Johnny's GoatBuilt JHF buggy build - Page 19 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 23rd, 2018, 07:26 AM   #361
LCG HIJKLMNOP
They can be fancier than angle iron, but the concept is the same. Take the load off the bolts so that the bolts are doing the retaining, not supporting the entire load.
Old July 23rd, 2018, 09:54 AM   #362
bbaXJ
Yooper In Training
bbaXJ's Avatar
While I agree with you guys on taking the load off the bolts, 8 1/2" gr 8 bolts won't even bat an eyelash at that job. Besides, under power 1 side will be pushing down and 1 will be pulling up. If you don't want any shear loads on the bolts you'd want U shaped brackets wrapping around the top and bottom of the frame, which would probably suck to remove. The clamp load alone from that many bolts squeezing the brackets to the frame will probably keep them out of much shear force.
Old July 23rd, 2018, 10:00 AM   #363
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I had thought about wrapping it around but thought it added complexity without a lot of extra benefit. You really think it'd be a benefit over the one 1/2" grade 8 bolt going through the bushing?
I guess if they get loose, they would be at a bigger risk.
Old July 23rd, 2018, 10:15 AM   #364
Cool parts peddler
Ironman Offroad's Avatar
A little lip on one side would help with alignment on reinstallation.
Old July 23rd, 2018, 10:16 AM   #365
I would weld a “heel” ledge along the bottom to maintain location when they get removed and will also keep it from falling out if your bolts came loose.
Old July 23rd, 2018, 10:17 AM   #366
Fawkin Dale beat me to it by a minute.
Old July 23rd, 2018, 10:21 AM   #367
LCG HIJKLMNOP
I wasn't as concerned with torque as much as keeping the engine from continuing to the ground when you land from those sweet jumps. At least with a lip on it, it can't fall to the ground. You could accomplish the same thing by making your thru-frame bushings stick out the thickness of the bracket material. Then the bushing would take the load and the bolts would hold them to the frame. I'm sure I'm over-complicating it. It's a little compromise for piece of mind IMO.
Old July 23rd, 2018, 11:27 AM   #368
FYI, @JohnnyJ your used tires have arrived. They look pretty good for their age but you will need to vulcanize one of them.
Old July 23rd, 2018, 02:18 PM   #369
ROXROES
cool story
ROXROES's Avatar
It takes almost 18,000 lbf to shear a 1/2" bolt, so x8 thats 144,000 lbf. I don't know how much air time it would take to generate that much force, but I think its negligible since you'd likely be the weak link and not the bolts.
And since I love to get enginerdy with this stuff, the clamp load of a properly torqued grade 8 1/2" bolt is roughly 12,000 lbf, so x8 thats 96,000 lbf. So I'd dare say those bolts will never experience any shear stress of significant levels. :deuces:
ROXROES is offline   Reply With Quote
Old July 23rd, 2018, 02:27 PM   #370
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by ROXROES View Post
What bbaxj said but with math and numbers and stuff
Old July 23rd, 2018, 02:39 PM   #371
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Whoa, that was a shit ton of tech there. Had to make sure I was in the right place.
Old July 23rd, 2018, 02:52 PM   #372
ROXROES
cool story
ROXROES's Avatar
Old July 23rd, 2018, 03:14 PM   #373
LCG HIJKLMNOP
Dowels are for location, keyways are for stress, bolts are for holding shit together. You didn't even consider the moment arm to the CG of the engine from the mount point, or the fact that they'll pull threads before they shear. 4 of the 8 bolts do nothing with a down force, geez man, where'd you get that degree? Your calculations aren't even valid. Draw a free body diagram before you try to get all enginerdy next time.(Patiently awaiting FEA stress diagram ) I don't care either way. I can't even spell wheelering. It'll be fine until it isn't.
Old July 23rd, 2018, 08:29 PM   #374
Wink
Old July 24th, 2018, 06:59 AM   #375
ROXROES
cool story
ROXROES's Avatar
So the engine is going to buckle allowing a moment to occur.
Old July 24th, 2018, 08:38 AM   #376
Cool parts peddler
I like the dowel and tapered slot idea.
Old July 24th, 2018, 09:01 AM   #377
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Use (16) 7/8" grade 12 bolts. Sleeve the frame. Slot it, dowell it. And then, booger weld the shit out of it.......
RIP FULLSIZE4LIFE
Old July 24th, 2018, 10:08 AM   #378
These things are taking up space in our warehouse. Thinking of taking bids.
Sent from my iPhone using Tapatalk Pro
Old July 24th, 2018, 10:41 AM   #379
ROXROES
cool story
ROXROES's Avatar
How many free vulcanizing repairs are included???
Old July 24th, 2018, 10:50 AM   #380
If you want tires that have been vulcanized, I'll sell you mine.
And fwiw, I tend to need to repair about 1 of my reds per year. I can live with that.
Similar Threads
1985 Grand Wagoneer $7,500 HenryJonesJr Vehicles for sale 1 August 26th, 2016 09:27 AM
1977 Wagoneer street/strip project $3000 Grand Rapids MI ghinmi Vehicles for sale 0 August 7th, 2016 08:47 PM
1985 Grand Wagoneer $8,500 Or Best Offer HenryJonesJr Vehicles for sale 0 June 9th, 2016 09:18 PM
1977 Wagoneer project $4000 Grand Rapids MI ghinmi Vehicles for sale 1 April 16th, 2016 02:08 PM
1985 Grand Wagoneer Project - Almost Done HenryJonesJr Vehicles for sale 0 April 10th, 2016 07:43 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.65606 seconds with 87 queries
