.
When I set the motor in place I put it as far back as I could and as high as possible. What's crazy is I just did the exact same thing with my wrangler and the crank pulley on the truck sits 3" higher at ride height. The truck has 5" of useable up travel and the wrangler has 8". If I can't figure out a radiator hose solution the motor in the truck will get lowered, but that's worst case scenario
Old March 29th, 2018, 09:25 PM   #115
fabricator
throttle jockey
fabricator's Avatar
From that pic, the hose doesn't look like it would be bad. But I've also cut the outlets off the radiator and welded them back on at whatever angle works best with the hoses
Old March 29th, 2018, 10:24 PM   #116
Ryanw10
Ryanw10's Avatar
Yea I guess the picture is a little deceiving but vertically between the inlets there is probably a 4" difference but horizontally there is basically nothing. I have only used rubber flexible hoses in the past and there is no chance of that working. Stainless flexible hoses might work but I'm having a hard time spending close to a $100 on a hose that might work.
I spent countless hours dialing in my aluminum tig skills to make sure I wasnt going to ruin a brand new radiator welding the puck mounts on so I'm not worried about relocating the outlets...but that doesn't affect the flow of the radiator at all?
Old March 30th, 2018, 12:00 PM   #117
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
My local parts store let's me bring a bent piece of wire and compare it to stock hoses until I find something I can chop up. On a slow day, they've even helped.
Old March 30th, 2018, 12:39 PM   #118
Ryanw10
Ryanw10's Avatar
I tried that at auto zone one time with a cardboard cut out of the shape i needed and the guy at the counter asked me "what's the make and model?" So I said nevermind and went over to auto value and the guy at the counter came back and helped me find what I needed
Old March 30th, 2018, 01:32 PM   #119
bbaXJ
Yooper In Training
bbaXJ's Avatar
I hope that's not the final product. I'd HIGHLY suggest a larger hole in that bracket with a pass-through rubber, poly, or silicone isolator on the mount. Frames flex and I'd be amazed if it didn't crack the radiator tanks right around the welds holding those pucks in if you hard mount it like that.
I've done the same, works well if you find the right shop. Napa, Carquest, and local mom and pop shops seem to be far better about it than the generic Autozone and OReilly's types with the mouth breathing counter staff.
Old March 30th, 2018, 01:47 PM   #120
Ryanw10
Ryanw10's Avatar
I'm going to disagree with you but I will hear you out and I will be open to others opinions as well.
I was for sure planning on a bushing to isolate the tank from the mount, but unless convinced otherwise I do not agree with opening the hole up. I get that the frame flexes but if I have the radiator mounted only by the tanks, won't the radiator core absorb frame flex?
I could be way off but that is my train of thought. I made these pucks but wide open design sells basically the same thing and it looks to me like they mount them to there frames the same way I did, it actually looks like they don't even use a bushing at all.
Similar Threads
1940-49 Willy's Jeep Questions Cool Hand Luke Jeep Tech 0 June 17th, 2016 08:34 PM
Jeep Willys CJ 5 1957 - $1350 (Grand Haven Mi) cerial Ebay / Craigslist / Auction Links 1 December 7th, 2015 11:56 AM
1960 Willys Jeep CJ-5 37k Miles $1000 tcxtreme1000 Vehicles for sale 8 September 21st, 2015 01:12 PM
*SOLD* "Saddle Brown" Jeep Commander leather seats (great for Willys Jeeps) 1x1_Speed_Craig Completed Sales 3 May 9th, 2015 09:30 PM
1999 Jeep Wrangler W/ LS 5.3L, Long arms, ETC sonic Vehicles for sale 15 October 6th, 2014 06:17 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 1.14563 seconds with 87 queries
