Johnny's GoatBuilt JHF buggy build - Page 23 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2018, 09:13 PM   #441
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
4 link uppers mockup. Lowers are planned out but need mockup. Geometry will have 3" higher roll center in the rear than front, which should be good. Front AD% will be higher than rear (65% to 55%).
Pinion tie in will need some relief on pass side to clear at full bump.
Current thought is 1.625x0.188 uppers and 2x0.375 lowers. All DOM with inserts. Already picked up 7/8x3/4 rod ends for uppers and lowers.
Old November 25th, 2018, 02:29 PM   #442
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Rear tire check. Making sure I know where the shocks can live.
Old November 25th, 2018, 05:11 PM   #443
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Just need the concrete and rebar to set and the rear 4-link will be complete.
Old November 25th, 2018, 06:18 PM   #444
Awesome
Old December 4th, 2018, 08:39 AM   #445
curbdog17
Mini Van
curbdog17's Avatar
Strong Work
Old December 9th, 2018, 10:38 AM   #446
awesome progress
I'm excited to see this thing out and about.
Old December 22nd, 2018, 06:43 PM   #447
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Rear links are now hopefully more durable. Front upper link is frenched into the truss.
Have the pass upper link in cardboard cad. Plan is to get it cut tomorrow.
Old December 22nd, 2018, 06:46 PM   #448
Ryanw10
Ryanw10's Avatar
So jealous of your shop.
Buggy looks great too!
Ryanw10 is offline   Reply With Quote
Old December 24th, 2018, 10:19 AM   #449
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Cut a set of axle side UCA mounts yesterday, but realized they were 1/2" too low. Will have to modify and recut.
Thanks on the shop. I'm super happy with the space.
Old December 24th, 2018, 10:54 AM   #450
Moving right along. Looks great
Old December 24th, 2018, 11:53 AM   #451
Too slow.
Old December 26th, 2018, 08:11 PM   #452
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Need the pass side axle UCA bracket and then turn uppers into metal.
Old December 27th, 2018, 05:10 PM   #453
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Full bump. Front needs steering, rear needs shocks.
Old December 27th, 2018, 05:37 PM   #454
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Rear mockup. Tank is clear of axle UCA mounts.
Radiator is old 26x19 from when the wrangler had a 4.7. Want to go to 31x19.
Old December 28th, 2018, 08:10 PM   #455
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Looking fancy! Keep it up
Old December 29th, 2018, 12:06 PM   #456
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Went to use weld on brake brackets and found they line up perfectly with the flange and not the tube. I think I will chop the bracket around the flange and make a piece to bolt on to the stock 4 bolt flange. Wish I would not have scrapped the old backing plates so I had a template.
Old December 29th, 2018, 01:49 PM   #457
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Checking front for clearance and making sure shocks dont bind. Now to slide it back and get rear shocks setup.
Old December 29th, 2018, 02:37 PM   #458
vroom vroom
I'm starting on your wheels today.
Old December 29th, 2018, 05:17 PM   #459
A little boring head work.
Sent from my iPhone using Tapatalk Pro
Old December 29th, 2018, 07:19 PM   #460
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Hooray, I can mount the winter tires, now just to get done before winter ends.
One rear shock temp mounted. Need to rotate lower bracket a bit forward. Plan to make a nicer upper mount that spans the tubes. Then duplicate on pass side.
Similar Threads
1985 Grand Wagoneer $7,500 HenryJonesJr Vehicles for sale 1 August 26th, 2016 10:27 AM
1977 Wagoneer street/strip project $3000 Grand Rapids MI ghinmi Vehicles for sale 0 August 7th, 2016 09:47 PM
1985 Grand Wagoneer $8,500 Or Best Offer HenryJonesJr Vehicles for sale 0 June 9th, 2016 10:18 PM
1977 Wagoneer project $4000 Grand Rapids MI ghinmi Vehicles for sale 1 April 16th, 2016 03:08 PM
1985 Grand Wagoneer Project - Almost Done HenryJonesJr Vehicles for sale 0 April 10th, 2016 08:43 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.50168 seconds with 87 queries
