52 Willys Truck - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2015, 08:02 AM   #41
John2001
John2001's Avatar
I got the bracket all made up for the bed yesterday and bolted to it. I have to make mounts to the chassis and bed still to put them together. I also tried to roll the edges of the bed, that was an epic fail. I'll have to come up with a way to do that when I get a chance.
John2001 is offline   Reply With Quote
Old September 25th, 2015, 03:56 AM   #42
John2001
John2001's Avatar
My wife and I got the floor installed and mostly bolted in last night. I'll get the rest of the bolts today. The bed is still not fastened to the chassis yet, I have to make mounts still. I set the radiator in place just to eye ball how I might wanti t to sit.
Old November 27th, 2015, 01:28 PM   #43
John2001
John2001's Avatar
Reverse manual valve body is in. Tomorrow I will be installing the high stall converter. I have front and rear drive shafts now and need to have them lengthened, just the rear for now until I have a front axle in place. I also need to get bearing retainers for the 205 one day. I may start reworking the floor tomorrow or Sunday also
Old November 27th, 2015, 05:37 PM   #44
Cool Hand Luke
I might have missed it but I can't remember reading, what thickness did you use on the bed?
Cool Hand Luke is offline   Reply With Quote
Old November 27th, 2015, 06:36 PM   #45
John2001
John2001's Avatar
Hell, I never even checked. It's thick enough and has enough bends in it it won't be a worry by the time I'm done with it and it's thick enough I can't roll the damn edges of the bed no matter what I've done so far! I'm going to mount an 1/8" or so plate to the front inside bed floor bolt that down and mount the coolers to it.
Old November 27th, 2015, 07:42 PM   #46
jeepers48
jeepers48's Avatar
Hey John could you post the dimensions of your pickup bed, thx.
jeepers48 is offline   Reply With Quote
Old November 27th, 2015, 08:00 PM   #47
John2001
John2001's Avatar
65-1/2x44" by 22" deep. I wanted the bed to stick out past the chassis 1" on the side. Once I link the rear suspension and ditch the springs I'll cut another foot or so off the back of the chassis. I deliberately made it too short for now
Old November 28th, 2015, 03:42 PM   #48
John2001
John2001's Avatar
Torque converter is installed, I just need to put the bolts in the fly wheel. I made a bracket for the coolers and bolted the radiator to it. I need to finish it and bolted the condenser (trans cooler) and power steering cooler to it also. Here's a partially complete picture.
I found an 1/8" plate to mount the cooler bracket too for the bed. My plan is to bolt the plate to the bed frame and then mount the bracket to the plate on the floor. I like overkill. I'll get some Taurus/sable electric fans for cooling.
My plans for the engine are changing...
Old November 28th, 2015, 03:55 PM   #49
John2001
John2001's Avatar
Old November 28th, 2015, 04:19 PM   #50
Cool Hand Luke
Haha sounds thick enough to me
Old November 29th, 2015, 05:59 PM   #51
John2001
John2001's Avatar
The bracket to hold the coolers are now finished and the 1/8" plate are all bolted to the bed
The bed is still only resting on the chassis. I haven't come up with a way I'd like to mount it to the frame yet.
I still need to get some longer bolts for the mounts and a handful of grade 8 bolts.
I should be picking up a set of fans tomorrow after work.
Old November 30th, 2015, 04:22 PM   #52
John2001
John2001's Avatar
I'm now the owner of a fuel cell and taurus/sable fans, radiator, condenser and whatever else it came with... all I wanted was the fans. Hopefully soon I'll be able to get back at it. I have a new phone now too so no more half ass pictures
Old December 1st, 2015, 04:09 PM   #53
John2001
John2001's Avatar
If anyone is still paying attention don't mind the hack job but the fans have a new home
Old December 2nd, 2015, 06:47 AM   #54
John2001
John2001's Avatar
I can use a good idea if anyone has one. I need a good way to mount the bed to the frame. There's enough pictures on here for you to know what working with. I don't think I want it solid mounted. There's too many important things in the bed and it's not the most ridged box I've ever seen so I want to somehow put it on mounts that will flex just a little. I can run with a decent idea.
Old December 2nd, 2015, 08:06 AM   #55
adamrz
Zombie Hunter
adamrz's Avatar
great build! you do some fast work. Watching this one for sure.
adamrz is offline   Reply With Quote
Old December 2nd, 2015, 08:26 AM   #56
John2001
John2001's Avatar
7 documented months... it's not going as fast as I was hoping but other things take priority over a toy quite often. I hope to have it ready to go the summer after next. Then the winter follow that pull the motor punch it out and build it and the trans
Old December 2nd, 2015, 08:47 AM   #57
BigBlockTony
BigBlockTony's Avatar
I would look for some body mounts for a Jeep body to put under the bed. It may raise the bed up more but if you go with polyurethane mounts it should be plenty stiff.
BigBlockTony is offline   Reply With Quote
Old December 2nd, 2015, 08:48 AM   #58
BigBlockTony
Or else put the radiator on some poly mounts and solid mount the bed
Old December 2nd, 2015, 08:55 AM   #59
John2001
John2001's Avatar
I'm not 100% confident in the bed frame being able to take a hard blow without getting a little tweaked. I'm fine with the bed going up some. I'm going to have to raise it anyway to level it out.
My first thought was to take two pieces of angle iron and sandwich them together. One welded to the bed one welded to the frame with a bolt going through them. If I did that in 3 spots per side I figured it would work fine but now I'm not so confident in that.
Old December 2nd, 2015, 08:57 AM   #60
John2001
John2001's Avatar
I am planning on this thing seeing a little bit of air time.
Similar Threads
Go-Fast Inspired Colorado build RDK_YJ88 Rig Builds and Pics 274 March 19th, 2016 09:40 PM
Want to see your build sheet? blackbronco92 The Pub 43 February 16th, 2015 08:45 AM
blazer/jimmy sas build 2.2 OL RED Rig Builds and Pics 4 November 28th, 2014 05:00 PM
1983 FSJ Cherokee build - 4bt Cummins etc. kkodet Rig Builds and Pics 63 November 15th, 2014 07:43 PM
The Ultimate KJ Liberty Build RDK_YJ88 Rig Builds and Pics 12 October 19th, 2014 09:00 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.66516 seconds with 87 queries
