The start of a farm truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2019, 07:19 AM   #1
roll-bar Bob
roll-bar Bob's Avatar
Talking The start of a farm truck
For the past 15 years this Big Pig has been a pavement pounder as it is Way to Heavy to be off roading. Now that does not mean I have not buried it right up to the axles a time or two but for the most part I try to keep it on hard stuff because it sinks like a rock. Unfortunately with the farm I don't always have a choice in where I need to go and am finding the Pig ill-equipped for the task. First step the dam thing did not even have tow hooks on the front bumper like every other Ram ever made apparently that was not "standard equipment" until 05.
Now it might not look stuck but all four tires are on ice and that trailer is in a little swail = need to call for help
And this time I cut the corner to tight hooking the stump with the trailer fender sliding the Pig off the trail and into the trees another fun one to get out of without pull points on the front.
So after years of procrastination it was time to address this problem and last night the parts came in and got installed
Now this is just one small step but it will make a huge difference in my world as I have a ton of other plans for this Pig in the future but for now I need to get the house done.
RBB
roll-bar Bob is offline   Reply With Quote
Old February 14th, 2019, 08:15 AM   #2
Nice!
You're a busy man RBB.
Old February 14th, 2019, 08:46 AM   #3
bbaXJ
Yooper In Training
bbaXJ's Avatar
Send a message via AIM to bbaXJ
If you plan to use those tow points a lot I'd add some reinforcements. I learned the hard way that even the factory tow hooks rely heavily on the bumper brackets. After some pretty abusive pulling(two 3/4 tons trying to un-stuck a deuce and a half) I was never able to get the bumper aligned quite right again.
bbaXJ is offline   Reply With Quote
Old February 14th, 2019, 08:57 AM   #4
roll-bar Bob
thank you I do have bigger plans for it in the future but for right now this gives me something to work with
RBB
Old February 14th, 2019, 06:58 PM   #5
Kegger83cj7
Kegger83cj7's Avatar
Huh. My 95 and 06 2500 trucks both had front hooks. Never gave it much thought that it would have been an option. Even my 94 Chevy did. When I go shopping for the next one I will keep this in mind. Mine have gotten some use over the years. I bet another bumper would not fit on my 95 either when I sold it.
Kegger83cj7 is offline   Reply With Quote
Old March 25th, 2019, 10:46 AM   #6
roll-bar Bob
Yep about every 2 to 3 years the big bitch eats one of these
RBB
Old March 25th, 2019, 11:40 AM   #7
Wow, that blows!
Old March 27th, 2019, 07:40 AM   #8
roll-bar Bob
Well last night it was time for round two
After taking my cap off it became very clear something is still not right with my drive line and or my new angles given the bed of the truck came up about 3 inches after losing the cap. So while replacing the carrier bearing I noticed I had a u-joint that was bound up and needed replacement. I have been procrastinating on some of this maintenance for far to long waiting for warmer weather. I am way over do for replacement of the u-joints in my front axle also. Just one more thing on my list of things to do.
RBB
Old March 27th, 2019, 10:18 AM   #9
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
I'd say they needed to be replaced!
Blue XJ is offline   Reply With Quote
Old April 1st, 2019, 07:07 AM   #10
roll-bar Bob
and now time for round 3
I found a tie rod end and another u-joint last night that i need to put on my list of shit to fix this last winter has been hard on the old girl
RBB
Old April 1st, 2019, 07:23 AM   #11
I'm in the same boat as you. My Sierra is in need of some front end work.
Old April 1st, 2019, 09:15 AM   #12
roll-bar Bob
It is cheaper than a truck payment
a lot more work but cheaper
RBB
Old April 1st, 2019, 09:21 AM   #13
RBB
True! I'll be driving mine for a loooong time before I have another payment.
Old May 13th, 2019, 08:50 AM   #14
roll-bar Bob
time for round 4
Yep it was that kind of weekend
RBB
Old May 13th, 2019, 11:25 AM   #15
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
What kind of parts are you using that you are going thru them so quick? Is it just the local parts store stuff and get a life time warranty?
I know you said its a farm truck but damn you would think these things would last longer
and that ball joint, was that welding rods?
mideerslayer is offline   Reply With Quote
Old May 13th, 2019, 01:30 PM   #16
roll-bar Bob
I am putting Moog parts in it this truck has just lived a very very hard life with me at the wheel that tie rod end had a little over 300 K on it and I was not doing a good job with getting it greased the last half of its life either.
RBB
Old May 16th, 2019, 08:33 AM   #17
roll-bar Bob
Time for a new one of these
this truck is just eating hundred dollar bills
RBB
Old May 16th, 2019, 08:38 AM   #18
Yeah, you got a money tree in your backyard at that new house?
Old May 16th, 2019, 09:33 AM   #19
roll-bar Bob
I wish but at this point this truck is still cheaper to repair then my old man's $800 a month truck payment
But that was until the water pump sprung a leak last night this one might cost me a bit more
RBB
Old May 16th, 2019, 02:12 PM   #20
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Same can of worms with my 2010 Sierra. Replaced bumper, found out hitch was rotten. Replace hitch, noticed rear shocks were bad. Tried to replace shocks and spare tire winch was seized. Cut off tire winch and replaced shocks. Decided while i was there to change rear end lube, all cover bolts so rusted they were no longer bolt heads. wtf.
BigBlockBlazer is offline   Reply With Quote
'81-'87 Chevy/GMC squarebody truck sheetmetal and parts CSFJ Parts for sale 15 June 25th, 2019 07:20 AM
SOLD 1998 Do-all Ex-Welding Truck SOLD Lousypirate Completed Sales 12 October 3rd, 2018 02:00 PM
My Chevy Truck Story dragginwagon406 The Pub 26 November 27th, 2014 05:48 PM
f350 4x4 mud truck part out- move to truck part out please dirtpoor4x4 Vehicles for sale 6 October 31st, 2014 11:50 AM
1989 K5 (Full Size) Blazer Show truck Lifted 36" tires Monster Truck thunderace31 Vehicles for sale 15 July 17th, 2014 06:05 AM
Page generated in 0.64915 seconds with 87 queries
