Project "Spartan" 1977 K5 Blazer "Drove it yesterday and new pics" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2008, 01:41 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default Project "Spartan" 1977 K5 Blazer "Drove it yesterday and new pics"
Well my vehicle is a 1977 Chevy K5 blazer when it started.
Engine:1997 GM Vortec 350 switched to carb w/ extreme 4x4 cam
Tranny: SM465 w/ granny low
T-Case: NP 205
Axles:3/4
Front: Dana 44 "Open" 4.10
Rear: 14bolt FF w/10.5 ring gear "Open" 4.10
Suspension: Add-A-Leaf
Tires: P285-75R16 Super Swamper SSR
Transformation 1:
Axle:
front: Auburn limited slip, warn premium lockouts, brute force u-joints, new seals, bearing, raised steering arm,ext...
Rear: Detroit locker, new drums, shoes, hardware, wheel cylinders
Suspension: 2" blocks all the way around...i know illigal ass hell!!!
Tires: 34-10.5/16 bias ply Super Swamper LTB's
Removed heater box from both inside and engine comp.
Transformation 2:
Broke the dana 44 twice.
First time was the stub shaft on the drivers side, while trying to pull the friends jeep out. Also broke the lockouts and u-joint
Second time was stuck in a hole and matted it and broke both inner and out axle shafts, u-joint was never foung and all bearings all the way around. Sunk blazer up the tranny hump in water!!!
Alxe:
Front: Dana 60 from a SRW out of a 1986 1ton truck
Installed the Dana 60 front then bent a connecting rod and cracked a head!!! From sinking the last time i broke the axle shafts
Transformation 3:
OVER THE WINTER
Engine: 355 engine
Steering: Crossover steering
Suspension: 4" rough counrty lift, eliminate sway bar
Tires:16-35/16 Super Swamper boggers and a 13-36/16 Super Swamper TSL Bias ply spare
Alxes:
Front: 4.56 gears w/ a Detroit locker
Rear:4.56 Gears
Exhaust: Cut-outs @ collector
Lights: Pro Comp 6" round Competition Driving lights
Can't really think of anything else at this time, but if you have any suggestions for me feel free to tell me thanks!!!
Old October 7th, 2008, 01:45 PM   #2
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Help the front out, weld that 14bolt!!
RIP FULLSIZE4LIFE
Old October 7th, 2008, 01:49 PM   #3
Hoss Blazer
!SPARTY ON!
Ya i forgot to say that i broke the Detroit in the rear and ended up welded it!!!
What else should i do to the front??
Dynatrac lockouts, drive flanges, 35spline outer stub upgrade??
Old October 7th, 2008, 02:11 PM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
spicer 35 spline stubs and warn lockouts, I wouldn't spend the money on dynatrac hubs for 36's and stock shafts.
Oh and some 38-39's
Old October 7th, 2008, 02:36 PM   #5
Hoss Blazer
!SPARTY ON!
All you need is new stub shafts and u-joints for the upgrade right?? And 38-39's aren't really practical where i go wheeling but that would be great!!!
Thanks for the input!!!
Old October 8th, 2008, 10:18 AM   #6
Hoss Blazer
!SPARTY ON!
Drive Flanges or Warn Premium Lockouts???
Old October 8th, 2008, 10:50 AM   #7
benny87
Young Gun..!
benny87's Avatar
Warn hubs.. You need something to be a weak link so why not a hub.
benny87 is offline   Reply With Quote
Old October 8th, 2008, 07:33 PM   #8
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Dont do the exhaust cut outs they are gay
Old October 10th, 2008, 10:31 AM   #9
Hoss Blazer
!SPARTY ON!
Makes more power with the cut-outs right at the collector!!
Old October 10th, 2008, 02:43 PM   #10
Hoss Blazer
!SPARTY ON!
DAMN!!!!
Warn Premium Lockouts: $426
Poly Performance Dana 60 Drive Gears: $245
Old October 16th, 2008, 04:48 PM   #11
Hoss Blazer
!SPARTY ON!
Just put 35 spline stub shafts on the list now!!!!
Old October 16th, 2008, 05:31 PM   #12
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
If you are only running 36" tires. I would not put any more money into that Dana 60. It should be strong enough for 36" tires. I would use that money for a winch or something. looks Good i'm sure you will have alot of fun in that blazer.
CHEVYRCKS is offline   Reply With Quote
Old October 16th, 2008, 06:56 PM   #13
Hoss Blazer
!SPARTY ON!
I've read that the Dana 60 outers are the same as the 44 outer stub shafts and i've already broke 2 of them in my 44 that i used to have!! So are they built stronger in the 60's or are they the same then???
Old October 17th, 2008, 02:05 AM   #14
01bellmer01
01bellmer01's Avatar
Send a message via MSN to 01bellmer01
i think it may need a 50" subframe lift with 30" chrome spinnerz and some woofers ghetto rider haha
01bellmer01 is offline   Reply With Quote
Old October 21st, 2008, 05:07 PM   #15
Hoss Blazer
!SPARTY ON!
Anoyne else think of anything i can do to upgrade???
Old January 1st, 2009, 01:31 PM   #16
Hoss Blazer
!SPARTY ON!
New pics of my engine and Oops of it too!!!
Ok i wish it was my engine!!
557 Hemi putting out 2,100 horse and 1,500 ft lbs before it blew up on the dyno @ school!
Old January 1st, 2009, 04:08 PM   #17
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Put Rockwells under it and spend the extra money on a warm big block.
Old January 17th, 2009, 08:20 AM   #18
Hoss Blazer
!SPARTY ON!
Just spend 800 on a Dana 60 and 14 bolt this summer so i don't really want to buy rockwells. Already had a 14 bolt rear that i just did new breakes on this summer also. So i just pulled the 44 out of the front and sold it w/ the extra 14 bolt i had. And i have a 454 bored .60 over that i did when i was in college and also put splayed caps in the middle three main caps. But i don't have money to get the 496 stroker kit and i want to run it next year so i have to put the small block back togeather!
So i was cleaning the carbon off my pistons w/ a wire wheel and found the #8 piston slapped a valve! Took all the valves out of the heads and none were bent though, so thats good. Gonna take the heads and block to the cleaners and have them steam cleaned and magna-fluxed next week.
Old January 17th, 2009, 10:47 AM   #19
Fraser
Fraser's Avatar
DAMN!!!!
find cheaper lockouts, you done need the fancy kind if your setting them up to be the piece that breaks first. [pre u-joint/ shaft]
Old January 17th, 2009, 11:05 AM   #20
Hoss Blazer
!SPARTY ON!
My luck has always been stub shaft or inner shaft brakes then the u-joint then it gets the lockouts too!!
Similar Threads
"GONE" FREE!! K5 Blazer Hard top "GONE" BigBlockBlazer Completed Sales 6 November 29th, 2009 12:17 PM
"""SOLD""" New Extreme Duty Rocker Guards $150.00 fits TJ & YJ """SOLD""" Nerv Completed Sales 10 June 11th, 2009 03:40 PM
68 jeep truck project "pics" silverz Rig Builds and Pics 18 June 9th, 2009 07:42 AM
"SOLD" 97 Ford Taurus SHO V8!!!! "Updated w/ pics"SOLD" 2poor2jeep2 Completed Sales 14 January 10th, 2009 05:25 PM
**SOLD**Ex Killer "B" Built CJ7 Project $3000 ***Pics Up*** Price Drop biohazardbill Completed Sales 11 September 22nd, 2008 07:04 AM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 1.23053 seconds with 86 queries
