Garage floor coating? - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > The Pub
The Pub A friendly forum where everybody is nice, and will answer any questions you have about life.
Old September 8th, 2016, 04:22 PM   #1
Spudy
Redneck Excavator
Spudy's Avatar
Default Garage floor coating?
Well the wife wants to try and clean up our garage. Plan is to full everything out and clean it good. We want to paint the floor to help keep it clean. Anyone ever try the epoxy kits they sell now? didnt know if it was worth the money over paint. Is a little over twice as much.
Thanks
Spudy is offline   Reply With Quote
Old September 8th, 2016, 04:27 PM   #2
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Thanks
Honestly the best place to do some research on this is www.garagejournal.com there are TONS of threads over there on this type of project. I was looking into it for a while as well and the one thing that I learned is that it's ALL about the prep work.
Mihlfeldl2005 is offline   Reply With Quote
Old September 8th, 2016, 07:14 PM   #3
DuffMan
Your Message Here
DuffMan's Avatar
I found "Rustoleum Restore" polycuramine at Lowes - for half price.
Same thing as "Rocksolid" (which Rustoleum bought our). Polycuramine is 20x harder than epoxy. As stated, research on Garagejournal and elsewhere.
I did my garage 3 years ago with no-name waterborne epoxy - still looks great! It's all about the prep - grinding,etc...
This is the Pub. Leave common sense at the door.
DuffMan is offline   Reply With Quote
Old September 8th, 2016, 08:10 PM   #4
BlooMule
Old School
BlooMule's Avatar
One place i worked painted the maintenance dept floor. It was pretty grungy, we rented a scarifer, scrubbed it with muriatic acid, then primed and painted with epoxy.
Couple years later, with moving heavy equipment and daily scrubbing with a commercial floor machine it still looked new.
Prep is key. Nothing will stick to oil stained concrete.
-rw-rw-rw
BlooMule is offline   Reply With Quote
Old September 8th, 2016, 08:35 PM   #5
busyfixin
Balls Deep
busyfixin's Avatar
Biggest question, do you weld, or use torches in the garage?
busyfixin is offline   Reply With Quote
Old September 8th, 2016, 09:03 PM   #6
Spudy
Redneck Excavator
Spudy's Avatar
no this is just the house garage. very look work is done in it. All mechanical stuff is done in the shop. is there a way to tell if the concrete is sealed?
Old September 8th, 2016, 09:20 PM   #7
BlooMule
Old School
BlooMule's Avatar
I think water will bead on sealed concrete
-rw-rw-rw
Old September 9th, 2016, 06:40 AM   #8
bbaXJ
Yooper In Training
bbaXJ's Avatar
Send a message via AIM to bbaXJ
The Rustoleum kits are junk compared to the high end stuff. I bought a gallon to use on my work bench. It works well enough for that, but it's like water compared to the stuff we used on my floor. It wouldn't hold up well at all. My friend bought some stuff online that he used in his garage and basement and it's holding up very well. He doesn't come on here much but let's see if he responds..... @p.o.r.n.
I had a high quality epoxy floor professional installed when I bought my house, I do lots of cutting, grinding, and welding, and it's held up extremely well. It was a concern of mine, but turned out to be a non-issue with a little common sense taken when melting metal.
bbaXJ is offline   Reply With Quote
Old September 9th, 2016, 06:46 AM   #9
koochman450r
koochman450r's Avatar
take a piece of clear plastic and tape it down on top of floor. If moisture builds up under plastic your floor is not sealed. Only need to do like a square foot.
Originally Posted by clarkstoncracker View Post
you won this battle.
koochman450r is offline   Reply With Quote
Old September 9th, 2016, 07:09 AM   #10
aber61
aber61's Avatar
The products from the big box stores is at a minimal ok. There are other products that are great but not cheap. 100% solids is a way to go. Two car garage would run you approx. $2000.00 and you could be on it the next day. Some guys are more $$ and some less. They have different products for all uses. I Have seen some real nice looking floors that are polished and sealed.
aber61 is offline   Reply With Quote
Old September 9th, 2016, 07:31 AM   #11
Flip
Member
agree - prep is key. we did ours with a kit from home depot but also did the clear coat over it in the spring of 2005 and didn't show signs of wear until this summer so 11 years of use. will be looking to redo in the spring
Flip is offline   Reply With Quote
Old September 9th, 2016, 04:15 PM   #12
Spudy
Redneck Excavator
Spudy's Avatar
for what we are doing with this (Wife parks in one bay and the other is just random crap lol ) I dont think i want to spend any more then just the box store expoy stuff. Even just leaning towards paint. If it was for a workshop i would put more money into it.
Old September 9th, 2016, 05:11 PM   #13
aber61
aber61's Avatar
If that is all you are going to use it for then get the HD stuff. They rent a floor sander for concrete. Be careful it can take you for a ride.
Old September 9th, 2016, 08:32 PM   #14
Sandals
Fucking Zen as Shit
Sandals's Avatar
Following this, and reading on garage journal, in a few month's I'm going to have a lot of floor to do.
Sandals is offline   Reply With Quote
Old September 9th, 2016, 09:37 PM   #15
p.o.r.n.
Member
Garage journal is a great place to get information. Like bbaxj said we have a buddy that has done this stuff for years and there are a few things to know:
1: Dont use acid no matter how good others may say it worked.
2: Prep is everything. Every bit of concrete needs to be roughed up good. The Clark machine from Home Depot with the diamond disc is what you want.
3: If your concert is old and messed up no epoxy will take well to it. This is my problem as half the garage was soft from years of a hot car parking on it.
4: If your epoxy stinks and burns the eyes it's junk. The burning is coming from all the fillers they use. Pure epoxy will not smell that bad at all.
With all that said I used epoxy coat
http://www.epoxy-coat.com/?ibp-adgro...FQQJaQod_JgFpQ
I'll use them again when I build may barn and the garage can be a show case. Just keep in mind good epoxy will not last on bad prep. Stuff at work was done 2 years ago with almost no tooth to the concrete and it looks like hell today.
p.o.r.n. is offline   Reply With Quote
Old September 10th, 2016, 12:15 AM   #16
Alex456123
Durango-space-division
Alex456123's Avatar
@whiterhino
How is the rustolium epoxy garage floor coating on the shop floor holding up?
#Durangoclan
Alex456123 is offline   Reply With Quote
Old September 10th, 2016, 12:43 AM   #17
GerkTJ
GerkTJ's Avatar
Originally Posted by Alex456123 View Post
@whiterhino
That's what I used on my barn floor and its holding up great!
GerkTJ is offline   Reply With Quote
Old September 10th, 2016, 12:52 AM   #18
Alex456123
Alex456123's Avatar
I helped apply it at the plant he works at, we mixed sand in to help with traction.
Last time saw it was still holding up great in a industrial environment.
#Durangoclan
Old September 10th, 2016, 06:01 AM   #19
It's still good.
I wish I had done my garage when I first built it. Now it would be a major project. .
Old September 10th, 2016, 06:53 AM   #20
aber61
aber61's Avatar
This is probably some of the best product out there. I have used this and it sets up fast, not for the light at heart. Get it down and move fast. Mix, pour, squeegy and back roll, done. Your on it the next day.
https://www.hpspartacote.com/
Garage door question Mr. Beefy General Tech 17 July 15th, 2016 03:22 PM
4x8 insualtion as "celing" in garage, how thick? booblinker The Pub 14 November 11th, 2015 11:45 AM
Electric heat for garage? kkodet General Tech 12 October 17th, 2015 03:30 PM
Freightliner FL70 Motorhome with Garage Project JeepMann Vehicles for sale 32 September 21st, 2015 02:40 PM
Garage, Pole Barn, or Shop heater... Natural Gas Modine 85,000 BTU....SOLD bigbadazzjeep Completed Sales 14 August 13th, 2014 12:35 AM
Page generated in 0.53247 seconds with 86 queries
