89 yj lsx dana 60s 4 link front and rear full hydro built for all around use. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 15th, 2015, 01:07 AM   #1
ck85abc3
Default 89 yj lsx dana 60s 4 link front and rear full hydro built for all around use.
Here is my attempt at a build thread. Normally would not have time. But I'm working night watch right now. I'll post and then edit over and over so I don't lose everything after hours of typing on my phone.
Here she is the day I bought it. Stock axles and transfer case with 70s chevy 350 and turbo hydromatic transmission. Spring over with lift spring. 38.5 boggers. Ended up breaking a front axle shaft on the second wheeling trip so I put in dana 60s from 79 ford f350 with piece parted together full hydro low steer.
Put the dana 60s in on the driveway and got her going the day before the Drummond island trip. Had full hydro in but my pump was shot. Wheeled all weekend without power steering pump. Arms were ssore afterwards. O ya, got a set of 39.5 boggers on 16.5" aluminum rims.
That Drummond island trip went well. But ever trip after that was horrible due to axle wrap. 3 different trips broke a front pinion on one, rear pinion on another, and rear yoke on another. Be warned... power sprung over and big tires you NEED a traction bar. I ended up deciding to go lsx 4 link with coil overs. Thought it was going to take 3-4 months...lol not a chance. Started working on it November of 2013 and wanted to take it to 2015 dog party.
The frame was a lot worse than I thought.
There were probably 5 places like that that I fixed. Plus I filled in every single hole and cut off every single bracket but the body mount brackets. I really should have built a new frame but at the time I was scared. The current plan is to finish the rig and then build a new from with some tweaks to fix some problems I realized by working on the stock frame.
Finally got the frame done. Time to 4 link the rear. Was planning on dual triangulated with upper and lower frame link mounts above the bottom of the frame. Goal for 4 link numbers was a range of anti squat from about 50 to 120 with the adjustable bracket and within .2 from 0 roll axis.
I thought everything was good when I articulated the axle it looked like there was a whole lot of articulation steer which I thought dual triangulated was supposed to prevent. Was planning on trying it out and was going to change if I did not like it. But then I realized there were going to be clearance issues with the drive shaft. I tried moving the lower link frame mounts a little farther apart to give clearance to the rear drive shaft but I could not get good numbers on the role axis no matter what I did. Ended up just slightly triangulating the lower links and putting them under the frame. I had to inboard the frame mounting brackets about 2 inches in order to get good numbers.
View from the side.
View from the ground up showing the under side of the frame.
Time to put in motor and tranny. 01 ls1 camaro bottom ended with 60k miles, 243 heads ls6 intake, ls2 maf, texas speed cam ground for low ended power and good idle. Mast motorsports ls conversion oil pan.
Time for shocks. 2.0 fox coil over 200 over 300. Hoping for 6 inches bump and 8 inches droop after skid plate and role cage is done. At about 7 and 7 now with jeep functional with no skid plate or roll cage.
Front currently has cross member between the hoops. Rear does not since I'm trying to keep this as stockish looking and 4 person functional as possible. Here is what I did to try to make the rear hoops strong enough without a cross member. 1.5" quarter wall dom and 1/4 plate. Upper shock mounts are pivoted out for clearance between frame and coil springs. Hopefully the extra beef in there and 1/4 wall will be strong enough.
Rolling chassis
Body and motor in place.
Front high steer arm tied into the stock steer arm.
Made it out for spring wheeling trip. Broke 3 beads. Really need to get beadlocks.
Mudstock at twisted trails offroad park. Warn winches work under water. This is jacked up for mud. Normal stance is about 3 inches lower from shock adjustment, 1 to 2 inches lower by deflating when I get beadlocks, and about 1 inch lower from adding weight. So about 6 inches lower.
ck85abc3 is offline   Reply With Quote
Old June 15th, 2015, 07:38 AM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Old June 21st, 2015, 09:25 AM   #3
chasetheface123
chasetheface123's Avatar
Looks awesome! Makin it to any of the bogs in the future? Alba, Polish fest?
chasetheface123 is offline   Reply With Quote
Old June 21st, 2015, 09:29 AM   #4
Looking good.
Old June 21st, 2015, 09:52 AM   #5
firehawk
Live Action!
firehawk's Avatar
Yea nice work.
Old June 21st, 2015, 05:51 PM   #6
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Good patch jobs!!
Get it up here to Alba days & Polish Festival!
Old June 22nd, 2015, 08:34 AM   #7
ck85abc3
I plan on going to more events in the future. But im only in michigan 13 days a month. Might get laid off again though. When are these events?
Old October 3rd, 2015, 05:43 AM   #8
ck85abc3
Old October 3rd, 2015, 07:56 AM   #9
burb1976
burb1976's Avatar
Nice build. Thinking about linking my 89 YJ.
burb1976 is offline   Reply With Quote
Old October 3rd, 2015, 10:22 AM   #10
NightKrawler
KOH Jackhammer
NightKrawler's Avatar
Originally Posted by ck85abc3 View Post
[URL=http://s1066.photobucket.com/user/Craig_Kritsky/media/Mobile%20Uploads/20150926_160539_zps0ornx6zj.jpg.html]
WOW!!
Subscribe for more videos http://www.youtube.com/user/bult4mud/videos
http://www.youtube.com/channel/UCYL4kHv0JB5sOKlPALLHGTQ
--l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_) .......
NightKrawler is offline   Reply With Quote
Old October 3rd, 2015, 10:35 AM   #11
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Nice work! I like it.
* 2018 ZR2
Old October 3rd, 2015, 02:05 PM   #12
fabricator
throttle jockey
fabricator's Avatar
Looking good. 200 over 300 springs?
fabricator is offline   Reply With Quote
Old October 3rd, 2015, 02:57 PM   #13
ck85abc3
They are 200 over 300. They are a lot stiffer than I expected. Have about 8 inches bump and 5-6 droop. I think I like the 200/300 for mud or snow. Never even came close to thinking I was going to tip so might as well get a little more ground clearance. Will need to figure out what springs to get for some rock crawling though.
Old October 3rd, 2015, 03:13 PM   #14
firehawk
Live Action!
firehawk's Avatar
Your lower link mounts are backwards.
Old October 4th, 2015, 12:43 AM   #15
ck85abc3
I know. Think it is that big of deal? I did it like that for better role axis numbers. I'm still planning on beefing up the mount more since they are backwards.
Old October 4th, 2015, 01:11 PM   #16
firehawk
Live Action!
firehawk's Avatar
Only thing you might notice is getting the backside of them getting hung up on rocks or anything you might drive over, you eliminated the ramp that typically comes off the back. Probably not a big deal.
Old October 4th, 2015, 03:53 PM   #17
ck85abc3
IC. The link is the ramp on the one side and the bracket is the ramp on the other side.
I was using the ramp on the bracket the compliment the link as a ramp and then was still planning on building a ramp for the other side.
Old January 15th, 2020, 07:34 AM   #18
Jayden
In the band!
I plan on going to more occasions later on. Be that as it may, I'm just in Michigan 10 days per month. Might get laid off again however.
Jayden is offline   Reply With Quote
Old January 15th, 2020, 09:03 AM   #19
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
WTF is with this dude? ^ Bot im thinkining.
Old January 15th, 2020, 11:25 PM   #20
Wramblerguy
Wramblerguy's Avatar
Gotta be
3rd generation jeeper
Similar Threads
Misc Jeep Part(s) CJ Radiator, YJ Front Calipers, 8.8 Rear calipers Stone Parts for sale 2 September 18th, 2015 10:22 AM
Chevy SRW Dana 60 front and 80 rear kkodet Parts for sale 17 April 26th, 2015 09:34 AM
79 Ford High Pinion Dana 60 Front and 99 E-350 Dana 60 Rear (Location: Neapolis, OH) Chrisholmz Parts for sale 6 March 10th, 2015 11:09 PM
Complete Axle(s): Dodge dana 60 front and 70 rear $700 moparhorse Parts for sale 11 January 12th, 2015 07:26 PM
Complete Axle(s): sterling 10.25 rear $200 wildhorse Parts for sale 5 September 25th, 2014 11:39 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.59999 seconds with 86 queries
