Johnny's GoatBuilt JHF buggy build - Page 17 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2018, 09:24 PM   #321
PUNISHER TA
PUNISHER TA's Avatar
Originally Posted by JohnnyJ View Post
Need to talk with the TIG-meister header guy to see if he is up for tweaking the headers to go around the top of the trans. @PUNISHER TA
Post-Collector? Im down for that.
PUNISHER TA is offline   Reply With Quote
Old April 30th, 2018, 10:58 PM   #322
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Why not try and relocate the coils?
Mihlfeldl2005 is offline   Reply With Quote
Old May 1st, 2018, 10:59 AM   #323
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Are you talking moving coil packs rather than adjusting bar? Yeah, could do that. I need to stare at it more. I want to mock up more stuff and see how it all could fit.
Old May 1st, 2018, 11:03 AM   #324
Mihlfeldl2005
Well, I feel like if you move the coil packs you'll be able to raise the engine up a bit more. Nothing noteworthy but it could help with clearance and maybe a little driveline angle
Old May 1st, 2018, 07:36 PM   #325
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks like plenty of room between crossbar and converter.
Old May 1st, 2018, 08:07 PM   #326
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Alternator fits with Goatbuilt relocation.
Old May 1st, 2018, 08:09 PM   #327
Good stuff
Old May 1st, 2018, 09:24 PM   #328
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
John I would defiantly recommend more room under the seat to the top of that t case, Check the manufacture specs but most suspension seats require 2-3 inches of clearance.
Old May 2nd, 2018, 07:23 PM   #329
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Hood clearance issue solved. Let's create a new issue.
Old May 4th, 2018, 09:02 PM   #330
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Looking good! What's size tires are you gonna run?
sbcrichie is offline   Reply With Quote
Old May 5th, 2018, 02:11 PM   #331
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Goal is to grab some 39 Red Krawlers, but for now I have some half-life 42 Iroks or 37 Trep Radials.
Old May 6th, 2018, 12:14 PM   #332
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Friday night I messaged Jesse Haines and asked how he set up his drivetrain. He said Atlas 1/4" off frame and skid and crank centered. The tcase spacing matches what Roxroes suggested.
So I borrowed a spare Atlas from Hoser and mocked this up. The seat frame just barely clears the atlas shifter extension off the back, but this is 2" deeper in the chassis than the 205. WIth the drop of of the case it gives me plenty of space under the seat.
There is about 1/2" clearance under the trans pan running a factory 3" truck pan. Only thing I can't check right now is converter clearance since I had to move to my mockup empty trans since the th400 output is too long for this Atlas setup.
I'm thinking of moving the drivetrain 1/2" to the front of chassis and building some mounts. That will give a little more clearance to between seat frame and Atlas.
Old May 6th, 2018, 02:25 PM   #333
Sounds like a good move all around.
Old June 2nd, 2018, 09:25 PM   #334
jhnyquest
goof ball
jhnyquest's Avatar
Old June 4th, 2018, 11:47 AM   #335
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Time has been short lately, but had some time on Saturday after being out of town over Memorial Day.
I'm working on a trans mount. The first idea was to see if I could tuck the bushing directly under the trans mount. That didn't work as it left < 1/4" between the mount and the belly skid. So I debated whether to hard mount or if I could fit the poly mount to the front of the cross-member. This is how i left it on Saturday.
I had to notch the crossmember, and will add tabs and a box in around where the poly mount intrudes.
Old June 5th, 2018, 10:47 AM   #336
bbaXJ
Yooper In Training
bbaXJ's Avatar
That's how I did the trans mount in order to flat belly my TJ. Just a flat plate tied into the side of the bushing tube with some anti-rotate gussets. Works great.
Old June 5th, 2018, 11:27 AM   #337
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Good to hear. I probably went overkill on it hoping it wouldn't tear itself up hanging in front of the mount, but I've had mounts work loose and tear up trans mounts in the past.
Old June 23rd, 2018, 01:30 PM   #338
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Needs a little more metal, but the trans crossmember is in place. Still debating if drivetrain goes forward a little.
Old June 23rd, 2018, 01:42 PM   #339
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Wide shot as its sitting.
Old June 23rd, 2018, 04:37 PM   #340
Similar Threads
1985 Grand Wagoneer $7,500 HenryJonesJr Vehicles for sale 1 August 26th, 2016 10:27 AM
1977 Wagoneer street/strip project $3000 Grand Rapids MI ghinmi Vehicles for sale 0 August 7th, 2016 09:47 PM
1985 Grand Wagoneer $8,500 Or Best Offer HenryJonesJr Vehicles for sale 0 June 9th, 2016 10:18 PM
1977 Wagoneer project $4000 Grand Rapids MI ghinmi Vehicles for sale 1 April 16th, 2016 03:08 PM
1985 Grand Wagoneer Project - Almost Done HenryJonesJr Vehicles for sale 0 April 10th, 2016 08:43 PM
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Page generated in 0.50473 seconds with 87 queries
