WhiteRhino's Latest Mods - Page 93 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 25th, 2019, 12:21 PM   #1841
IDK, 4ds and 5.38s is all Ive used, in the 2.72:1 always felt like a good ratio to me. the 3.8 not so much. Your tcase is 3.8 isn't it?
Yes 3.8.
Old December 25th, 2019, 12:27 PM   #1842
Yeah, I can see on the high wheel speed climbs your gonna miss what you had. Hopefully high range will work for ya.
Old December 25th, 2019, 12:32 PM   #1843
Well since we donít have any snow it could be a while before I find out.
Old December 26th, 2019, 08:00 AM   #1844
You also have a right pedal. 1st gear high should be great for snow hill killin.
Old December 26th, 2019, 08:39 AM   #1845
Hole shot will not be as good.
Old December 27th, 2019, 09:14 AM   #1846
Use both feet, it'll be fine!
Old December 27th, 2019, 09:49 AM   #1847
joe_jeep
welfare wheeler
joe_jeep's Avatar
Send a message via Yahoo to joe_jeep
Yes 3.8.
the 4 to 1 tcase in my rubicon is not the best option for me personally, with
5.38s and 35s. low is way too deep for me. i dont wheel out west, or big rocks.
mine is more of an overland rig almost. it will be horrible at the dunes!
it was different in my juggy, cause i had the creeper 4 spd.
i used high range, 1st gear alot. i like wheel speed.
a 2.72 to 1 tcase would fit me much better.
i always thought an atlas highlander 3 to 1 case would be sweet!
joe_jeep is offline   Reply With Quote
Old December 27th, 2019, 11:24 AM   #1848
Neutral drop holeshot ftw!
Old December 27th, 2019, 11:36 AM   #1849
^ this!
Old December 28th, 2019, 10:34 AM   #1850
joe_jeep
welfare wheeler
joe_jeep's Avatar
i got a feeling the stock 42rle, with 130k on it, wont enjoy this option!
but effective about 7 times.
Old December 28th, 2019, 12:38 PM   #1851
I'm pretty sure Jim doesn't have to worry about a 42rle
Old December 28th, 2019, 02:21 PM   #1852
Default WhiteRhino's Latest Mods
Test run was a success. No issues other than poor driving. Lol
Old December 28th, 2019, 02:26 PM   #1853
joe_jeep
welfare wheeler
joe_jeep's Avatar
nice
Old December 30th, 2019, 07:38 AM   #1854
Awesome!
Old December 30th, 2019, 01:56 PM   #1855
RDK_YJ88
589 Fabrication
RDK_YJ88's Avatar
Send a message via AIM to RDK_YJ88
Hoping to get a test run on the roxors new suspension At the mounds on Wednesday.
RDK_YJ88 is online now   Reply With Quote
Old January 10th, 2020, 09:52 PM   #1856
Oh, me too! I don't know if I will like it or not. I'm quite used to sitting on a rock and using the rocker guard as a pivot point. I'm also sure that a couple times I may have flopped because my rocker is what kept me from going over.
Time will tell........
And yes, cutting the body is pretty scary. The directions that came with them sucked. They said to cut 2" below the door opening, then strike a 45 degree at front and back and then a straight line to cut the floor.
Well:
- the really meant 2" below the door jam indentation. I used the literal term of "door opening" and discovered I cut too high. Thankfully I still had enough meat to get the bolts in. But I'm going to cut the other side 3/8" lower.
- striking a straight line front to back to cut the floor would move the floor about 2" further than it should be in the higher area. (right under the seat) If I had done that I would have needed to add a patch plate back in.
I'm not going to button up the passenger side until I do the driver side so I can take better measurements. Not that the passenger side is bad, but I will be able to do the second side better.
Got time on them now. Opinions?
Old January 11th, 2020, 06:37 AM   #1857
More good than bad but the boatsides have some down side to them. I've noticed several places where I clear that I would have drug in the past. (You witnessed this at the Badlands) Ground clearance is important! One thing I have noticed is that I tend to roll over onto my side more and without the side step I scrub my body armor more. And I lost the step to stand on while putting the soft top on and off.
I have pushed the side of the door opening in and out of shape. The boatsides are not as strong as the original sheet metal tub that is boxed by the rocker guard and also stiffened up by the side steps. I need to straighten it back out and add a small side step 3" wide but have not gotten around to it. I will definitely be doing it before I go back out west.
Old January 11th, 2020, 09:17 AM   #1858
The flopping thing is a concern. I know I've been saved multiple times by the step on the rocker. And even just taking that off, holy hell is it a lot more work getting in/out lol. I'll have to try and get creative reinforcing the tub etc.
I think I'm gonna line mine with a sheet of uhmw as well.
Old January 11th, 2020, 09:21 AM   #1859
I like the sound of metal on rock. Actually that does help to determine how hard you are in to something.
Iím also going to tie back into my cage / seat support to support the door opening.
Old January 13th, 2020, 06:42 AM   #1860
Jayden
In the band!
Default suggestion
I realize I've been spared on different occasions by the progression on the rocker. What's more, even simply taking that off, blessed damnation is it significantly more work getting in/out lol.
Jayden is offline   Reply With Quote
Tags
meballs
Whiterhino's new bumper Tab Jeep Tech 65 October 23rd, 2009 11:23 AM
OLD MAN Whiterhino's birthday 79CJ The Pub 33 December 19th, 2008 10:27 PM
Whiterhino's Mounds Shakedown Run Renegade II Pictures and Video 20 May 19th, 2008 08:08 PM
Latest Explorer pics and mods etvaugha Rig Builds and Pics 1 January 29th, 2007 08:04 PM
Page generated in 0.90064 seconds with 88 queries
