return a dead 1954 WillysWagon to the road/offroad. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2014, 07:59 PM   #21
J Truck Rick
J Truck Rick's Avatar
Kim,I believe those are CUTLASS hubs.Early aftermarket hubs.I still have a bunch of parts for these.I have a rebuilt 30-plus years ago,'54 Kaiser super-sonic motor,same as the Willys,but higher compression.
J Truck Rick is offline   Reply With Quote
Old April 25th, 2014, 08:39 PM   #22
jeepers48
jeepers48's Avatar
im going to swap out the axles next month, ford 9" and a D44 from a 77 F150.
I have a stuck valve in cly #4. Ive managed to semi-free it up. I threw a 12 volt battery in to crank the motor over faster with a mix of diesel and mystery oil. Cly #4 im dumping thinner into so as to eat up the gasoline varnish out of the valve guide.
If its a lost cause on the L226 motor, I just picked up a 2000 Cherokee with 115,000. on the whole drive train and just might swap everything over to the Willys Wagon. The Cherokee is getting 18-20 mpg hwy. As of today im still on the fence. Happen to have the Overdrive with the S-S?
jeepers48 is offline   Reply With Quote
Old May 12th, 2014, 11:23 AM   #23
jeepers48
jeepers48's Avatar
well heres what the willys looked like the past few weeks. Unstuck the intake valve and its all back together and running great for the first time since getting the wagon. Ill have to deal with the wiring now. I'd like to make it a 12 volt system rather than stick with 6 volts, reasons being I'd like to hook up a radio, cb and later a winch. Im in search of a overdrive unit if anyone knows where one is sitting for a fair price.
Old wiring is toast. The headlights and taillights don't work. My biggest fear is that one of the hot wires well short out and cause a fire under the dash or under the hood. Drove it a few miles the other day, "WooHoo"!! and cant wait to take it to the Mounds for a day. Tow strap equipped!
Old May 12th, 2014, 11:39 AM   #24
koochman450r
koochman450r's Avatar
there cant be much wiring on that thing. Couldn't you just rewire it all yourself? Buy new bulbs alternator, starter, coil and other stuff. Wouldn't be cheap but shouldn't be real difficult.
you won this battle.
Old May 12th, 2014, 05:01 PM   #25
jeepers48
jeepers48's Avatar
The only thing that stumps me is doing wiring on the Delco alt. Some guys use a dash-light bulb when wiring to the ignition and some don't. The last time I went through this I smoked a alt.....I still don't know how I messed up.
Old May 18th, 2014, 01:13 PM   #26
jeepers48
jeepers48's Avatar
Well I pulled the the heavy duty generator and fab'd up a bracket to hold the alternator. I started rewiring too. So far the alternator works but I have to up the rpms to get it to charge past 12 volts on the meter instead of 14-plus volts. Thoughts anyone?
I did use a light bulb between the alt and the ignition to excite the darn thing. Maybe a bigger bulb? or use another alt?, I have three of them kicking around.
Old May 18th, 2014, 01:23 PM   #27
jeepers48
jeepers48's Avatar
Anyone have a part number for me on a high output alt? The ones I have only put out 40 amps instead of 90 to 100 Plus amps. Ill be running a winch and extra lights on the wagon. Any alt I have is when dinosaurs were still roaming. I have a dinosaur but wont post any pics.
Old May 18th, 2014, 02:12 PM   #28
itselliott
itselliott's Avatar
If you have to rev it in order to get it to put out charging voltage, you need to "exite" the windings.
I dont have the specifics in my head but there are plenty of write up on this .
Look up alternator swaps over at IFSJA.org
Or here: http://oljeep.com/AltTheory17/Altern...ersion17R1.htm
Old May 18th, 2014, 03:11 PM   #29
jeepers48
jeepers48's Avatar
That's what the light bulb is for, I wired that between the alt and ignition switch. The bulb I used would be the same size as the ones to light up the dash on a jeep cj. I might try a different size/volted light.
Ive been looking thru youtube vid's and diagrams of what others have done.
im doing the delco 3 wire setup rather than a 1 wire.
Old May 20th, 2014, 12:53 PM   #30
FyrFyr
FyrFyr's Avatar
http://www.madelectrical.com/electri...elcoremy.shtml
This is the best info I found on these alternator and using them in other vehicles. I have the 94 amp 12si type on my Jeep and '65 Mustang and they have worked out well.
FyrFyr is offline   Reply With Quote
Old May 21st, 2014, 08:56 PM   #31
jeepers48
jeepers48's Avatar
Thx for the info, theres part #'s so I can pick up a 94 amp output. "Cool"
Old May 9th, 2015, 12:01 PM   #32
jeepers48
jeepers48's Avatar
Well, more work has been done on the wagon. I had put a used pair of XJ springs on the rear but they sagged a bit to much so I bought a pair of Ranchos w/1" of lift. It helps clear the 31" tires. I'll post pics on a nicer day. The Willys still leans to the drivers side but that's due to worn out spring packs on the front. I put all new brake pads and brake cylinders on the wagon too. I'm currently looking for either stock front seats or a bench seat from a S-10 pickup. Finding anything old that fits is fine by me.
I'm still trying to keep the build a bit rustic. It runs and drives but I'm still Leary of making it a daily driver for the time being .
Old May 9th, 2015, 01:03 PM   #33
jbsjunk
Little Member
jbsjunk's Avatar
Sounds like the rig they got for Dirt Everyday on Youtube.
Old May 9th, 2015, 01:58 PM   #34
jeepers48
jeepers48's Avatar
I've watched a few of their videos. They really cut up the dog house to get that LS1 motor in there.
Old May 9th, 2015, 02:14 PM   #35
jbsjunk
Little Member
jbsjunk's Avatar
I think they cut it because they could. They think Cali cars are limitless.
Old December 16th, 2019, 11:35 AM   #36
jeepers48
jeepers48's Avatar
On and off I've been working on the wagon. Still have the original motor in it, a flat head six. During the summer it kills dozens to thousands of mosquitoes/cough, cough!. I had picked up a Chevy D44 for the front but still havent gotten around to getting it narrowed and changing out the knuckles to Ford outters. At that time ill swap in a Detroit locker too.
Ive also done some sheet metal floor repair on the front passenger floor. The driver side well be next. Any leads on a warn or saturn overdrive would be appreciated, thx.
One last thing, very humble on that JP Magazine posted up my Willys Wagon, Pickup and 2a in Jeepshots about 6 months ago. Felt like getting my picture on the cover of Rolling Stone magazine.
Old December 16th, 2019, 12:18 PM   #37
I saw you in the mag and said hey I know that guy.
Old December 16th, 2019, 05:13 PM   #38
jeepers48
jeepers48's Avatar
Hi Jim. I had never had any pics in a magazine before ........ got me all giddy getting a E-email from Tracy Clarke / JP Magazine, telling me it was going to be in the next issue under Jeepshots.
Lol, I bought a few magazines off the shelf.
Similar Threads
4x4 off road show Presented by Great Escapes Off Road and Wolverine Off Road Club bbrancheau Meets, Greets, and Wrenching 5 August 5th, 2012 03:10 PM
Best GPS for on-road and some offroad? Flexin' XJ GPS tracks and trails 7 May 14th, 2008 10:08 AM
my explorer is like the Appllo 13 mission, and now im dead on the road Skooter_Built The Pub 21 June 26th, 2007 11:46 PM
closest place to offroad from m59 and Bogie lake road Chris Rogers The Pub 22 May 22nd, 2007 07:07 AM
Dead on road nightcrawler Jeep Tech 17 February 21st, 2007 05:21 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.56096 seconds with 81 queries
