Johnny's GoatBuilt JHF buggy build - Page 21 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2018, 01:15 PM   #401
Oh and thanks for cheer leading today.
Old August 5th, 2018, 06:17 PM   #402
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Working on finding full stuff. Looks like I'll need to redo engine mounts to make room for upper links. Going to need to stare at it some more.
Depending on how close to straight the front tire is, I should be about 82 wide up front to the outside of the tires. Trailer is 84 wide, so winning there.
Old August 5th, 2018, 06:38 PM   #403
jhnyquest
goof ball
jhnyquest's Avatar
When is hopeful completion date?
Old August 5th, 2018, 07:25 PM   #404
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Would really like to do a shake down run at the end of the year. Hoping to do first big trip early next year.
Old August 6th, 2018, 06:59 AM   #405
ROXROES
cool story
ROXROES's Avatar
Yep, you'll have to make the engine mounts as high as possible. I have about a dozen beefs with this chassis, the frame rail interior width, and front and rear heights being the same are a couple.
ROXROES is offline   Reply With Quote
Old August 6th, 2018, 09:10 AM   #406
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I was thinking this morning that I could make a jig with the old mounts, and then be able to make a new set on the bench. Maybe even be able to CAD up a set and have them cut.
One other issue that I need to work through is shock mounting. Looking through other builds, most are using remote reservoir coilovers or swayaway air shocks. I have Fox 2.5 air shocks, and they are 3" longer than the reference builds, which is making them a pain to find space for.
Old August 7th, 2018, 06:57 AM   #407
ROXROES
cool story
ROXROES's Avatar
Guess you'll have to switch to portals so you can mount them down on the c's!?
Old August 7th, 2018, 07:21 AM   #408
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
John, what lower link mounts are you using?
Mihlfeldl2005 is offline   Reply With Quote
Old August 7th, 2018, 07:31 AM   #409
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Not that I would, but that same thought crossed my mind. I'm thinking something like what Currie did on their 4600.
Barnes 4wd
Sent from my SM-T710 using Tapatalk
Old August 7th, 2018, 08:05 AM   #410
Mihlfeldl2005
Is that lower bolt where you're going to be mounting your air shock?
Old August 7th, 2018, 08:59 AM   #411
Default Johnny's GoatBuilt JHF buggy build
I don't like the air shock mounting that low. When I look at how bad my link mounts are worn (directly behind the axle) I wouldn't want my shock mount to be seeing that abuse.
The first pic is of my driver side. You can see the wear on the under side of the tab. The second pic is my passenger side where I had a bunch of 1045 plates made up that I am progressively adding to the outside of the existing tabs. It gives me a stronger tab and then makes the tab a 1/2 wide instead of the original 1/4.
Old August 7th, 2018, 09:18 AM   #412
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
That's what I'm thinking about. That's off the Currie/Savvy 4600 car, but it does get the shock low so it's not above the hood. But.. it's low.
Yeah, that's what I'm struggling with. I don't want the shock above the hood. Was thinking I'd need to put a skid on the bottom that's sacrificial if I go this route.
More sitting and staring coming.
Old August 7th, 2018, 09:25 AM   #413
Mihlfeldl2005
What length of shock? I don't feel like going back and looking for it.
Old August 7th, 2018, 09:36 AM   #414
I thought about that too but I can't get the link out if I plate the bottom.
On a side note, I can tell you it's a lot easier removing the links with the shock directly over the axle. I can pop my front links in and out without much issue. Because my rears are offset in front of the axle, it always wants to twist when I remove a link.
Old August 7th, 2018, 09:54 AM   #415
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Fox 2.5 x 14. They are 24.6" compressed compared to a SAW 2.5 x 14 that's 21", and Fox 2.0 x 14" remote reservoir coilover is about the same.
Yeah, definitely is more of a pain if I need to tear it down. Was wondering if I could make the link mount and have the air shock close to the tube and the link mount further out, but both near bottom of axle tube.
Old August 7th, 2018, 10:07 AM   #416
Why not stick the shock thru the hood like some badass race rig? It would give you baller status.
Old August 7th, 2018, 10:16 AM   #417
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Casey Gilbert doesn't have shocks sticking through the hood. #racecar #myhero #dreamy
Old August 7th, 2018, 10:40 AM   #418
Well then you should have bought a complete Miller Motorsport chassis.
Old August 7th, 2018, 12:06 PM   #419
bbaXJ
Yooper In Training
bbaXJ's Avatar
It's what all the cool kids are doing
Old August 26th, 2018, 11:54 AM   #420
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Just getting back from vacation. This arrived the day I was leaving.
I talked with Offroad Anonymous and asked if he make a cut down truss for me. We traded some emails and measurements and he cut it for me. All fits well, just need final fitment and to glue it on.
Similar Threads
1985 Grand Wagoneer $7,500 HenryJonesJr Vehicles for sale 1 August 26th, 2016 10:27 AM
1977 Wagoneer street/strip project $3000 Grand Rapids MI ghinmi Vehicles for sale 0 August 7th, 2016 09:47 PM
1985 Grand Wagoneer $8,500 Or Best Offer HenryJonesJr Vehicles for sale 0 June 9th, 2016 10:18 PM
1977 Wagoneer project $4000 Grand Rapids MI ghinmi Vehicles for sale 1 April 16th, 2016 03:08 PM
1985 Grand Wagoneer Project - Almost Done HenryJonesJr Vehicles for sale 0 April 10th, 2016 08:43 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.52642 seconds with 87 queries
