LS Powered Jeep Willys Pickup - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2018, 09:27 PM   #81
Ryanw10
Ryanw10's Avatar
Track bar is mocked up
Ryanw10 is online now   Reply With Quote
Old January 5th, 2018, 10:09 PM   #82
sterlingfire
Looking good Ryan!
Are you still planning on going to the snow run at r+v the weekend of the 26th?
sterlingfire is offline   Reply With Quote
Old January 6th, 2018, 07:04 AM   #83
Ryanw10
Ryanw10's Avatar
Originally Posted by sterlingfire View Post
Looking good Ryan!
Yessir! I will be taking my wrangler up there
Old January 6th, 2018, 08:00 AM   #84
sterlingfire
Cool, I'm thinking about showing up for the Saturday runs. We'll see if that happens though. Hopefully see you there.
Old January 6th, 2018, 08:34 AM   #85
Ryanw10
Ryanw10's Avatar
Sweet! I'll be there Saturday morning and most likely staying through sunday
Old January 6th, 2018, 08:37 AM   #86
Ryanw10
Ryanw10's Avatar
Everything is looking good so far at full bump, track bar is about level and will be able to clear the diff cover with no bend. I was really worried about that with the axle side mount lower and the pig on the passenger side.
Also looks like the truss will double nicely as a bump pad like I was hoping
Old January 6th, 2018, 06:40 PM   #87
sterlingfire
How are you doing the drag link? Y link?
Cool, I hope to make it for sure!
Old January 6th, 2018, 07:52 PM   #88
Ryanw10
Ryanw10's Avatar
To be determined haha. My knuckle is a flat top so I could have it drilled and tapped for a hi steer arm, or I will do the y link set up. Gotta stare at it some more and decide on a steering box first
Old January 7th, 2018, 06:49 PM   #89
Looking good.
Old January 7th, 2018, 07:29 PM   #90
Ryanw10
Ryanw10's Avatar
Looking good.
Thanks!
Old February 1st, 2018, 08:04 AM   #91
Ryanw10
Ryanw10's Avatar
I have been struggling to come up with a steering box that will package nicely. I started with my wrangler box and that was pretty obvious it was not going to work. I flipped it around to try and simulate an astro van box but still not going to work. I then came across the Toyota IFS box that looked pretty promising but I don't like that it mounts outside of the frame. The steering box from my wife's JK looks like exactly what I want but those are still pretty expensive to buy. My latest find is a Jeep WJ box so I'm hoping to grab one of those from the junkyard this weekend.
I also have a set of fox 2.0 resi coilovers that should be here next week to get this thing back on its own weight!
Old February 1st, 2018, 08:31 AM   #92
Steering boxes are overrated lol.
Old February 1st, 2018, 08:42 AM   #93
How much highway use do you plan on? For the occasional street use, full hydro is an option.
Old February 1st, 2018, 08:53 AM   #94
Ryanw10
Ryanw10's Avatar
I figured someone might bring that option up, and I'm not totally against it yet.
But with that said I won't run any bigger than a 35" tire with this set up so hydro will never be "necessary"
A mechanical linkage set up will be quite a bit cheaper than a hydro set up.
It will see very little highway use, any long distance travelling it will be put on a trailer.
It will see a lot of street miles between car shows, ice cream runs, mall runs, etc.....
My parents will drive this a lot more than I will and I'm told full hydro can take some getting used too
Old February 1st, 2018, 09:31 AM   #95
You are correct. For your setup you will probably want mechanical.
Old February 1st, 2018, 10:55 AM   #96
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
You could do the 4500 trick and run a smaller manual box and a double ended ram with an external servo. But that is likely gonna cost a few bucks. I looked at PSC and didn't see it, but you should be able to call and get the dirt on it.
Old February 5th, 2018, 06:00 PM   #97
Ryanw10
Ryanw10's Avatar
I braved the cold this weekend and pulled a wj steering box and then started mocking everything up.
Y link steering is for sure not going to work
Tie rod over the knuckle with the drag link on a high steer arm seems to be the best option so far, only issue is the steering box sits pretty high on the frame and it is the most expensive option.
Track bar and drag link are within an inch in length and at the exact angle.
Another option I messed around with is the tie rod under the knuckle and the drag link on top. The steering box sits lower on the frame but track bar and drag link angles are way off.
Old February 23rd, 2018, 12:12 PM   #98
Wramblerguy
Wramblerguy's Avatar
Almost looks like a flat pitman arm with the joint mounted below would work
3rd generation jeeper
Old February 23rd, 2018, 12:22 PM   #99
Ryanw10
Ryanw10's Avatar
I have everything mocked up right now and as it sits, I'm happy with it. Clearance is close with the 1" od mock up tie rod so if that ends up being an issue a flat pitman arm will for sure be the solution.
I just finished up my coilover towers at work today so this weekend I will get those tacked in place and start cycling through the suspension
Old February 24th, 2018, 03:50 PM   #100
Ryanw10
Ryanw10's Avatar
Getting the shock towers tacked in place
Similar Threads
1940-49 Willy's Jeep Questions Cool Hand Luke Jeep Tech 0 June 17th, 2016 08:34 PM
Jeep Willys CJ 5 1957 - $1350 (Grand Haven Mi) cerial Ebay / Craigslist / Auction Links 1 December 7th, 2015 11:56 AM
1960 Willys Jeep CJ-5 37k Miles $1000 tcxtreme1000 Vehicles for sale 8 September 21st, 2015 01:12 PM
*SOLD* "Saddle Brown" Jeep Commander leather seats (great for Willys Jeeps) 1x1_Speed_Craig Completed Sales 3 May 9th, 2015 09:30 PM
1999 Jeep Wrangler W/ LS 5.3L, Long arms, ETC sonic Vehicles for sale 15 October 6th, 2014 06:17 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.71410 seconds with 87 queries
