wheelbase - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > The Pub
The Pub A friendly forum where everybody is nice, and will answer any questions you have about life.
Old May 16th, 2018, 07:46 AM   #1
siettas81
siettas81's Avatar
Default wheelbase
what is a good all around / ideal wheeling center axle to center axle wheel base for 38"-42" tires ?
siettas81 is offline   Reply With Quote
Old May 16th, 2018, 07:57 AM   #2
IMO, 106" - 115" I'm 106 with 39's and observing others when wheeling, I'd like to be 108 to 110. My observation is that any longer starts creating break over issues. However, I get around pretty decent at 106.
Old May 16th, 2018, 08:00 AM   #3
koochman450r
koochman450r's Avatar
117"
Just saying that because thats what i'm at lol. But i feel like they all have ups and downs. Too long is awesome on climbs but shitty for trails and turning, then the opposite is true. I always feel like people building buggies try to be 110-122.
Originally Posted by clarkstoncracker View Post
you won this battle.
koochman450r is offline   Reply With Quote
Old May 16th, 2018, 08:09 AM   #4
Originally Posted by koochman450r View Post
117"
Depends on tire size and the type of wheeling you want to do. No way I would want to be that long on 39's and rock crawling. Now, if all you want to do is run high speed at the dunes or be a hill killer, that's a different story.
Old May 16th, 2018, 08:10 AM   #5
I'm going from 105" to 109". With a belly height of about 19" I'm worried 109" is going to be to long but I'm pretty much forced to do it with my new front end set up.
Old May 16th, 2018, 08:17 AM   #6
koochman450r
Yeah i was figuring with 40+ tires and standard midwest wheeling. I have a 21" belly and i dont find myself getting caught up on too much stuff. there is no perfect number, but goatbuilt specs out 110wb for their kits.
Old May 16th, 2018, 08:22 AM   #7
38-40 tires rockcrawling I'd say < 106-110 wheelbase and 19-20 belly
42-43 tires rockcrawling I'd say 112-118 wheelbase and 20-22 belly
Seems like the guys wanting big climbs over getting through tight trails add 8-10" of wheelbase and have a bit more belly to help with breakover
Old May 16th, 2018, 08:23 AM   #8
Yeah i was figuring with 40+ tires and standard midwest wheeling. I have a 21" belly and i dont find myself getting caught up on too much stuff. there is no perfect number.
I guess we need @siettas81 to define what type of wheeling he wants to do.
Here is something to think about. The Ultra4 guys run a combination of high speed desert to extreme rock racing. (not technical crawling) Most of them are running 40" tires and most of them are < 115" wheelbase. If you are going to drop > $150,000 on a dedicated race rig, you would probably design around the best wheelbase for your rig.
The technical rock crawling guys run about the same, maybe a little shorter.
Now go to the other extreme to the rock bouncers. They are all running > 42" tires and have much longer wheel bases.
Old May 16th, 2018, 08:30 AM   #9
koochman450r
this is the internet. We aint got no time for real information and sound advice Make it 140" with 54" tires and 4 wheel steer!!
Old May 16th, 2018, 08:32 AM   #10
That's about what my RC car is scaled at. LOL
Old May 16th, 2018, 09:44 AM   #11
siettas81
siettas81's Avatar
just looking for input, this winter i am stripping parts / drive line from my truck and putting them onto a new cab i bought to be smaller and not fool size anymore, would like to be decent at hills, rock crawling but still be able to rip about dunes. planning to build somthing close to ultra 4 style rigs with straight axle, coilovers and by passes on all 4 corners with trailing arm 4 link in rear
Old May 16th, 2018, 09:45 AM   #12
siettas81
siettas81's Avatar
been thinking 108-110 range
Old May 16th, 2018, 09:47 AM   #13
Tire size?
Old May 16th, 2018, 10:08 AM   #14
siettas81
siettas81's Avatar
Tire size?
39.5-42s
Old May 16th, 2018, 11:36 AM   #15
Bones
skillicous
Bones's Avatar
Send a message via AIM to Bones
all around wheeling? 113. tighter trails and rocks, 108.
Inviscid Motorsports
Special Thanks and Recommendations to;
Motorcity Machines
Ironman Offroad
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Bones is offline   Reply With Quote
Old May 16th, 2018, 12:50 PM   #16
bbaXJ
Yooper In Training
bbaXJ's Avatar
Send a message via AIM to bbaXJ
I agree with most of the ranges stated here. It comes down to personal preference, but also how the rig is built. The shorter it is the more suspension geometry and overall balance will matter. My TJ is relatively short at 103", but it's stable as hell and can climb a lot more comfortably/safely than a lot of longer wheelbase rigs because it's set up well. Sometimes more wheelbase is a bandaid for a bad setup. If your rig tries doing a wheelie every time you're climbing under throttle you don't necessarily need more wheelbase, you need to correct your geometry and possibly your shock setup. Even with good setup there's obviously a limit for safe climbing or easy maneuverability, that's where the ranges mentioned come in.
bbaXJ is offline   Reply With Quote
Old May 16th, 2018, 01:15 PM   #17
Bones
skillicous
Bones's Avatar
I often see too little separation on the chassis side of the rear 4 link. Causes the rear axle to roll and hop when loaded on climbs. Too much separation is better than too little.
Motorcity Machines
Ironman Offroad
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 16th, 2018, 01:24 PM   #18
xj4life
xj4life's Avatar
Love to see this kind of tech talk on GL. Who says this forum is dead
Project Midlife Crisis
xj4life is offline   Reply With Quote
Old May 16th, 2018, 01:35 PM   #19
^ X2
When I was building my junk, the people on this forum went out of there way to help keep me from screwing it up.
I do not have experiance with many rigs at all, but my jEeP at ~103" climbs pretty good and has not felt to short yet.....
Old May 16th, 2018, 02:26 PM   #20
BlooMule
Old School
BlooMule's Avatar
Yeah, it's too bad there's not a sub forum for this stuff...
-rw-rw-rw
BlooMule is offline   Reply With Quote
Page generated in 0.57739 seconds with 86 queries
