Misc Jeep Part(s) LOTS of YJ parts! great prices, many for FREE! Pics at link. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2013, 10:43 AM   #1
BDSjeeper
BDSjeeper's Avatar
Send a message via AIM to BDSjeeper
Default LOTS of YJ parts! great prices, many for FREE! Pics at link.
HUGE UPDATE! Tons of new parts and pictures added, prices lowered, and free items added!!!
You can call me at 734-260-1667 if you have any questions or would like to come take a look look, or just shoot me a PM. My name is Steve.
All parts are located in Saline (Ann Arbor).
Its time to clear house! It with a heavy heart that I write this post, but I want to get this stuff moved before the weather turns on me and I'm stuck sitting on it for another winter. I've been out of the jeep game for ages, so I'm not too up on what prices are like now days - just going from memory. Feel free to let me know if I'm way off base on something and make me an offer.
***PICTURES can be found at this link***
http://s8.photobucket.com/user/BDSje...ary/YJ%20Parts
4.0L engine w/125k (give or take). Strong runner when parked, great oil pressure. All painted up (circa 2008). Ready for some plugs and a valve cover gasket. New water pump. Haven't touched it in 5 years or so. $400
Very clean YJ frame. MORE shackle reversal kit already installed. Searched long and paid a lot for such a nice clean frame. Set up for 4.0L. $400
Clean titled 1992 YJ. My former daily driver turned trail rig. No axles, suspension or drivetrain of any sort. Complete (but gross) interior, still complete with dirt and mud from my last wheeling trip. Rusty, holy, patched together. Basically talking a bare jeep to throw some 3/4 or 1 ton stuff in and go bashing, not much more. Includes all factory AC components (worked when parked). Family style cage and some off-the-wall soft top/full soft doors. $400
Extended YJ fender flares. Good shape, just need to be cleaned up. $75
YJ OEM Hard Top - Black. Rear wiper and defrost, but no wiring. May have a small crack in one of the corners, but I can't remember if that was this top or another one. I'll check. Either way, it was surface damage caused by a branch. $150
Brand new 4.0L exhaust manifold. Some aftermarket one to replace my cracked OEM manifold. $75.
Bestop black Sailcloth soft top with tinted windows and soft uppers. Great shape except for a split seam in the right front along windshield frame. Includes a FREE bonus matching top section with a tear in the left rear leg. Both are relatively new and in great shape otherwise, and could be repaired. Fix one and use the other as a trail top. Paid over $700 when new. $250
OEM YJ soft top frame. Bend in right front rail that connects to windshield frame. Could probably be straightened. Great shape otherwise. $50
Bestop strapless bikini top and rear deck cover. Good shape. Rear cover is designed to cover folded-down soft top. Works with family style cage. $75
YJ 20 gallon fuel tank with brand new fuel pump/sending unit. Never used. $40
TH400 set up for whatever those things came in... Can't remember now. I think it was a 4.2L and some BS transfer case. No idea if it works, never ran it. Don't even know how or why I acquired it!! $25
Bestop center console. Powered (light and 12v cigarette plug). $20
Draw-tite hitch. Accepts 1 1/4" receiver. $25
Alternator. Low miles (~25k). $20
Intake manifold/throttle body/injectors/power steering pump. $50
Stainless windshield hinges, hood hinges, and tire stopper. Don't think I have hardware for them though. $25
XJ Master Cylinder/Brake Booster/Proportional valve. $20
Shelby Daytona power seats. Same gray as OEM YJ interior. Was going to install as a replacement. OK shape. $50
FREE WITH ANY PURCHASE!
All YJ parts unless otherwise specified.
If you don't want/need anything from the list above, but need an item off the list below, make me a lowball offer. I just want to see this stuff go to good use. LONG LIVE THE YJ!
Neoprene seat covers. Front and rear, Black and grey. Condition: Meh. FREE!
Airbox. FREE!
Starter. FREE!
Serpentine Belt. FREE!
T-stat housing. FREE!
heater box/air box. FREE!
Brand new gas tank skid for smaller YJ tank (15 gal?) FREE!
Early YJ instruments (speedo, tach, and 5 gauge center pod. FREE!
OEM Foglight/rear defrost switch. FREE!
BDS 3.5" YJ suspension lift. ~20k miles on everything. Includes F&R double military wrap leafs, shocks, drop pitman arm (if I can get it off), and i should have the extended sway bar links around somewhere. $350 **GONE**
8.8" rear axle. Complete (caliper to caliper, u-joint adapter to diff cover) ready to bolt up to a YJ. I bought the axle a few years ago from a local junk yard what had a bunch of brand new, 0 mile explorer 8.8 axles still sitting on the OEM axle rack. I put maybe 2k miles on it, and it has since been sitting under my YJ chassis in the barn. MORE YJ perches and shock mounts, yoke adapter for stock YJ shaft, 4:10 gears, a set of fozzy and a set of stock spider gears. Again, this has been sitting for 5+ years, will probably need pads and rotors, but the hard stuff is done! $550 ***GONE***
Dana 30 front axle. Matching 4:10 gears to the above rear axle. Professionally rebuilt a few years ago when I was going through everything (all new bearings, shims, seals, axle shaft joints, etc) and has 0 miles on it since then. The problem is that I reinstalled it under my jeep chassis and never reinstalled the diff cover or filled it with fluid (idiot...), so it also has some lot rot on the ring/carrier/pinion/etc. Could probably be filled with oil and ran, but I'll let you make that call. $50 ***GONE***
NP231 - Advanced adapters SYE kit and Tom Woods CV driveshaft. ~125k miles on the case, ~20k on SYE/shaft. $150 ***GONE***
Rear swing out tire carrier. Includes D-Rings and 2" receiver. Used to sling my spare 33" up on it. Very HD. $150 ***GONE***
Daystar 1" Poly body mount/lift kit. Includes all hardware, brand new in the box. Not just lift pucks, these are the actual replacement body mounts. $75 ***GONE***
Steering Gearbox. Low miles (~25k). $50 ***GONE***
YJ Tub. Pretty typical Michigan YJ tub, maybe a LITTLE on the better side than most? Drivers floor is rusty but not yet rotten, it can be saved. Typical jeep spots, some small stuff around where the fender flares mount, etc. $400 **GONE**
Partially rebuilt AX15. All brand new bearings and seals. Chipped 5th gear with my puller during removal, was going to order a new gear and finish the rebuild, but you know... $25 ***GONE***
Radiator and shroud. Low miles (~25k). $25 ***GONE***
FREE YJ TUB WITH ANY PURCHASE (to the first to come get it before it is reclaimed by the earth). Seriously. Come get it. Includes tailgate and non-family style rollcage. **GONE**
AX15 Manual Trans - Worked fine when pulled, 125k miles or so. $250 **GONE**
Red YJ windshield frame. Bad glass but frame is in excellent shape. $50 ***GONE***
Steering Shaft. FREE! ***GONE***
Trailmaster Steering Stabalizer. FREE! ***GONE***
Front Driveshaft. FREE! ***GONE***
Rock Gear Bimini Top. Tear on right side, great trail top to keep the sun off you though. FREE! ***GONE***
Full Doors. Disassembled and partially rust repaired. All parts included. FREE! ***GONE***
Rusty Windshield Frame/glass. Cracked. FREE! ***GONE***
Grille. Disassembled and sanded down but now rusty again. All parts included. FREE! ***GONE***
AX15 Shifter/NP231 shifter/floor plate/shift boot. FREE! ***GONE***
AX15 Slave Cylinder. Newer. FREE! ***GONE***
Antenna and mount. FREE! ***GONE***
Swaybar. FREE! ***GONE***
Upper and Lower Radiator Hoses. FREE! ***GONE***
OEM Pitman Arm. FREE! ***GONE***
XJ front coil springs. FREE! ***GONE***
Tan Dash Pad/back plate. FREE! ***GONE***
Grey dash parts. FREE! ***GONE***
heater control. FREE! ***GONE***
All pedals (gas, brake, clutch, ebrake). FREE! ***GONE***
Battery Tray. FREE! ***GONE***
Misc Bracketry, all FREE! ***GONE***
Clutch backplate. FREE! ***GONE***
Wiper motor, misc linkages, and arms/blades. FREE! ***GONE***
Happy pickings!
Steve
BDSjeeper is offline   Reply With Quote
Old September 25th, 2013, 11:36 AM   #2
MichiganJeeper
May be interested in the 8.8.. pm me pics or text to 5179454169 thanks
MichiganJeeper is offline   Reply With Quote
Old September 25th, 2013, 12:27 PM   #3
cannaert
No more Jeep
cannaert's Avatar
Shoting you a PM on the tubs you have.
I will take the Tub. I need one ASAP.
Old October 1st, 2013, 02:49 PM   #4
BDSjeeper
BDSjeeper's Avatar
Sold a few things on the list + some odds and ends, still a lot left though. Updated the above listing and replied to a lot of PM's. I'll be taking some new/additional pictures tonight for those inquiring. Will update later on tonight.
Old October 2nd, 2013, 07:03 PM   #5
onewheelscotty
onewheelscotty's Avatar
Send a message via AIM to onewheelscotty Send a message via Yahoo to onewheelscotty
I'm interested in the top, and np321 :-) or 231.
onewheelscotty is offline   Reply With Quote
Old October 3rd, 2013, 04:09 PM   #6
rangell
Ma' Meatloaf
rangell's Avatar
Sent pm on half doors
rangell is offline   Reply With Quote
Old October 11th, 2013, 08:34 AM   #7
BDSjeeper
BDSjeeper's Avatar
Huge update. Prices lowered, items added, FREE section added, a bunch of new pictures! Check it out and let me know if you're interested in anything.
Old October 12th, 2013, 12:24 AM   #8
kixx007
Certified Ypsilantian
kixx007's Avatar
kixx007 is offline   Reply With Quote
Old October 13th, 2013, 02:42 PM   #9
Logdog
I picked up a bunch of goodies today and if anybody is looking for a frame, they should take a look at this one. It was clean!
Logdog is offline   Reply With Quote
Old October 15th, 2013, 09:25 AM   #10
snocross2xtremes
snocross2xtremes's Avatar
Thanks!
Similar Threads
LOTS OF PARTS 4L80e, 3k PI stall, lots more shady_573 Parts for sale 0 April 19th, 2011 11:14 PM
Misc Jeep Part(s) Lots of CJ 5/7 parts-soft doors, top frame, misc. parts, 304 V-8 parts, MAKE OFFER! Ready4Wheelin Parts for sale 16 April 11th, 2011 07:08 PM
Ongoing Moving Sale thread - Lots of Parts and Tools - LOTS More added 4/2/11 kkodet Parts for sale 30 April 2nd, 2011 01:02 PM
Lots- Ford Axles+parts, engines, 79-90 body parts, GM car,F450 Parts,GM 5th Gate,sled AZDIRT Parts for sale 6 October 26th, 2010 07:52 AM
WTB lots of stock 2000 TJ parts (susp, body parts) darkostoj Wanted 5 June 13th, 2007 11:48 AM
Page generated in 0.32158 seconds with 56 queries
