"Dirthead 509" TJ Project - Page 50 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2019, 12:56 PM   #981
Steering box seal replaced
pic
pic
pic
pic
Jesus, I know you like photography but do you need such BIG FUCKING PICTURES??
Old June 3rd, 2019, 01:00 PM   #982
found a way to link from google photos, that's how they come in. Until GL4x4 makes photos great again, I'm not going out of my way to format stuff. If they yuge, they yuge.
Old June 3rd, 2019, 01:13 PM   #983
Tapatalk is your friend
Old June 3rd, 2019, 01:32 PM   #984
I don't need anymore friends
Old June 5th, 2019, 08:23 AM   #985
Ordered new shifter cables for t-case and ordered driveshaft material. Not sure when alro drops got so damn expensive but it was literally cheaper to ship dom from who the fukc knows where than it was to drive up the road and pick it up by hand.
Old June 5th, 2019, 08:31 AM   #986
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Steel cost are nuts right now
Sent from my SM-G955U using Tapatalk
Old June 5th, 2019, 12:50 PM   #987
Just trying to help you old guys out. Don't need you pulling a muscle squinting at the screen or breaking a hip getting your biphocals out.
Old June 10th, 2019, 10:00 AM   #988
Driveshaft material showed up. No faith in this working but I own it so it's going in. Wallace Racing Driveshaft Calc says 995ft-lbs for torsion so on paper it's fine ish. Eye test says it's a toothpick.
I bought 1.75"x .250 wall to sleeve my driveshaft from 1 3/4 to the 1 3/8 so I had to turn the ID. Lathe work used to be fun, now it's just another thing that has to be done. That's how I know I need to wrench less and wheel more.....
Keeping runout to a minimum is always the obstacle. I turned the bushings until they were a transition fit. With that fitment the end of the driveshaft can still move .030" or more, so a much more sophisticated technique is needed to keep everything aligned while welding
Tacked together and bolted in to check clearances one more time before welding it solid. Immediately making a spare, no point in waiting. It either works or it doesn't and sometimes it never doesn't.
I also made the pictures smaller for the old man. Seems counter-intuitive but whatever, he's always been difficult.
Old June 10th, 2019, 10:39 AM   #989
Pics are perfect.
It will be fine. That's a thick wall, the torsional strength will be fine. Just because you have a loud muffler doesn't mean you have lots of HP.
In all seriousness, you won't have a vibration problem. Don't sweat it ~ run it.
Old June 11th, 2019, 07:52 AM   #990
Test fit with pass side front full stuff and drivers full droop. Verified I have to cut the thread and nut off the shifter knob.
Always paint that $.99 stuff when it's hot. I should be able to see if it rubs this way.
Don't forget the plugs. I hate welding them back up with ATF in the shaft. Always catches on fire.
Spare shaft didn't want to give up it's sleeve. Found my old plug welds. Plug weldz, the new X weld
Finished turning the new adapter sleeve last night so I should be able to clean this spare up and get that put together this week yet. Moving onto the other 20 things on the list soon. Should be able to drive again by the weekend. I should probably finish tuning it before I break it again. I'll add that to the list.
I know WhiteRhino is confused about why I'm working on this. I need to have wrist surgery later this year so I'm doing my September prep ahead of time. It's easier to motivate myself when I have a deadline approaching. This is different for me
Old June 11th, 2019, 09:06 AM   #991
Don't worry about balancing it. You won't be going that fast anyway.
Looks good.
Old June 12th, 2019, 08:10 AM   #992
Did you make sure the yokes were clocked the same?
Ryanw10 is online now   Reply With Quote
Old June 12th, 2019, 09:49 AM   #993
Good eye. It doesn't look like it. No wonder he needs it balanced.
Old June 12th, 2019, 09:54 AM   #994
I dont think you will ever get a driveshaft with the yokes not lined up balanced. I once fought a nasty vibration with a professionally built and balanced driveshaft only to find out the it was assembled one splines worth off.
Old June 12th, 2019, 03:04 PM   #995
You mean the white lines, you don't worry about those white lines.
It's half ass assembled a spline or 2 off but it's aligned. Pull yoke, rotate, assemble. Easy peasy. The seam on the inside of the DS tube gives it away. Have to cut a slot in the adapters to get them to slide in. I drew that line down the tube with angle iron before I cut it apart.
project "almost as cool as stan's yj" yj UPDATE 1 ton tj now page 2 *DONE* tom77cj5 Rig Builds and Pics 84 June 11th, 2010 01:14 PM
Project "Spartan" 1977 K5 Blazer "Drove it yesterday and new pics" Hoss Blazer Rig Builds and Pics 35 June 16th, 2009 09:01 AM
"""SOLD""" New Extreme Duty Rocker Guards $150.00 fits TJ & YJ """SOLD""" Nerv Completed Sales 10 June 11th, 2009 03:40 PM
03 Jeep "Project Rubi" 37's beadlocks and stuff ... SOLD TJ-RUBI Completed Sales 61 November 6th, 2008 06:47 PM
SOLD - 1968 CJ-5 $800 Good "starter" project. PavementPounder Completed Sales 21 November 20th, 2007 11:39 AM
Page generated in 0.65901 seconds with 73 queries
