52 Willys Truck - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2015, 09:05 AM   #61
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Look into a spring-mounted mounting set-up similar to that used on bigger military trucks. There has also been discussion about this kind of mounting on expeditionportal.com.
Old December 2nd, 2015, 06:27 PM   #62
John2001
John2001's Avatar
A little more progress. My wife and I put all the bolts that needed to go in the bed to hold it all together in tonight. We swapped out all the grade 6 bolts that I wanted to with grade 8s. We also mounted the fans, I had to redrill the holes on the cooler bracket because I forgot to compensate for the offset due to the added space required when installing the fan shroud.
John2001 is offline   Reply With Quote
Old December 2nd, 2015, 06:29 PM   #63
John2001
John2001's Avatar
This is as good of a picture as I can get given the angle and location of everything. My wife my have come up with a brilliant idea on how to mount the bed to the frame.
The fuel cell is just laying in there I haven't done anything with it yet
Old December 18th, 2015, 08:23 AM   #64
John2001
John2001's Avatar
Rims and tires 39.5x18s I picked them up last night. Bad picture but proof.
Old December 18th, 2015, 11:00 AM   #65
Nuggets
I fix stuff!
Nuggets's Avatar
I love this project. Are those pusher or puller fans? If you leave it in the current configuration, I think you will have some cooling issues unless you get positive air flow in there. I'd be afraid the low pressure area behind the cab would cause cooling issues if this vehicle is driven on the street. Just my 2 cents.
Old December 18th, 2015, 11:24 AM   #66
Cool Hand Luke
That was going to be my input as well. I just watched someone who had a rear engine truck with the radiator mounted in the same location struggle with cooling issues.
By using some duct tubing they ran a "vent" of sorts from the top of the cab down to the bed to help get some air moving behind the cab. It's a dead zone of sorts when the air comes up over the front of the vehicle. Something to consider.
Great progress though. Love that these trucks are still being restored.
Cool Hand Luke is offline   Reply With Quote
Old December 18th, 2015, 11:49 AM   #67
John2001
John2001's Avatar
This will never be driven on the street. I'm one step ahead of you guys when it comes to the dead spot. It's all planned out in my head.
Old December 18th, 2015, 03:40 PM   #68
John2001
John2001's Avatar
I also have just about all the parts to convert the rear drums to rotors. I have to cut the factory drum bracket off that's welded to the axle, fab up the dana 70 rotor style and weld it on. I could have easily bought a conversion kit but I don't want to go with a single piston GM caliper. I'm using all the factory parts from a 2000 E350 which is a dual piston setup.
I found these specs for the new plate I need to make if anyone ever needs it, I thought I'd share
Old December 18th, 2015, 05:12 PM   #69
jbsjunk
Little Member
jbsjunk's Avatar
See how Roadkill solved that hurdle.
www.youtube.com/watch?v=XuHIemMF4kY
Old December 19th, 2015, 04:04 PM   #70
John2001
John2001's Avatar
I got them made up today. I didn't follow the specs on the OD because I wanted them as big as I could make them. I'm trying to get everything in order so I I'll have plenty to do on my 4 day weekend coming up.
Old December 20th, 2015, 08:08 AM   #71
John2001
John2001's Avatar
Here's an idea of what it'll look like once the tires are on. My first order of business is to clean the garage before I get back to it.
Old December 20th, 2015, 08:12 AM   #72
John2001
John2001's Avatar
I'm still hoping to have it ready to play by mid summer minus building the engine
Old December 22nd, 2015, 06:51 PM   #73
John2001
John2001's Avatar
You guys have seen the floor... here's a revising of it, obviously still not complete.
Old December 22nd, 2015, 06:53 PM   #74
John2001
John2001's Avatar
Hole.....
No hole...
Old December 25th, 2015, 02:35 PM   #75
John2001
John2001's Avatar
More of the floor done. I used 1/8" plate over to drive shaft in case sh!t ever happens I won't have to worry about anything getting into the cab.
Old December 26th, 2015, 08:17 PM   #76
John2001
John2001's Avatar
I taught my 11 year old niece how to mig weld, she went to town with it.
She welded up a good majority of the bracket. I will be making some slight changes to it now that I realize the flaws in the design.
New seats installed
Old December 27th, 2015, 07:11 PM   #77
John2001
John2001's Avatar
I made a bracket for the fuel cell and mounted it in the bed today. I also bought a optima yellow top battery and will hopefully be wiring that up and finishing the fuel system this coming weekend.
Old December 28th, 2015, 12:50 PM   #78
adamrz
Zombie Hunter
adamrz's Avatar
New seats installed
Uncle of the year in my books. Awesome job both in concept and execution, with bonus points for teaching the next generation how to make things happen.
adamrz is offline   Reply With Quote
Old December 28th, 2015, 01:11 PM   #79
Nice. Keep at it!
Old December 28th, 2015, 06:14 PM   #80
John2001
John2001's Avatar
Thanks guys. I have a picture of my daughter pulling the bolts off of the trans pan and giving me a hand swapping the valve body somewhere.
Back to the progress...
Temporary fuel lines are installed, fuel pump is mounted and I need a new fuel filter.
The battery is set in a round about area of where it is going to be mounted, I'm waiting for a marine battery box before I make it perminamt. I started running the battery cables too. It was sometime around finishing this that I realized a branch fell and shattered my windshield on the Dodge..... I'm done for the night
Similar Threads
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 09:40 PM
Want to see your build sheet? blackbronco92 The Pub 43 February 16th, 2015 08:45 AM
blazer/jimmy sas build 2.2 OL RED Rig Builds and Pics 4 November 28th, 2014 05:00 PM
1983 FSJ Cherokee build - 4bt Cummins etc. kkodet Rig Builds and Pics 63 November 15th, 2014 07:43 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 09:00 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 1.11587 seconds with 88 queries
