Redneck Engineering - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > The Pub
The Pub A friendly forum where everybody is nice, and will answer any questions you have about life.
Old May 1st, 2020, 10:19 AM   #1
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Default Redneck Engineering
So here's the problem statement: How do I get a vehicle with no rear axle up onto a trailer?
Long story: My sister got in an accident in her jeep (JKU) last year sometime where an oncoming car hit her in the left rear wheel. The impact ripped the rear axle out from underneath the jeep but miraculously did little body damage at all. Insurance totaled the vehicle out and my brother in law bought it back and pocketed a few grand. It's currently been sitting in his garage for about a year now and he has finally realized that he needs some help to get the thing back on the road.
This is apparently where I come in. I have to get the jeep back to my barn somehow but as the jeep currently has no rear axle under it (it's sitting next to it) I am somewhat at a loss as to how to get this thing on my trailer. First things first, let me describe the trailer.
The trailer is a low deck, 24' gooseneck with about a 2 1/2' dovetail. The deck height is relatively low at about 23" and then about 16"-18" at the bottom of the dovetail. I have ramps for the trailer but they're general equipment ramps and not very smooth, easy enough to get the front wheels on but no way in hell I could roll wheel dollies up them. On the front of the trailer I have a 9.5ti Warn that will do most of the pulling.
Current best idae I have come up with is to use an engine hoist to lift the back of the jeep into the air and then bump the winch very slowly forward ensuring that the engine hoist doesn't get side loaded or turned. Theoretically if everything stays straight this would allow me to get the rear of the jeep up past the dovetail and then I can set it on wheel dollies to move it farther forward.
Also suggested was the use of pvc tubes as rollers to allow the back of the jeep to roll on to the trailer, I'm not against the idea but it'd require buying the pvc pipe and then just having it sitting around. I have also tossed around the idea of just throwing down sheets of plywood and letting the winch go at it and dragging the thing up...
Open to questions and other ideas. Trying to make this thing the least dangerous/redneck as possible while still getting the job done.
Edit: pictures of trailer....Attachment 265404Attachment 265406Attachment 265408
Edit two: pictures of how the jeep sits.... Attachment 265410Attachment 265412Attachment 265414
Mihlfeldl2005 is offline   Reply With Quote
Old May 1st, 2020, 10:34 AM   #2
roll-bar Bob
roll-bar Bob's Avatar
Coming from the king of REDNECK I would
Grab a bent trailer axle from out back use some muffler clamps and maybe a couple C-clamps to temp an axle under it and drive it home in front wheel drive.
RBB
roll-bar Bob is offline   Reply With Quote
Old May 1st, 2020, 10:38 AM   #3
Mihlfeldl2005
RBB
That's way classier than I was expecting
Sent from my SM-G960U1 using Tapatalk
Old May 1st, 2020, 10:45 AM   #4
roll-bar Bob
I have a slightly bent 3500 Lb trailer axle I just took off my car hauler it is 95" wide so the tires would set outside your tub
if you want to borrow it for a few weeks come and get it.
Old May 1st, 2020, 11:22 AM   #5
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Send a message via AIM to jeepfreak81 Send a message via MSN to jeepfreak81 Send a message via Yahoo to jeepfreak81
I was going to suggest temporary welding a framework underneath after lifting that has a long skid on each side and just drag it.
jeepfreak81 is offline   Reply With Quote
Old May 1st, 2020, 11:23 AM   #6
xj4life
xj4life's Avatar
Sounds like a solid plan to me as long as the engine hoist is strong enough to lift the Jeep. Possible to back the trailer under the Jeep once its in the air? Seems safer to move the trailer under the Jeep than move the Jeep to the trailer...assuming I'm reading your description right.
Project Midlife Crisis - Tube Chassis Crawler
xj4life is offline   Reply With Quote
Old May 1st, 2020, 11:28 AM   #7
Mihlfeldl2005
The engine hoist would just be too lost the back. My intentions were to leave the front wheels on the ground and just pull them up the ramp with the winch.
Old May 1st, 2020, 11:45 AM   #8
Ajdemello
Member
When Ive pulled the rear end out of scrap trucks. I lift the back up high enough to get the trailer under it with a floor jack on the trailer under the hitch usually. Then start winching it up the floor jack will roll on the trailer then when its up far enough put blocks under the jeep and pull out the floor jack. Its a little sketchy but it seems to work. If im understanding what your asking.
Ajdemello is offline   Reply With Quote
Old May 1st, 2020, 12:10 PM   #9
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Put it in 4 low and drive it up there? It'll drag the back along just fine!
Blue XJ is offline   Reply With Quote
Old May 1st, 2020, 12:20 PM   #10
bbaXJ
Yooper In Training
bbaXJ's Avatar
Send a message via AIM to bbaXJ
I was going to suggest basically what RBB said. I have a 14 bolt sitting in my garage if you have any 8 lug rollers around. Some creative wood and ratchet strap use could hole it in there well enough to get the turd on and off the trailer.
Or lift up the back of the JK, winch/strap it to the front of your TJ, and assist it up that way. Repeat the same thing for unload.
bbaXJ is offline   Reply With Quote
Old May 1st, 2020, 04:04 PM   #11
Mihlfeldl2005
So far the engine hoist seems like the easiest idea, I do have a couple of 4x4s that I'll be taking with just on the off chance I need to use them as skis for the rear
Old May 1st, 2020, 05:35 PM   #12
Procure a flat-ish car hood. Put pretty side down. Set rear of jeep on hood. Ratched strap hood to jeep. Drag that bish on to trailer.
Old May 1st, 2020, 07:06 PM   #13
Tractor with front bucket attached to the cage
Old May 1st, 2020, 07:31 PM   #14
Mihlfeldl2005
You missed the redneck part, that's damn near civilized.
Old May 2nd, 2020, 07:55 AM   #15
Mihlfeldl2005
Going with the engine hoist and using 4x4s as skis as back up. Will take pictures of the hilarity for y'all
Old May 2nd, 2020, 09:58 AM   #16
Mihlfeldl2005
Not too badClick image for larger version
Old May 2nd, 2020, 09:22 PM   #17
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
I usually cheat and use two 2x12s per side with sand in-between. Slides right up. I've even driven FWD cars up on my trailer that way without spinning a tire.
wrath is offline   Reply With Quote
Old May 3rd, 2020, 06:18 AM   #18
Mihlfeldl2005
Didn't think about the sand, but that would've helped
Old May 3rd, 2020, 10:17 AM   #19
xj4life
xj4life's Avatar
Not too bad
Page generated in 0.54753 seconds with 83 queries
