Complete Axle(s): BUILT axles. ARB air lockers! D30hp, Ford 8.8. Rims to fit. 4:10 gears. Now with PICS - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2014, 04:18 PM   #1
Badmunky
Badmunky's Avatar
Arrow BUILT axles. ARB air lockers! D30hp, Ford 8.8. Rims to fit. 4:10 gears. Now with PICS
Hello.
I bought these axles to put under my 2000 Cherokee.
But plans changed and I sold the Cherokee.
Now I have no use for these axles. So its time to find them a new home!
They where built and run for about 12,000 miles with no problems.
If your looking for junk, these are not for you! These axles where built all the best parts. no corners where cut.
If there is any thing you would like to know just ask. There was so much done to these axles I may have missed something.
The front axle is a D30 HP from a Cherokee. They where fully rebuilt 12k miles ago with all new ball joints, U joints, seals, bearings, gears, and ARB air lockers! Every part was replaced!
It also has a custom OTK steering setup that is made from 1.25 .219 wall DOM tubing and larger rod ends then stock. Its beefy!
It has Nitro 30 spline chromo axles, 27 spline outter, and new Timkin wheel hub bearings. It will bolt right in to any Cherokee!
The brakes and steer knuckles are from a WJ. There larger then the stock XJ brakes. New pads, rotors, and two piston calipers where installed when the axles was built. Also has synergy ball joints, and A Riddler diff cover.
All brackets are 3/16" thick accept passenger upper control arm bracket.
Pics of the front axle.
The rear axle is a Ford 8.8 from an Explorer with disk brakes!
The axle tubes have been welded and it also has all new parts, 4:10 Nitro gears, ARB air locker, Yukon Chrome molly HD shafts with C clip eliminator kit, TNT raised shock mounts, TNT U bolt eliminator kit, and it is ready to bolt right in to a Cherokee!
The brakes where replaced with new pads, rotors, and calipers when the axle was built.
The axles are filled with full synthetic fluid, and are ready to go!
The rims are 17" steel D windows and will clear the brakes on the axles. The wheels are also used and have about 18k on them. They need to be cleaned and painted. But there solid and straight.
The axles and wheels have been stored in a storage unit since they where removed from the donor vehicle. (It was not wrecked, it was converted to 1 ton axles.)
Also included are spare parts for the front axle. All parts are new. I also have some boxes and paperwork from the build.
1. Complete Timkin front hub bearing.
2. Front axle seal.
3. Drive shaft yoke.
4. Ball joint.
5. Tie rod end.
I am asking $3,500 for every thing!!!!!!!!!!!!!!!!!! (This is what I paid for it all.)
The build cost on these axles not including the front donor axle was well over 7K. The lockers alone cost more then 2K.
I have a trailer and can even help with delivery with in reason. My zip is 49286.
Please PM me if you are interested!
Thanks!
Badmunky is offline   Reply With Quote
Old November 29th, 2014, 04:24 PM   #2
1997XJ
1997XJ's Avatar
Price for d30?
1997XJ is offline   Reply With Quote
Old November 29th, 2014, 05:02 PM   #3
Badmunky
Badmunky's Avatar
Looking so sell only as a full package at this time.
If they do not sell in a few weeks I may consider selling them separate.
Old November 29th, 2014, 09:44 PM   #4
bbaXJ
Yooper In Training
bbaXJ's Avatar
Sounds like a nice bolt-in setup but you'll be VERY lucky to get half that for them. Not trying to be a dick, but that's just realism talking.
Old November 30th, 2014, 01:30 AM   #5
Badmunky
Badmunky's Avatar
The 17 PM'S I have already received between this forum and the other 4 I have them listed on, and the fact that I have been offered 3k 4 times already tell me you are wrong.
When I bought them 3 months ago I practically had to beat guys off with a stick to get them!
The lockers and gears alone cost over $2,500 BEFORE you have them installed.
I don't think I will have any problem selling them. It may not be to a member of this forum. But they will sell.
Hell I just saw a guy get $1,250 for a STOCK D30hp with over 100k on it. And it's brakes where shot!
Old November 30th, 2014, 01:17 PM   #6
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
i concur
Old November 30th, 2014, 01:37 PM   #7
Silver93XJ
Silver93XJ's Avatar
Originally Posted by unclebeaner View Post
i concur
X3 if you do find someone to pay that much, that person had more dollars than sense.....
Didn't see any chromo shafts in that front 30....that's a must at that price.....
Silver93XJ is offline   Reply With Quote
Old November 30th, 2014, 02:48 PM   #8
Badmunky
Badmunky's Avatar
I will revise the listing with some more info soon. I missed several things that the Axles have as well.
I also have pics coming in a few min.
Trust me guys these cost over 7k when they where built.
Old November 30th, 2014, 03:42 PM   #9
chasetheface123
chasetheface123's Avatar
You couldn't even get that much for a good condition 60 in todays market..
chasetheface123 is offline   Reply With Quote
Old November 30th, 2014, 05:21 PM   #10
Badmunky
Badmunky's Avatar
I agree with you. 99% of the people would never pay that. But 1% will.
I updated the description with more info. I missed a few things.
Old December 25th, 2014, 09:59 PM   #11
Silver93XJ
Silver93XJ's Avatar
Still available?
Old December 25th, 2014, 10:03 PM   #12
Badmunky
Badmunky's Avatar
Yep.
Old December 26th, 2014, 05:25 AM   #13
srlbotanical
Because I Said So...
srlbotanical's Avatar
Ready to separate yet? I'm interested in a price for just the D30
srlbotanical is offline   Reply With Quote
Old December 26th, 2014, 07:20 PM   #14
InTeRnEt_RyAn
InTeRnEt_RyAn's Avatar
Default BUILT axles. ARB air lockers! D30hp, Ford 8.8. Rims to fit. 4:10 gears. Now w...
This! GLWS sparked my interest. I so want to build an xj or Mj. These would be nice under that lwb MJ in for sale. Keep it light and lean. Again GLWS
InTeRnEt_RyAn is offline   Reply With Quote
Old December 28th, 2014, 04:14 PM   #15
Badmunky
Badmunky's Avatar
Nope not willing to separate them.
Looking at like this:
They sell as a package deal, or I buy the wife her own rig and they go under that.
I don't need the cash. And will not take a big lose on them.
They sell when they sell. I'm in no hurry to be rid of them.
Old December 28th, 2014, 04:15 PM   #16
Badmunky
Badmunky's Avatar
Tho I will separate the rims.
$100 for the set.
Old December 29th, 2014, 08:24 AM   #17
noise_maker
Frustrated Monkey
noise_maker's Avatar
Where are you located? I may be interested in the rims
noise_maker is offline   Reply With Quote
Old December 29th, 2014, 02:31 PM   #18
bigdogwaggy
bigdogwaggy's Avatar
same, just need to get that cash!
bigdogwaggy is offline   Reply With Quote
Old January 2nd, 2015, 12:33 PM   #19
bigdogwaggy
so whats the info on the wheels?
Old January 2nd, 2015, 01:05 PM   #20
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Why is everything so rusty? Been sitting outside?
ReiKo is offline   Reply With Quote
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.63919 seconds with 85 queries
